RE: Walkera Dragonfly #36
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Dragonfly 36
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: Walkera Dragonfly #36
    Page: <<   < prev  444 445 [446] 447 448 449 450 451 452 453   next >   >>
    Login
    RE: Walkera Dragonfly #36 - 7/14/2008 4:05:30 AM
    Chophop
    Status: offline
    I tried that 36 FP but went on to the CP2-BT mod for outside. I think those little palm sized Walkera CP and FP helis are it for indoors. You can get em for around $100.
    The 36 is FINE with 288mm CF blades and metal main grips. It's been a really nice heli with that Scorpion HK2208-28/12t. Lately, I have been prefering the CP2-BT because it is so maneuverable. It is twitchy, tough for a newb.
    I'll look up those blades, but without taking them apart, I really wouldn't know. I have been hit by the Walkera 4 blades several times and they barely broke skin and left a laugh of a welt. A proud little war wound.
    CH
    (in reply to babyhuey)
           Post #: 11126
    RE: Walkera Dragonfly #36 - 7/14/2008 4:27:40 AM
    Chophop
    Status: offline
    Hey, what's this ? Be careful, you might pull a stomach muscle.
    http://www.rcgroups.com/forums/showthread.php?t=889488
    CH
    (in reply to Chophop)
           Post #: 11127
    RE: Walkera Dragonfly #36 - 7/14/2008 5:02:44 AM
    babyhuey
    Status: offline
    LOL Chop,
    Hey just forget about the Quark blades. I found out that they are only like six inches long so it would be like using tail blades on the mains! Oh well I'll keep looking for some indoor blades for my 36.
    The more I fly my 36 the more I love it!
    _____________________________
    Tail motors? We don''t need no stinking tail Motors. Walkera 36, Comet , GMP Cobra 50, Kalt Baron Whisper, Koyosho Caliber
           Post #: 11128
    RE: Walkera Dragonfly #36 - 7/14/2008 6:00:56 AM
    Junkz0r
    Status: offline
    OK then!
    Finally getting my s$%t together and getting some decent parts for my DF36.
    I don't know if i ever mentioned but I bought it 2nd hand off a guy at my work (only crashed once!) and only had a broken blade holder.
    I've bought the C'n'C head/swash combo but that had a stuffed bearing in it and need to get another (I hear parts are always handy).
    I completely stripped and rebuilt the chassis, main gear, tail gear. (might go the C'n'C tail rotor/boom too).
    I bought one of those Scorpion motor's Chopchop mentioned. I have a TowerPro 30amp ESC... is that the wrong choice for this motor Chopchop?
    I Bought 4 of those TowerPro 5g servo's (not TP branded but the same servo's from asia).
    I have new blades, some other various spare parts.. some batteries (mystery lol)...
    AND I'm almost entirely sold on the Spektrum DX6i transmitter/receiver. Here in Australia the DX6i rrp's for under 250 and from all the reading I'm doing it looks like a full featured 6ch transmitter... am I doing it right?
    Cheers and thanks again for all the great info.. It's doing my head in lol!
    Aussie! Aussie! Aussie!
           Post #: 11129
    RE: Walkera Dragonfly #36 - 7/14/2008 11:32:24 PM
    Rollin Thunder
    Status: offline
    You need three 9g servos (2 cyclic, 1 pitch) and one 5g for the tail. Go for the DX I wish I had. Instead I got the Futaba 6exh which is only good for helis.
    Take a method and try it. If it fails, admit it frankly, and try another. But by all means, try something.
    F.D.R.
    (in reply to Junkz0r)
           Post #: 11130
    RE: Walkera Dragonfly #36 - 7/15/2008 12:04:55 AM
    Junkz0r
    Status: offline
    quote:
    ORIGINAL: Rollin Thunder
    Oh I told a fib
    I actually did get 9g servo's not 5g like I thought (these ones)
    Can I use a 9g for the tail? or should I buy a special servo just for the tail.
    Regards,
    Junkz0r
    (in reply to Rollin Thunder)
           Post #: 11131
    RE: Walkera Dragonfly #36 - 7/15/2008 12:21:10 AM
    Chophop
    Status: offline
    I would get an HS-56HB for the tail. VERY reliable. Other servos didn't last more than a few 10's of flights. I have over 400 flights on that tail servo. I found it best to spend a little more on servos and save crash damage costing more than the servos. I use HS-65HB on the cyclic and the HS-56HB on the tail on both the MX400 and 36. I am currently running S-75's on my CP2-BT with my fingers crossed. I have not had good luck with them. I am running an HS-65HB on the CP2 tail and it is doing great.
    But I got a bunch of them (S-75) for $5 ea from HeliProz in flight packs from DX6 systems. People were requesting the DX6 without servos because they stink. I was new and didn't understand I can't afford to buy the cheap junk.
    I just got a set of Futaba S3114 servos for the CP2 cyclic. I fingered some Futaba servos and they seem as low backlash as Hitec. The S3114's are 20g torque, .1 second at 4.8v with a ball bearing PTO (power take off) that weigh 7.5g and are $15.00 . 1 year warranty. Seems too good to be true. We'll see. They are a recent new product.
    I think there are some PE foam blades at Aero-Fever or some HK vendor. They might be softer. I'd say skip the 36 indoors except for a quick test hover. Too big.
    CH
           Post #: 11132
    RE: Walkera Dragonfly #36 - 7/15/2008 12:27:37 AM
    Chophop
    Status: offline
    Oh, the S3114's will need some mod to fit the S-75, HS-55, Esky, NS-05 etc. 9g footprint. They are slightly smaller. It looks like extending the screw hole on out the edge of the tab and a large washer will work. I WILL MAKE EM WORK.
    CH
           Post #: 11133
    RE: Walkera Dragonfly #36 - 7/15/2008 12:32:55 AM
    Rollin Thunder
    Status:
