Junkz0r
Joined: 6/25/2008 From: Melbourne, AUSTRALIA Status: offline
quote:
ORIGINAL: Chophop I just checked my tally on the 2nd DF36, and I have 620 flights on the cheap piece of junk that seems to keep on flying. Cheap junk as some say ? I wore out 2 and working on my 3rd main gear, plus some head links and balls, most have been converted to Align Stainless steel balls/links long ago. It's the main blade grip to mixing arm link that wore out a few flights ago. I got 620 flights out of that link set. I previously wore out the pitch rod blocks in 60 flights or so, but since polishing the shaft slot, I have 500 or so flights on this one. Oh, and I did find and replace a worn set of tail shaft bearings about a week ago. NO COMPLAINTS ! CH Hi Chopchop When you say 'pitch rod blocks' and polishing the shaft slot, can you show me which part you are referring to? Cheers
_____________________________
Aussie! Aussie! Aussie!
