jascamera
I had a walkera 36 try putting a heat sink, even a home made from a coke can. The reduce heat from the motor will cause less glitches. Also when you hold the heli, it's making that glith noise it should be the gyro is telling the servo to adjustment, but I can be wrong. Mine are doing that, but I know it's only the tail servo that's moving. Check and see if it's only the tail servo that's making all the noise, if so you have no worries, your gyro is working. Then, I would highly reccomend that the first 50 flight you should never lifted above 6 inches. You have to find out what tendency that the heli have. Is it leaning left, or right and etc. You have the correct all these tendencies and have it hover in the same spot. Then you can hover a feet and higher and higher. Be patient.
