babyhuey
Joined: 9/3/2007 From: St. James, MO, USA Status: offline
quote:
ORIGINAL: Chophop The S3114's went out today. I couldn't reach Servo City on the phone and got scared they were one of those problem vendors. I guess not. Osterizer on RCG says S3114 servos are about as good as an HS-56HB but not quite. To me that means they are ok but not as good as an HS-56HB. Still hard to imagine a $15 servo as good as a $25 servo. This might be the result of some new production technique or maybe a marketing plan to gain happy customers. Any way, I just hope they are good. I really should have just gotten another set of HS-65HB's so I could simply move them to another heli if needed. 3 S3114's weigh 22.5g . 3 HS-65HB's weigh 34.5g . I save 12g with the S3114's. And the S-75's are 27g for 3, so again I save ~5g with the S3114's. On the smaller Cp2-BT, 12g is a good loss. One problem I have with it is it lifts of with the pitch so small that it easily flips around between zero and the tiny bit the CP2-BT needs to fly. I get some yoyo intermittantly. So I hope the tighter Futaba servos will correct that slop error the S-75's have. CH Chop, Your gonna like the 3114s. I have one on the tail of my 36 and it works very well, Fast , strong and centers well. The only thing is that they have the wimpyist servo arms you have ever seen. They also have smaller mounting dimensions which you are already aware of. With a better arm they would be one of the best small servos available. Huey
_____________________________
Tail motors? We don''t need no stinking tail Motors. Walkera 36, Comet , GMP Cobra 50, Kalt Baron Whisper, Koyosho Caliber
