RE: *Super Tigre G-2300 Question*
Tower Hobbies
Logged in as Guest
  Printable Version
Enya R120GP
Seller:  Hobbsy
Details:   $325.00   |  10/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: *Super Tigre G-2300 Question*
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: *Super Tigre G-2300 Question* - 7/19/2005 4:39:33 PM
seanychen
Status: offline
My ST G2300 w/ Bisson Pitts muffler turns APC 18x6W @ 8500 RPM, on 5% nitro or 15% nitro, no difference.
It's about 500 rpm weaker than OS 160 FX, and 500 rpm stronger than Saito 150, about the same as Saito 180 on 15% nitro.
_____________________________
E_Total = M*G*H + 1/2 M*V^2
When H=0, all of airplane's velocity becomes crash energy!
(in reply to SunShyne)
       Post #: 26
RE: *Super Tigre G-2300 Question* - 7/19/2005 5:35:38 PM
RobertC
Status: offline
Wow, for an engine that is half the price of the 1.60FX that sounds pretty good! I look forward to my own trials...
So, nobody else has needed (tried?) to extend the needle on this (or other ST) engine? I thought I would get a million responses of "obvious" answers!
(in reply to seanychen)
       Post #: 27
RE: *Super Tigre G-2300 Question* - 7/20/2005 3:13:20 AM
Cyclic Hardover
Status: offline
I went down that road on a 3250 with carb switching a few years ago. It did solve all the problems but right now, my 2300 has about 20ish flights on it and I have no problems at all other than the machining thing but the performance is still very good. Good all around engine. You can prop it for speed, 3d or general sport flying.
Retired Army Aviator - Excuse Me! You sold me a hair with a cake around it!
(in reply to RobertC)
       Post #: 28
RE: *Super Tigre G-2300 Question* - 7/20/2005 4:54:23 PM
pe reivers
Status: online
Once set, you forget what those needles look like.
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl
There is sanctuary in analisys.
       Post #: 29
RE: *Super Tigre G-2300 Question* - 8/8/2005 9:04:22 AM
marioa_qg
Status: offline
Well Ive have always wanted an overpowered warbird....the new h9 P-47 is comming out and ive been thincknig of buying it......i just ordered a 2300 for it. The pro is probbably going to touch the ground so ive been thinking in a 3 bladed one. Which do you sujest?
       Post #: 30
RE: *Super Tigre G-2300 Question* - 8/8/2005 7:02:00 PM
zx32tt
Status: offline
I'm running a 18-6w APC on my Goldberg Sukhoi. I've got a little over 1 gallon thru it, and it runs excellent. I'm using a Bison Pitts muffler with a Perry pump. The carb is very easy to tune, and I've had no problems at all. For the money, you can't beat this engine.
Z
(in reply to marioa_qg)
       Post #: 31
RE: *Super Tigre G-2300 Question* - 8/8/2005 7:33:58 PM
ICE_MAN
Status: offline
I'm turning 9100 With the Mej 18X6 Prop.. Turned about 87-8800 On both the MenzS and APC 18X6's...
People in my Area with O.S. 1.60's and Pipes are turning Modified MA Props at arroun 85-8700.
ICE
(in reply to zx32tt)
       Post #: 32
RE: *Super Tigre G-2300 Question* - 8/8/2005 8:28:57 PM
seanychen
Status: offline
quote:
ORIGINAL: marioa_qg
For the P-47, I'd say use a 4-bladed prop, just like the real thing. Bolly makes a 15.5 x 12W 4-blade that the ST 2300 may just swing it (near its upper-end load)
       Post #: 33
RE: *Super Tigre G-2300 Question* - 8/8/2005 9:17:17 PM
ICE_MAN
Status: offline
Is The Bolly wood?
Try to find a black prop.. CF would be awesome.. Have no clue on sizes though.. I'm swingin 18X6 2 blade if that helps
ICE
       Post #: 34
RE: *Super Tigre G-2300 Question* - 8/8/2005 10:02:48 PM
seanychen
Status: offline
Carbon Fiber, black, correction: 15.5 x 12.5 4-blade
I think it's like $67
(in reply to ICE_MAN)
       Post #: 35
RE: *Super Tigre G-2300 Question* - 8/9/2005 12:09:31 AM
marioa_qg
Status: offline
my wallet is going to hurt if it tuches the ground...
       Post #: 36
RE: *Super Tigre G-2300 Question* - 8/9/2005 12:25:20 AM
marioa_qg
Status: offline
well i just didi a little reasearch and gound an APC 14.5 * 11, will the 2300 run it smoothely?
Click to see fullsize image.
Click for fullsize
       Post #: 37
RE: *Super Tigre G-2300 Question* - 8/9/2005 1:55:56 AM
ICE_MAN
Status: offline
1.) It's CF It will stand up to more than wood and Nylon.... I'vee seen some planes go in from high and the CF prop be unscathed.
2.) APC's are heavy and the engine will not spool up as fast as it's capable of.
You'll like the CF better
ICE
       Post #: 38
RE: *Super Tigre G-2300 Question* - 8/9/2005 1:22:42 PM
mrbigg
Status: online
Graupner-(spelling is off, maybe) sells some 3 blades that look good. don't know about the 4 blades.
check out the RCU Review of the Hangar 9 Corsair (electric). It's got one of these and it's the best looking 3 blade i've seen that is reasonably priced.
2 months ago i picked up a 2300 for a TopFlite 60 sized corsair. Probaly won't be done 'til spring.
PROVERBS 15:22 - Plans go wrong for lack of advice; many counselors bring success.
       Post #: 39
RE: *Super Tigre G-2300 Question* - 8/9/2005 8:38:46 PM
ICE_MAN
Status: offline
Mr. Bigg,
Have you fired up your ST yet?
marioa_qg
I had an APC 18X6W on my 1.40... While it spun good rpms and idled real low.. It wouldn't spool up as fast as this engine is capable of.. I for one would really advise against APC props for any 2 stroke bigger than about 1.0 CI.. Also I believe I heard some talk of the bigger APC's being weak and after so many hours getting stress lines (white makrs caused by stress) and the people were having to replace them... A 2 Blad wood prop would be good.. but wouldn't look good at all... The CF prop is a piece of art.. Runs good and is also a more effcient airfoil. I think one would look awesome on that P-47! I've attached a couple pics of Mej. to show you. The Ultra Stick is mine and the 40%er belongs to the SHowme Airkings
Click for fullsize
Click for fullsize
Click for fullsize
ICE
(in reply to mrbigg)
       Post #: 40
RE: *Super Tigre G-2300 Question* - 8/9/2005 9:39:19 PM
mrbigg
