lsnover
Joined: 4/29/2002 From: Bath, PA, USA Status: offline
Tom: Aside from some QC issues and the weight, I'm pretty happy with mine. My biggest gripe is the Canopy fit. THe canopy is a bit "warped" and doesn't fit snug, and the design of the bolts that secure it in place is poor. If you tighten it too much, it collapses the balsa on the side of the fuse. If you don't tighten it enough, the bolts come loose. Additionally, while the supplied hardware was OK, alot of it is odd metric sizes, which makes it hard to substitute individual parts. The plane looks great, and flies great. I've done everything I can to lighten it but had to add some nose weight, as it was tail heavy. How you making out with yours? Regards, Lee
