solocarlo -> RE: Walkera Dragonfly #36 (8/6/2005 10:58:37 AM)
The 35,36 & etc have electronic problems to begin with. Normally the radio gitch doesn't occur until your battery has been used for a while. From my obervations, as long as the battery(NiMH or Lipos) is on healthy condition, the radio gitch would less likely to occur, and I don't say it will not occur. When the motor spins up and suddenly it stops on a brand new battery, it tells you your battery is not brand new, your seller ship a used battery as brand new to you. I had this seller from ebay sold me used lipo batteries as brand new ones. When I flew the heli with these batteries I thought they were brand new, the heli could never lift higher than a foot and hovers only a few seconds in the air before dropping back down to the ground and the motor shuts off by itself more than a dozen times. When I informed the seller, his response was, the flight time of the battery heavily depends on the skill of the pilot. After a dozen email exchanges with the seller, he finally confessed that he made a mistake and shipped the batteries from an used battery bin. Can you believe it? The electronics of the walkera 35/36 can help you to sniff out the unhealthy batteries for you which it's not bad after all.
