lsnover
Joined: 4/29/2002 From: Bath, PA, USA Status: offline
quote:
ORIGINAL: Aerotech Hello, I have contacted our frieght company and should know shortly Langster. As far as the motor goes Banker. Its a generic setup. I chose not to setup for one specific motor since the 50cc class motors are comming out very quickly to serve demand. The customer has the options so you dont have to modify the plane for another motor type. Thanks John John: Can you elaborate on this? I ordered one of these on the basis that based on the photos, it was pretty much ready to roll for a DA50. I was debating between yours, Wildhare and BMEs, and chose the Aerotech because of advertised weight, the setup for cannisters, and the setup for the DA50. BME is leaving their motor mount essentially unfinished. While this is not a big deal, I am not much of an engineer, and prefer something that is as plug and play as possible, especially with regard to setup of thrust lines, etc. If the finished product is not ready to roll for a DA50, I would appreciate very detailed instructions on installation measurements, etc. if at all possible. Thanks for your comments. Sincerely, Lee
