CitYbYdBaY
CA, USA Status: offline
Hello, Newbee here, just want to thank RC UNIVERSE for having a online forums. Otherwise I wouldn't know where else to go for help on my dragonfly #36. I just bought a dragonfly #36 heli with the 2200 li-po batter, 30A ESC and Brushless Motor. I got it to fly for a few seconds and it flew into the wall damaging the main foam blades. I found out that the signal between the reciever and radio controller was lost. Now here is the wierd part, if I walk about five feet away from the heli even with the antenna on the raido fully extended, I lost signal with the heli, and the gyro LED light just blinks until I get closer, that is where the heli makes a beeping sound and I have signal again. And also even if I stay close by to the heli, when I try to fly it again right before 50% of throttle I lose signal with the heli and the LED light on the Gyro blinks and then it resets again by making a beeping sound. Does anybody know what could be the problem I'm having? I'm guessing that it's the reciver causing the problem. Also what part of the heli is making that beeping sound? I brought it to a hobby shop and they told me it could be the radio controller, the crystals, the reciever, the 30A ESC, or the Brushless motor. They told me to send it back to the guy I bought it from so they can see what's wrong and replace whatever I need. The guy at the hobby shop also said that the helicopter blades spin up too fast when he slowly gives the controller a little throttle. He said it shouldn't do that, it should start up slow and smooth. Is that true about the blades starting up slow and smooth when the throttle is moved up a little and slowly? So does that mean the ESC is faulty? I just sent all the electronics back to the seller like the radio, reciever, gyro, ESC and motor. He said that he will test them out and replace the bad parts and send them back to me. Any feedback is greatly appreciated. Thank you!
