RE: Walkera Dragonfly #36
Tower Hobbies
Logged in as Guest
Users viewing this topic: Fugitive_Bill
  Printable Version
More Resources on the
Dragonfly 36
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: Walkera Dragonfly #36
    Page: <<   < prev  437 438 [439] 440 441 442 443 444 445 446   next >   >>
    Login
    RE: Walkera Dragonfly #36 - 4/25/2008 11:09:21 PM
    babyhuey
    Status: offline
    Happy to hear it was temporary.
    Right now my 36 is the best flying heli that I own. The Comet is apart to fix a problem in the tail and the Cobra had a failure to launch on the first try to start it. I have to completely dissamble the clutch to repair a slipping problem. Anyway the 36 will fly rings around the Comet right now and if it is a good example of the Trex type of heli then so far I'm not impressed.
    _____________________________
    Tail motors? We don''t need no stinking tail Motors. Walkera 36, Comet , GMP Cobra 50, Kalt Baron Whisper, Koyosho Caliber
    (in reply to Chophop)
           Post #: 10951
    RE: Walkera Dragonfly #36 - 4/28/2008 1:46:12 AM
    babyhuey
    Status: offline
    Well so much for that! Another wind assisted crash! I guess I'll never learn to stay inside when the wind is blowing as the 36 just got blown into a GD tree. Broke the "industructable " blades and the frame mounts for the skids. May have damaged the main gear also.
    I am soooo pissed!
    (in reply to babyhuey)
           Post #: 10952
    RE: Walkera Dragonfly #36 - 4/29/2008 11:09:58 AM
    Rollin Thunder
    Status: offline
    Chop
    Long time
    How about 3500kv and 3200kv motors from Scorpion? You know I love my KA's but also know a good thing when I see it. Would ya post some links to these sized motors? I'm sure I'm not the only one who would like to know. All those who read but don't post on the forums. This site comes up under some Google searches. On several occasions I've searched the net for things related to RC and have clicked and found one of my old post. I think there should be a Walkera 36 hand book web site. It should be a collection of all the best, relevant and concise post describing 36 setup and mods. Maybe include a summary of Lipo safety as the first chapter after the Walkera 36 introduction and tutorial. We need someone to spend the long hours reading and cataloging the most universally useful and relevant posts. Someone (sorry don't remember who) started a site like this but I don't have a link. Maybe it's still up and maintained?
    Take a method and try it. If it fails, admit it frankly, and try another. But by all means, try something.
    F.D.R.
           Post #: 10953
    RE: Walkera Dragonfly #36 - 4/30/2008 2:25:38 AM
    Chophop
    Status: offline
    I was wondering where you were RT. I have been sick and grouchy lately, better today.
    The Scorpion HK2028-28 is excellent for the 36 with a 12t pinion. I'm set up for 2300 rpm at 80% throttle. I got a 22% reduction in current draw, down to about 870mah in 9 minutes of pretty wild sport flying. The motor/esc comes back barely warm and the battery barely above air temp. I can get a little run and just a push of collective and elevator and it's up a hundred feet.
    The JGF 400DF definately torques better, if not for battery voltage sag at the end of the flight, I wouldn't need governor mode for it. The HK2208-28 sags a bit and just doesn't seem to deliver the instant torque the 400DF does. The 400DF averages about 1100 mah in 9 minutes on the same 670g DF36.
    The Scorpion has the delicate motor windings for leads, the 400DF has heavy duty wires. I already broke a Scorp lead when trying to unplug it from the esc to reverse wires.
    Either one is fine for me.
    Well, remember that orange MX400 I crashed on my first day of sickness when my cold made my eyes blur and I lost it ? It's been rehabilitated and is now bright yellow. I sanded and painted it. Factory quality paint job except for two little runs , but they are shrinking. I did the weight, CG , and balance by Bob White's video on Helifreak.com on a pair of Walkera 280mm foam blades and I have them on the MX400 for now. It is smoother than ever, I never did the weight/CG step in balancing, but will always now. I also put a strip of scotch tape along the leading edges to be sure they don't fly apart. My guess is air gets into the seams and blows them up into separating.
    The 36 is still flying ok.
    I decided to put the CP2 belt mod on hold awhile. I need a better gyro, 4 servos, blades, canopy and AR6000 to finish it permanently. I think the MX400 and DF36 are going to be ok. The CP2 is too light for this windy hill top.
    CH
    No stupid comments for now.
    (in reply to Rollin Thunder)
           Post #: 10954
    RE: Walkera Dragonfly #36 - 4/30/2008 2:38:40 AM
    babyhuey
    Status: offline
    Well my 36 is a mess.
    Broke the frame, stripped the main gear, bent the mainshaft and the boom, and destroyed the tail assm.
    It may sit for awhile.
           Post #: 10955
    RE: Walkera Dragonfly #36 - 4/30/2008 5:39:23 AM
    Chophop
    Status: offline
    Sorry BH. That's why I fly all I can,,,, while I can. The world is full of change.
    The foam blades are to keep it flying. I am mad because I can't find the Sonix 288mm CF blades. These are very unique. They have some intricate contour on the tips and also have a sort of trans-sonic profile on the trailing edges. Very quiet and efficient. Not even a hiss and absolutely no buzz except in high G .
    They stopped selling them when the Shogun ran out of wax. X-heli.com has some that appear to be the same but you know how that stuff goes.
    CH
           Post #: 10956
    RE: Walkera Dragonfly #36 - 4/30/2008 7:45:19 AM
    babyhuey
    Status: offline
    Thanks Chop,
    I don't remember seeing those blades but i'll keep an eye out for them. I'll fix the 36 soon but right now I just can't.
    Does anyone here have any experiance with the 35?
           Post #: 10957
    RE: Walkera Dragonfly #36 - 5/6/2008 1:41:23 AM
    drobin
    Status: offline
    What happened?? I haven't seen a post since last Wed.
           Post #: 10958
    RE: Walkera Dragonfly #36 - 5/6/2008 2:25:37 AM
    Chophop
    Status: offline
    I don't know if my griping has been keeping the thread going or slowing. I quit griping and it stopped.
    Well, let me think something to gripe about.
    CH
    (in reply to drobin)
