RE: Walkera Dragonfly #36
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: Walkera Dragonfly #36 Page: <<   < prev  19 20 [21] 22 23 24 25 26 27 28   next >   >>
Login
RE: Walkera Dragonfly #36 - 10/10/2005 10:34 AM
Bodybuilder
Score: 100
Last Login: 10/11/2006
Status: offline
Aurora707 thanx for that info.
When you go to meet Jarek let me know - we might go together -- my email is dj884@hotmail.com so if you want to go together let me know.
Do you know when is the next heli-meet going to be on?
Hide Signatures
(in reply to aurora799)
       Post #: 501
RE: Walkera Dragonfly #36 - 10/10/2005 3:25 PM
borisboy
Score: 100
Last Login: 2/3/2007
Status: offline
Hey guys
Hate to be apain need some urgent advice my #36 turned up today i bought it from ebay but i have a problem, the tx is broken there are parts raterling around in side of it and the left stick doesnt return to center it feels broken,and also the throttle is on the right stick, i am emailing the seller but has anyone had this problem and what should i do i am gutted should i put up with it and get agood tx or what please help me.
cheers
Hide Signatures
(in reply to Bodybuilder)
       Post #: 502
RE: Walkera Dragonfly #36 - 10/10/2005 4:27 PM
Spockie-Tech
Score: 100
Last Login: 2/20/2008
Status: offline
One of my Walkera Tx's was like that too.. I dont think the Chinese have ever heard of Quality Control.. either that or they dont care.
I just opened mine up and fixed it. It was a misplaced plastic bit that wasnt snapped into its slot on the gimbal. Unless your seller tells you not to I'd just open it up and have a go myself, as long as you're not the type who is all thumbs.
_____________________________
Rotorcraft Pilots dont "Fly" - They *beat* the air into Submission !
Hide Signatures
(in reply to borisboy)
       Post #: 503
RE: Walkera Dragonfly #36 - 10/10/2005 4:41 PM
nickgrant
Score: 100
Last Login: 11/2/2005
Status: offline
If I order a brushless motor & speed controller, do I need to order a tool to get the gear off the old motor, and put it onto the new one?
Also, are they a pain to fit - am I likely to break my model trying to get the old motor off?
I ordered one of those 2,200mah batteries rated at 15C, so I'll let you know how it performs. It's only 155g... sounds too good to be true?
Hide Signatures
(in reply to colrod12)
       Post #: 504
RE: Walkera Dragonfly #36 - 10/10/2005 8:03 PM
NOZZARCHELI
Score: 100
Last Login: 12/5/2006
Status: offline
Hi nickgrant,
Nope don't force it....getting your motor out is easy....im guessing u have a 36.....all you have to do is take out the screws with a small phillips screwdriver, unpulg the old one and take it out.....if your adding a brushless you ill have to disguard the old power and motor wires and attach the speed controller to the receiver also, use the power lead coming from the speed comtroller to plugn your battery into, otherwise your motor won't work properly........serew it in and bobs your uncle....your done
Hope this helps,
Matt.
Don't Steal, The Government hate's competition
Hide Signatures
(in reply to nickgrant)
       Post #: 505
RE: Walkera Dragonfly #36 - 10/10/2005 11:57 PM
thecheatscalc
Score: 100
Last Login: 4/17/2009
Status: offline
ok first yes this is a 36, it's the 36 thread after all... just remove the main body screws in the front (not servo screws) until you can get the motor out. now get an align420LF and their programmable 25A ESC just patch those +/- wires into the RX recieving batt wires (parallel) and plug the servo like connector into the ch4 slot. next just plug up the motor and stick it in the proper slot and you're done. on my model both of my free li-polys lift my 700g heli off just fine. best store for the motor and ESC is grand rc also look in the TRex pinnion section for one that looks like 11?,13?,15? that'll give you 4 pinnions (9,11,13,15 don't ask just do) and they'll fit just fine on your existing motor gear and align motor. also while you're there get some REX abs blades (315mm) they're invencible, good luck
thecheat
www.ushobbysupply.com - your #4 HQ!
All stock located in the U-S of A!
Hide Signatures
(in reply to NOZZARCHELI)
       Post #: 506
RE: Walkera Dragonfly #36 - 10/11/2005 1:57 PM
Terry B
Score: 100
Last Login: 7/2/2008
Status: offline
Dear All
I have found another source of parts for the 36 in Australia
http://stores.ebay.com.au/rc-hobby_W0QQcolZ4QQdirZ1QQdptZ0QQftidZ2QQtZkm
I have ordered some and he emailed that they were posted today. Only A$4 for postage no matter how much you order. This is much better than from HK. Now lets hope the correct parts turn up.
Terry B
Hide Signatures
(in reply to thecheatscalc)
       Post #: 507
RE: Walkera Dragonfly #36 - 10/12/2005 8:58 AM
Mikey-Flies
Score: 100
Last Login: 12/27/2005
Status: offline
Got my 36 today and went about checking it over. This came with aluminum upgrade parts for some of the head, brushless motor and atiyator, and 2 sets of blades (foam and "fiber" blades that appear to be some kind of plastic with lightening holes at the root) and a 2200 mah lipo + charger. These yellow plastic blades are quite a bit heavier than the foamies but more flexible. They have stickers saying 3d on them. The foam blades were destroyed in a "Not quite a crash crash" due to a loss of control ( radio or receiver, not sure which yet and not sure if I'll bother to find out). The brushless does start up somewhat abruptly. The lipo charged fine and so far seems up to the task.
* 1) Noticed that the part HM36-003 (perhaps spindle shaft? Not sure of the right terms yet) was bent. This was visibly noticable by carefully inspecting the blade grip angles. Took it out and verified it was bent.
2) The flybar paddles were quite a bit out of whack (different plane, slightly flared up, bent at different angles)
* 3) Noticed that HM36-006 L ancon pole??? pieces were not parallel. Didn't bother to adjust as it did not seem to affect function of the head.
4) Several (Mostly in the areas that the head bits had been swapped into) screws were stripped or of mismatched types!!
5) Lots of loose or too tight screws!! -- If you have read to check the screw tightness, well do it, and then do it again. You should probably go out and by some loctite and use that as well as several of them loosened again after a short hop.
6) The transmitter left stick (Throttle/tail) was not returning to normal. As per another thread popping the x-mitter apart and putting the gimbal back into its socket cured the problem.
7) The motor got really hot really quick. The motor screws seemed to be sunk into the plastic of the frame. After putting in spacer washers this was resolved (I think, didn't fly/run the motor that long but it didn't take long to get hot before so I think it has been resolved).
8) The pitch was all out of whack (really really positve, w/o the ability to even approach 0 deg at full down). I adjusted the servo arm to at least get to ~0 deg pitch, but the links have to be shortened to go any further. Didn't bother to go further than that before the first flight (planning on normal mode test hop).
* 9) The tail servo moves quickly but centers really slowly. Is this a normal thing? Is there something that has to be adjusted on the gyro to compensate for this?? I tried swapping in a hitec 55 servo and it behaved the same.
* 10) The tail drive gear for the belt drive rides low on the shaft gear when any lift is applied to the rotor. The main rotor moves up and down about 1/2 the width of the tail pulley gear. I think something here needs adjusting but I'm not sure what?? Perhaps moving the tail drive gear on the main shaft down a little if that is possible?
11) Almost no aileron control. The head moves about 1/4 as much aileron as it does fore/aft. I think this is a combination of things that will need adjusting.
12) The pitch of the blades was radically different. This was easily tracked down to different length ball joint links and corrected.
13) The motor was meshed too tightly to the main gear. Fixed by moving it back slightly. Still got hot until the washers were added.
14) Gyro led light never lights!
15) Flight notes. The heli was quite slow to cyclic commands which although it made the heli stable was not a good thing in my mind. I have a FP century hummingbird that is fairly nimble so this may just be a transition period to the slight larger sized bird. Exceptionally stable though. Lift off was non eventfull aside from a little left drift that was hard to compensate for due to the lack of good aileron travel and some wobbling (which I believe is the result of too much pitch and too little headspeed, should be quite fixable). The tracking seemed odd at first (off a bit) but then seemed to adjust itself after a short bit of running (blades setting, or bent shaft turning to align the bend vertically perhaps??). I was quite surprised at how stable and vibration free it was given that the spindle (I think that is what it is) shaft was bent a little.
16) The Tail pin was not in securely and actually fell out during a test flight (only about 3 feet up. Landed w/o incident although the heli had started to spin and was picking up speed... lucky it was close to the ground and not pitched in any direction). I actually lost the pin for a while and so replaced it with a piece of carbon fiber that was ca'd into the tail slider. I'd suggest Glueing the stock piece in as well as it appears more than willing to work its way loose.
17) A few hops later, Complete loss of control resulting in full throttle and full left/back servo deflection. This was not good. I read about something similar but decided to give the stock radio a try anyways as it had behaved nicely on the bench. I would warn against anyone using the walkera transmitter and receiver for now as you may experience a complete loss of control. The blades whacked themselves to death on a staircase right beside me. Luckily as they were thrashing I managed to unplug the heli before anything else was really damaged. Item #33 i the exploded view in the instruction manual cleanly broke (both sides of the swash). I think this is where the rotational energy of the crash was spent. One ball links piano wire was bent a bit and one of the lock nuts for a blade has vanished into the ether (anyone have a source for those?). That was it for damage. I superglued the #33 parts and reinforced the backside with a bit of zip tie and the feel quite strong now so other than the missing locknut she is flight worthy again (mechanically). Electrically is another issue.
18) Have not managed to reproduce this glitch on the bench and I don't really want to attempt flying again (although it was shaping up to be a very well behaved bird) until I can resolve this issue. I'm thinking of getting another receiver to use with my Hitec eclipse (Should have got a barebones kit!)
I haven't yet adjust the plt/pzt knobs on the transmitter or finalized the link length for the blade pitch/aileron controls.
I also played with the gyro extent and sensitivity switches . I hadn't noticed much change on the bench changing the sensitivity from one extreme to the other but the "servo Radian" pot definitely controls the range of travel of the servo. I'm also quite confused by the "Lei Sure" dip switch described in the manual. Could this be a heading hold switch? Overall the tail control could be a little quicker but I didn't have more than a few minutes of test hops to play with it.
Hide Signatures
(in reply to Terry B)
       Post #: 508
RE: Walkera Dragonfly #36 - 10/12/2005 3:41 PM
Spockie-Tech
Score: 100
Status: offline
Thats a hell of a good summary of things to watch for on the #36 there Mikey.. Allow me to add a few comments, mostly agreeing with you, but some thoughts and questions as well..
quote:
ORIGINAL: Mikey-Flies
Where did you buy a #36 that came with aluminium upgrades and ABS/Fiber Blades ? Was the Lipo the fairly common unmarked "blue" one, which seems to have highly variable quality, or was it a different type ?
They sound like T-Rex ABS blades. If they are, then they are much better for a beginner to practice on, since they're a lot tougher. The white foamies are light and stiff, but disintegrate at the slightest touch, whereas the ABS ones will cop a pounding without a mark.
From what I've seen and others reports, the radio glitches are most likely caused by the 5v regulator in the receiver/esc overheating and shutting down momentarily. Probably due to excessive current load from the servo's, since there is no end-point travel adjust to stop them from pushing against the limits. Removing the plastic casing and heatsinking the two surface mount transistors (actually, one is the motor speed control FET, the other is the 5v regulator) seems to reduce the incidence of over-heat shutdowns a lot from what others have found.
Feathering shaft I believe, except in Walkera engrish, where its probably called a "Turnig Plole" or some such.. Are people who can read and write english really that hard to come by in China ? Perhaps someone should offer their services to Walkera as a product manual author ?
quote:
flybar paddles out of whack, Several screws stripped or mismatched, Lots of loose or tight screws, transmitter stick not returning, motor got hot quick. motor screws sunk into plastic frame. pitch all out of whack
Usual wonderful QC. How they can call these things RTF is amazing. They would be better off selling them as Kits like the T-Rex.. I'm sure your average 5yo, and even his all-thumbs dad could do a better job of assembly than whatever trained monkeys they must use on their assembly lines
I noticed that too.. it is caused by the gyro. if you bypass the gyro and plug the tail servo direct into Rx channel 4, it goes away (but of course flying suddenly becomes very hard ). I now have a Futaba Gy240 on my #36 and it seems a lot better. Supposedly the "V2" Walkera Gyro is a "Heading hold" gyro whic his presumably what they are trying to say with "Lei Sure" (Direction Sure ?). but flipping that switch never did anything on my Walkera Gyro. I might set them both up on the bench and see what I can find out, since noone seems to have answered my estion about how you tell a HH from a Rate Gyro yet. I'll get back to you on this one.
quote:
tail drive gear for the belt rides low on the shaft gear when any lift is applied to the rotor. The main rotor moves up and down about 1/2 the width of the tail pulley gear. I think something here needs adjusting but I'm not sure what??
Mine was like that too.. so much so that I was worried about the teeth stripping since will the main shaft lifted it was only engaging the belt drive gear by about 1/4 of the tooth. I fixed it by disassembling the whole frame, and replacing the aluminium bush at the top of the main shaft (just under the top bearing), with a slightly thicker one that I salvaged from my old #35 frame. That eliminated the up and down play in the main shaft and kept the gears in mesh. To anyone who doesnt have a "parts bin" lying around, perhaps try and find some suitable washers.
Sounds like a gyro fault. probably just the LED, since if the gyro was dead you probably wouldnt be able to fly. It should flash fast when its initialising, slow when its completed its initilisation but has no signal from the receiver (tx off), and come on solid when all is good.
I upgraded mine to an align brushless motor and governer mode ESC, and this allowed me to wind the head speed way up compared to the stock brushed motor, which seems to have made a huge improvement in flying characteristics. It always felt mushy with the standard motor. With the rotors at full speed regardless of pitch it feels crisp.
Ditto to me and a friend. Does anyone at the factory actually fly these things after production has started ?
quote:
other than the missing locknut she is flight worthy again (mechanically). Electrically is another issue. Should have got a barebones kit!
Thats what I did after similair experiences with my #35. The frames arent that bad for the $ if you go over them and check everything you've listed. The electronics are junk. Its what I'd read on quite a few occasions (after I bought my #35) and it is so.
I guess that when you pay about $150 (Australian, $110US) in total for a Transmitter, Receiver, Speed Controller, Gyro, 4 x servos, Motor, Battery and charger you really cant expect much.
A "ready to crash" Walkera #36 is about $240 in Australia for the full package.
Heres what I spent to make it ready to *fly*
(Australian dollars)
$100 - Walkera #36 Bare-Bones Frame
$ 78 - Align 35Amp Brushless Esc (Governor mode & Soft Start)
$ 55 - Align 420LF Brushless Motor
$ 90 - Align 2000mah 18C Lipo
$200 - Triton Charger (you can get a Swallow for $90 which will do)
$150 - Futaba GY240 Heading Hold Gyro
$ 80 - 4 x GWS Micro Servos
$150 - Futaba 7C Transmitter
$ 50 - Novak XXTra Receiver
$ 15 - Deans base-load Antenna
$ 20 - Carbon-Fibre main Blades
$988 !
A hell of a big difference from the $240 "Ready to Fly" package.
All I can say in the positive is that the price of the first Walkera Kit I bought was cheap enough for me to think I'll "give it a go" and try one.
Then, the momentary glimpses of successful flight I had in between crashes, wimpy batteries, radio glitches, gutless motors, stripped servo's, unexplained Gyro hiccups, stripped tail drive gears (my first one was a #35) and so on was enough to keep me adding bits one by one until I ended up with a package that works.
3 months later, and I've just completed my 5th 15+ minute flight with no problems.. Finally I'm starting to get somewhere..
Had someone told me it would cost close to $1000 to start, I probably would have skipped it, so maybe there *is* some justification to selling a "cheapy" kit to give people a brief taste of flight and encourage them to get some serious gear a piece at a time.
Hide Signatures
(in reply to Mikey-Flies)
       Post #: 509
RE: Walkera Dragonfly #36 - 10/12/2005 3:44 PM
Tiger27
Score: 100
Last Login: 8/14/2006
Status: offline
Nickgrant, the walkera brushless comes with a pinion as is so I didnt need to change mine, not to hard to fit or remove the old motor, just make sure the screws dont go in to deep in the brushless, as someone else mentioned add another washer, I also made a quick homemade aluminium can heat sink which keeps the motor at a reasonable temp.
Hide Signatures
       Post #: 510
RE: Walkera Dragonfly #36 - 10/12/2005 3:48 PM
Tiger27
Score: 100
Status: offline
Terry B, nice tip on the Aussie supplier the postage is a bit more realistic than the chinese suppliers, I think I may well be contacting them soon
Spokie-tech i noticed the problem you mentioned with the overheating causing shutdown, so I spent a bit of time getting the servo arms to as close to 90 degrees as I could then trimmed it so they dont chatter when at full extension, my rx rarely gets warm now, but I might try removing the cover from the rx and adding a heatsink just in case, some very worthwhile tips from both of you there.
< Message edited by Tiger27 -- 10/12/2005 3:58 PM >
Hide Signatures
(in reply to Tiger27)
       Post #: 511
RE: Walkera Dragonfly #36 - 10/12/2005 6:28 PM
NOZZARCHELI
Score: 100
Status: offline
HI Guys......I think my 36 tail servo is broken.....I know WALKERA electonics are shocking.......but hey.......i turn the tx and the heli on and the servo works fine, then when i takeoff a couple of seconds into the flight the tail servo locks up and the heli goes into a wild spin.....when i power down the servo just chatters and doesn't respond to any input......thing is, when i unplug the battery and then plug it in again the servo works again...i don't know if my gyro is affecting the servo in some way, but this is really annoying....any tips would be apreciated........thanks
MATT.
I may just get a full set of new servo's......that'll cure my problem...
Hide Signatures
       Post #: 512
RE: Walkera Dragonfly #36 - 10/12/2005 7:36 PM
Riverman
Score: 100
Last Login: 8/17/2007
Status: offline
Hello
I've got a brushless lipo Walkera 36 on the way (s/b here by Fri), and I am trying to take in as much as I can from other people's experiences. Unfortunately, my expectations seem to be dropping with every new topic in here. However, I can't send it back and I'm going to need to do the best I can with what I've got. I've come to the conclusion that I will completely strip it down and rebuild it and that even doing an initial 'ground' run on the motors and electronics might be dangerous without having the thing strapped down.
I currently fly a Eflite Blade CP and am thouroughly enjoying it. I am amazed how well it handles the wind when in 'idle up' collective pitch mode. Does the Walkera 36 have any kind of idle up? Anyone know how well it handles the wind?
What kind of climb performance can be expected out of the brushless setup? Has anyone worked out a solution to the hard starts people seem to be encoutering with this motor?
Thanks for all the valuable input everybody!
Hide Signatures
       Post #: 513
RE: Walkera Dragonfly #36 - 10/12/2005 7:51 PM
Mikey-Flies
Score: 100
Status: offline
Picked up a spindle shaft (From the shogun manual I found that is what they call it), a new 6ch receiver, a few misc bolts and nuts (I'm thinking I still don't have any that will fit the aluminum blade grips; they seem to be a slightly off size from what I can find.
I should be setup to give it another go tonight.
I also have some spare servo's sitting around that I could transplany/implant into the heli. I'm thinking that gws pico servo's and hs 50's will be too wimpy though so I'll lilkely go with some 55's I have sitting around.
I'll play with the gyro some more tonight as well and try flicking the lei sure switch for fun (while not flying!)
*** Oh yeah, I also adjusting the upper mixing arm length to give me negative and positive pitch on the blades. I still need to trim this out though and adjust the throws on the servo's but I think this will be a lot easier on the eclipse.
< Message edited by Mikey-Flies -- 10/12/2005 7:52 PM >
Hide Signatures
       Post #: 514
RE: Walkera Dragonfly #36 - 10/12/2005 11:06 PM
NOZZARCHELI
Score: 100
Status: offline
SORRY TO NAG!!!
!HI Guys......I think my 36 tail servo is broken.....I know WALKERA electonics are shocking.......but hey.......i turn the tx and the heli on and the servo works fine, then when i takeoff a couple of seconds into the flight the tail servo locks up and the heli goes into a wild spin.....when i power down the servo just chatters and doesn't respond to any input......thing is, when i unplug the battery and then plug it in again the servo works again...i don't know if my gyro is affecting the servo in some way, but this is really annoying....any tips would be apreciated........thanks
MATT.
Hide Signatures
       Post #: 515
RE: Walkera Dragonfly #36 - 10/13/2005 12:27 AM
Mikey-Flies
Score: 100
Status: offline
It was an ebay purchase. The same heli is listed now but at a little bit higher price. Search for "Walkera brushless metal rotor" with the search descriptions box checked and you should come up with some hits.
The blades do appear to be the same/similar to the trex. I hope they won't be too heavy. I have dremeled the slightly raised edge at the root so they will sit in the grips nicely now.
The lipo was blue (unknown manufacturer) but it was labeled as 2200 mah with a bunch of other markings and whatnought. I'm thinking the battery plugs will have to go fairly soon (they don't look trustworthy). The lipo has functioned fine as has the included charger. The NiMH "charger" seems to have a fixed output of 500 ma ... that can't be good lol. I love the "Unplug the charger if the batteries get hot and wet" comment as well. If the batteries are "wetting" themselves, they are finished imho.
I went with the electron 6 receiver so we will see how that goes.
My motor started WORSE after putting washers in so I'm pretty sure the bolts were rubbing (sort of a power robbing/amp hogging soft start I guess <g> .
Hope to head home soon and play with this some more.
Hide Signatures
       Post #: 516
RE: Walkera Dragonfly #36 - 10/13/2005 12:43 AM
NOZZARCHELI
Score: 100
Status: offline
I KNOW IT'S A BIT OFF TOPIC BUT , I just put my stock motor from my 36 in my FP DF4 it was just in the bag whitch had all my extras in when i got my 36.....well i put it in my DF4 and it actually works......hovers well, loads of power, flight time is only very slightly shorter, BUT for the preformance i don't really care.....cool eh
MATT
Hide Signatures
       Post #: 517
RE: Walkera Dragonfly #36 - 10/13/2005 2:59 AM
millewi
Score: 100
Last Login: 10/22/2006
Status: offline
Have you guys seen this? Un freaking real. Check it out.
http://www.wifi-toys.com/wi-fi.php?a=articles&id=79
Hide Signatures
       Post #: 518
RE: Walkera Dragonfly #36 - 10/13/2005 4:01 AM
Spockie-Tech
Score: 100
Status: offline
Thats a pretty cool video.. Smart arse 9yo's. Young Kids are so bloody good at picking up hand-eye coordination skills.. Its probably just like a real life playstation game to him, and what young kid cant whip their parents on the playstation..
The most awesome flying video I have seen by one of the worlds best pilots (Alan Szabo) is only *marginally* better than that, and Alan is probably in his twenties I'd guess from looking at him. The picture quality is a lot better though.. you can find it here
http://www.augustoheli.com/videostuff/videoarchive/AlanSzabo/Alan_Szabo_Sunday_at_the_Lake.zip
I'd be looking over my shoulder if I were Alan with 9yo's like that coming up behind him..
and if you want more videos than you can handle, the server full of them is here
http://www.augustoheli.com/videostuff/videoarchive/default.asp
Dont let my grumping at the Walkera electronics discourage anyone too much.. they *will* fly if you are aware of their limitations and double check that everything is set up right, and they're probably not a bad way to get started, since you will probably crash a bit to start with regardless of how good a chopper you have, and its better to crash a cheap one than an expensive one..
But you do need to be aware of their limitations and how to work around them or else you will spend your time battling the machine instead of your own lack of skills to start with. Go the brushless, check the assembly, fix any sloppy bits and movement that shouldnt be there. heatsink or air-cool the receiver/esc. make sure the servo's dont bind. Bin the NiMh Charger, demmand a replacement if you get a dud Lipo. etc etc. its all been said in this thread.
@Mikey - If you manage to get a different Rx working with the Walkera Tx, let us know, I tried a Hitec feather with no go, and I've heard others havent managed it either.. I suspect the Walkera Tx uses a non-standard modulation system, but maybe not.
@bknox: the Walkera does have an Idle-Up (or 3D) mode. Its the "N / 1" switch in the top right of the Tx. *Dont* turn it on while you're on the ground.. someone else called it the "Brown trousers switch", since it immediately sends the motor to full power, and it takes a second or to respond when you switch it off again ! The pitch curve (adjusted by the PLT/PZT knobs) is seperate for this switch, allowing you to have a "hover" pitch curve in normal mode, and a wider range 3D curve in "1" mode. Personally I wouldnt go there until I was bored of hovering and could do it with your eyes shut (so to speak).
@nozzarcheli: to check the location of your tail problem, bypass the gyro by plugging the tail servo straight into the receiver ch 4. You probably wont be able to fly it this way, but it will show you if its the servo having brain failure and going to full travel or the gyro telling it to. If you're careful and spin up the power gradually with no wind, you might be able to manually correct for the torque with side rudder and get a lower hover going without the gyro to see if that eliminates the problem.
Once you get servo's jamming up against their stops, the Rx usually overheats and shuts down.. watching the LED on the Gyro (if its plugged in) can give you a clue here. if it starts flashing fast, the power has failed for a moment and the gyro has reset - probably due to Rx overheat. If it flashes slowly, its lost the radio signal. If it stays on solid when the spin happens, its more likely the servo since as far as the gyro is concerned all is well. Not definite though, since the gyro's inputs (power and signal) could still be ok, but its putting out an incorrect output. Another possibility is too high an "extent" setting on the Gyro. This will make the servo jam against its tops and cause the overheat shutdown. Process of elimination..
Hide Signatures
(in reply to millewi)
       Post #: 519
RE: Walkera Dragonfly #36 - 10/13/2005 5:36 AM
Mikey-Flies
Score: 100
Status: offline
Spockie-Tech : Sorry for not being clear. I was meaning to use the electron 6 with my Hitec Eclipse transmitter. I don't know if the failure was rx or tx so I'll eliminate both with one fell swoop.
Update.
With the new receiver installed all the walkera servos are silent! Absolutely no jitter whatsoever. A really interesting observation about the tail servo; with the new receiver it is much quicker in response and just as fast centering but it only centers fast one way. I suspect a mechanical snafu for the other direction (push vs pull to center) and will investigate further). It could still be the gyro but I really suspect the receiver was doing something odd to that channel now. My gyro led still does not light whatsoever. The actual sensor in the gyro is now embedded in foam btw and can't move around the way I had read with the rubber band. At least they *somewhat* fixed that issue.
I had to reverse the pitch servo and will work on the curves etc.
I took a look at my canopy today (briefly) and noticed a missing rubber gromet. It is still sealed in its baggie and I don't think it will be a problem to fit something workable.
I found some small screws that fit about as well as the stripped one in the blade grips (not perfect but perfect enough as the old ones were tapered screws for 2 of them). The metal grips had 2 nice socket head bolts and 2 tapered screws that were stripped so bad they were quite hard to get out.
I've noticed that the two screws holding the paddle center piece work loose really really easily. I'll have to do something about that. Oh well, off to work on the tail binding. And then to play with the gyro some more. BTW, the servo recentered at the same speed with gyro gain at min and at max.
Hide Signatures
(in reply to Spockie-Tech)
       Post #: 520
RE: Walkera Dragonfly #36 - 10/13/2005 7:41 AM
Mikey-Flies
Score: 100
Status: offline
I am starting to wonder about the "blue" batteries a little now too. I haven't had the heli in the air much (a lot of trimming hops) but the basics are just about sorted. The last hop lasted about 30 seconds when the power faded quite quickly. I'm not sure I have the pitch curve set right for the throttle curve and may have had too much pitch so I'm going to adjust it and see. The power would come back after landing for a few seconds but then fade quickly again.
The tail blade screws were working their way quite loose, tightened them again.
The tail response seems super slow, almost feels like I'm fighting the gyro a bit. I've flicked the lei sure (leisure?) switch now to see what effect that has.
I'm now thinking that the slow tail centering is electrical and not mechanical as the tail operates smooth off the servo. It could very well be the gyro :/
It took a bit of tweaking of settings but I now have a bit more roll than previous. I eventually unscrewed the ball on the aileron lever arm and moved it in a hole (this is on the servo side) effectively increasing the lever action. Response was a little better but still feels slow.
I noticed the pitch control has only z bends so there isn't a lot of room for adjustment there. I'm thinking of changing this over to some form of du-bro connector as the zbends have a fair amount of slop.
The abs blades seem to be working well but it will take more time to tell.
I'll try the NiMH cells as well as the lipo over the next few hops. The radio has been great. The tail servo will jitter a bit from the gyro if the heli is moved (once it starts it doesn't stop) but the other servo's seem rock solid now.
Has anyone managed to determine the amp draw with the walkera 3200 bl motor for a normal mode hover? (I'm thinking these blades will change the current requirements a bit but it should still be in the ballpark). This would give me a baseline for battery requirements.
Has anyone tried like 90 wood blades for the shogun on the 36? They were arguably the best upgrade for my hummingbird.
Hide Signatures
       Post #: 521
RE: Walkera Dragonfly #36 - 10/13/2005 9:30 AM
cptsnoopy
Score: 100
Last Login: 8/2/2008
Status: offline
just a quick stab at the walkera electronics...
This is about 7 months after I bought my #35. (please forgive me as I don't think I'll be getting a #36...)
Electronics replaced in this order...
before second flight. 4 new servos. Hitec HS-55's
Heli flew pretty good but still had some serious glitchs...
about a week after replacing the servos, I was given an old futaba digital transmitter so I purchased a GWS receiver and a GWS brushed motor esc and put those in. wow, that made a huge difference! I could change the parameters for throttle, pitch, servo trim, servo limit, d/r, ect.
I flew the heli this way for several months. then one day i got ahead of myself and tried a loop. not a good plan. after replacing a couple of parts the heli was up and flying again. i decided to spend a lot more time right side up before going there again.
the next problem that cropped up was from the motor. no real surprise since it was involved in a crash onto pavement... the motor just did not perform as well as it used too. so instead of getting another brushed motor, i went and purchased an eflite 4200kv motor and a castle creations phoenix-25 esc. about $120 spent. before I had a chance to install the setup i decided to do something about the walkera gyro as noted below. The walkera gyro was going to be the last and only walkera electronic part left on the heli but it got traded in too before I could go fly again.
About a month ago I picked up a used JR 8103 transmitter so I could fly my walkera #45 (ccpm). So, as long as I was using the JR, I decided to trade in the GWS receiver for a Hitec electron 6 and a deans antenna to use on the #35.
I did notice that the gyro was a bit odd. I have several of these walkera gyros and they all act the same. you can turn the heli as fast as you want to the right (counter torque direction) but when you try to turn left it will only allow for slow turn. I tried adjusting the travel to the left but the gyro would sense the increase in rate and just remove the additional left rudder. I got tired of that the other day and decided to just get the good stuff and leave the walkera electronics behind for good. I picked up a gy-401 and a hds-877 digital micro servo, another $170. I finally got the new goodies on the heli yesterday and now it has tons of headspeed and turning left and right are predictable. I use the same amount of stick to get the same amount of turn rate either left or right.
The total bill for the upgraded electronics (including the transmitter) ended up being just a tad over $600. that does not include the lipo batteries or the trition charger.
the walkera helis will for the most part fly with the stock electronics and it is a good way to get started. but, if you want dependable performance you will need to start replacing the electronic parts as soon as your wallet will allow...
< Message edited by cptsnoopy -- 10/13/2005 6:59 PM >
Hide Signatures
       Post #: 522
RE: Walkera Dragonfly #36 - 10/13/2005 9:36 AM
Tiger27
Score: 100
Status: offline
Ive had my 36 with brushless flying with the Align 335, flew very nicely but there too long for a heavy landing and resulted in a blade strike which cracked the cover on them, I will now be cutting them down 10-20mm and they should be fine.
I think the blue batteries are pure luck if they work, mine is awaiting correct disposal and Ive been using the ni-mh until I can get a decent lipo, the ni-mh when charged correctly, ie not with the supplied charger, work well enough for the level of skill Im at, which is a minute or so hover if Im lucky.
Hide Signatures
       Post #: 523
RE: Walkera Dragonfly #36 - 10/13/2005 9:46 AM
Tiger27
Score: 100
Status: offline
cptsnoopy, if you look around the forums the 600 you spent seems to be pretty much the way this hobby is, wether you get the more expensive helis or not, in my mind the main thing is finding out wether it is the right hobby or not at a reasonable starting price, so far Im really enjoying it and will probably, once Ive trashed the walkera, upgrade to a better model with better electronics. To me it seems one of the largest expenses is a decent Tx but I suppose once you get a good one it can be used for more than one model.
I would have never have taken opportunity to give the hobby a go without the enticement of the low priced Walkera, even if in the long run it turns out to be false economy.
Hide Signatures
       Post #: 524
RE: Walkera Dragonfly #36 - 10/13/2005 9:58 AM
Riverman
Score: 100
Status: offline
Hello
"...you will need to start replacing them (the electronics) as soon as your wallet will allow..." I like that quote. Exactly my sentiments.
My coworker purchased a Walkera 36 brushed combo off Ebay and it arrived today. We only had our 30min break to check things out before a quick attempt at flight. Initial oberservations:
-Too much drag in the rotor system. I don't know the source yet (gear mesh, belt tension, bearings etc...)
-Tail rotor servo is horrible. Its one of those yellow "upgraded models". It chatters and sometimes sticks at full deflection!
-Flybar is bent and twisted?! Flybar paddles couldn't be aligned do to only one 'flat' on the flybar for the setscrew. Will analyze later. Probably our hasty omission or something.
-Lipo battery has no balance circuit! This is useless. I imagine it will be flat lined very soon.
-I love the anodized aluminum boom and skids. Looks slick. (had to add some positive comments)
We fired it up at work in the hangar while we were on break and the results were less than encouraging. (Note: Both the NIMH and the lipo were tried after a quick charge)
Despite our best efforts at trimming the pitch of the blades with the pots, the best we could manage was 15sec 2foot off the groud hovers at full throttle. It just seems to bog down when asked for enough pitch to lift the machine. At low or zero pitch the thing screams. The motor is running very hot.
We didn't expect bottle rocket climb performance out of the thing, but this is not a working helicopter as is. My coworker is disassembling the thing tomorrow to check everything and try to milk more performance out of it.
I've got the brushless combo on the way. Can someone give me an idea of how much more(?) power the Walker brushless offers as opposed to the stock brushed motor? Will it fly?
Brett
Hide Signatures
(in reply to cptsnoopy)
       Post #: 525
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
4.203RCU1
