pe reivers
Joined: 1/23/2002 From: Arcen, , NETHERLANDS Status: online
ST learned how to make a big glow engine work, long before OS did. OS makes the better carb for it. The OS 7D with midrange mixture adjustment paired to the ST2300 engine is about the best combo you will ever find. An 18x8 prop, or similar propload will do just fine with 5-10% fuel. This engine can rev up to 12000, but behaves just at well at 7000.
_____________________________
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl There is sanctuary in analisys.
