RE: Walkera Dragonfly #36
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Dragonfly 36
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: Walkera Dragonfly #36
    Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
    Login
    RE: Walkera Dragonfly #36 - 8/9/2005 12:48:47 AM
    sparkling_fist
    Status: offline
    hmm..
    if i throw it away..
    i will only have the ni-mh battery..
    will an rc-smart brushless 4980 motor with actiyator work on my #36?
    ps.. (100th post)!
    < Message edited by sparkling_fist -- 8/9/2005 12:49:10 AM >
    _____________________________
    Barbarian for life.
    Stuff happens then you die.
    (in reply to cptsnoopy)
           Post #: 101
    RE: Walkera Dragonfly #36 - 8/9/2005 12:22:37 PM
    sh
    Status: offline
    hello all,
    just wondering what time of swash this helli has, is it a 90 degree or a 120 degree swash.
    thanks
    (in reply to sparkling_fist)
           Post #: 102
    RE: Walkera Dragonfly #36 - 8/10/2005 1:48:15 AM
    aurora799
    Status: offline
    It's configured for 90 degree, although the swash plate has the ball links for 120 degree also.
    (in reply to sh)
           Post #: 103
    RE: Walkera Dragonfly #36 - 8/11/2005 12:16:02 AM
    phillip0101
    Status: offline
    Hi!
    Right, in getting all excited about helicopters since my dad got a really cheap one which hardly flys, but still its good fun. I have been hearing all bad things about walkera helicopters and im not sure what to do, i really like the look of the walkera dragonfly 36 with brushless motor which seems very good value and just within my small budget.
    I know that the walkera 35 is supposed to be total rubbish (apparently), but is it worth risking it and buying a 36? or is is going to be more trouble than its worth?
    can someone give me some help as i cant make a decision and its starting to drive me crazy, lol, keep reading and reading everything on the internet and just cant decide what to do
    Thanks, hope someone can help
           Post #: 104
    RE: Walkera Dragonfly #36 - 8/11/2005 12:47:17 AM
    sparkling_fist
    Status: offline
    most #36 dont even fly for over a min..
    mine reached 2 inches once and doesnt take off..
    i donno if its the batteries or the heli itself..
    the best thing u can do is buy a t-rex..
    they seem to be the best so far..(from what ive heard)
    Barbarian for life.
    (in reply to phillip0101)
           Post #: 105
    RE: Walkera Dragonfly #36 - 8/11/2005 1:15:07 AM
    stoogy
    Status: offline
    I had the same problem with my #36 I just ordered a new Li-poly 11v 2200mah and a new charger and this thing now flies!
           Post #: 106
    RE: Walkera Dragonfly #36 - 8/11/2005 2:34:39 AM
    imaginit
    Status: offline
    Hi Stoogy,
    Tnx for the info on dip switches...Now I got my new brushless motor..it is a carbon fiber casing 3200kv from rc-expert...the pinion exactly matched the main gear,,,,and IT WORKS... the original motor is really shorted..it made my esc and battery damaged...I am now working on the adjustments...I find it hard to adjust the tail rotor...it keeps on rotating clockwise when it reaches not more than 6 inches off the ground......
    (in reply to stoogy)
           Post #: 107
    RE: Walkera Dragonfly #36 - 8/11/2005 5:14:55 AM
    aurora799
    Status: offline
    Unless you have actually tried flying every #36 that exists, don't make such broad judgments on them!
    If yours reached only 2 inches you probably have not configured it properly. Don't expect the Heli to fly perfect straight out of the box.
    When properly configured (with only stock parts, brushed motor, and standard NIMH battery) I can get my #36 to hover for about 4 minutes.
    Having said that I would recommend using LiPos & a good charger though, for more power and run time (around 10 minutes).
    I have 2x Walkera supplied 1500mah 11.1V LiPos and they have worked fine for me so far.
    Phillip0101 - The #36 is much like the #35 but with a belt drive tail that overcomes the main problem with the #35. The motor and Rx are in different positions on the #36 too. My #36 has been good value so far, but you need to be patient and have a bit of knowledge to make sure it is setup right. I will gradually upgrade my elecronics, but it works fine for now.
    < Message edited by aurora799 -- 8/11/2005 5:21:44 AM >
           Post #: 108
    RE: Walkera Dragonfly #36 - 8/11/2005 6:25:07 PM
    sparkling_fist
    Status: offline
    er i got 2200 mah 11.1 li-po..
    it swells and dsnts give half the power my ni-mh does.
    quote:
    "When properly configured"
    er.. how do you suggest i do that?
    Barbarian for life.
    (in reply to aurora799)
           Post #: 109
    RE: Walkera Dragonfly #36 - 8/11/2005 6:30:36 PM
