RE: The Jacknife-new mega jet out of S.Texas
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Boomerang Jets Intro - RTF
Seller:  Dumb Thumb
Details:   $2,900.00   |  11/1/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: The Jacknife-new mega jet out of S.Texas
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: The Jacknife-new mega jet out of S.Texas - 7/19/2005 4:27 PM
patf
Score: 100
Last Login: 11/6/2009
Status: offline
jack
pm me with an addy and i can send you the other 50 or so shots in full res on a cd...
pat
_____________________________
Patrick Fernandez
Hide Signatures
(in reply to Jack Holland)
       Post #: 26
RE: The Jacknife-new mega jet out of S.Texas - 7/19/2005 5:05 PM
-JC-
Score: 104
Last Login: 11/7/2009
Status: offline
Looks great Jack.
When can you announce the price and delivery?
John C
Hide Signatures
       Post #: 27
RE: The Jacknife-new mega jet out of S.Texas - 7/19/2005 11:48 PM
wojtek
Score: 100
Last Login: 6/13/2008
Status: offline
heres some VIDEO of the Jacknife from MAB ....
http://www.voy-tech.net/Videos/JackHolland.wmv
sweet !!!
Wojtek
Nothing can ever be fast enough !!!
Hide Signatures
(in reply to -JC-)
       Post #: 28
RE: The Jacknife-new mega jet out of S.Texas - 7/20/2005 12:54 AM
matten
Score: 100
Status: offline
I have seen this Jet in Jack Holland house in primer wile visiting him with my friend Pedro few monts ago, this Jet is BIG, BIG ,BIG and from what I saw in the video fly very , very well.
Congratulations Jack!
Best Regards,
Richard Mattenberger
Richard Mattenberge
Hide Signatures
(in reply to wojtek)
       Post #: 29
RE: The Jacknife-new mega jet out of S.Texas - 7/20/2005 7:54 AM
hornet driver
Score: 100
Last Login: 6/13/2009
Status: offline
jack
she did fly great as we all thought during the design and construction phase
and what a great name that is so fitting for it ...(half your name and half wind-cutter)...much better than excaliber :-)
gregg
YOU DONT GET PAID TO FLY....YOU GET PAID TO LAND!!!
Hide Signatures
(in reply to matten)
       Post #: 30
RE: The Jacknife-new mega jet out of S.Texas - 7/20/2005 9:56 PM
helipad
Score: 100
Last Login: 6/29/2008
Status: offline
Hey Jack
Three hundred paces is wrong you were so excited you got your numbers mixed up it was a hundred paces (300 feet) that day when we test flew it. In approximately half that length it was already off the ground with full flaps down. I hope that we get to go to Waco to fly it there.
Rudy
Hide Signatures
(in reply to hornet driver)
       Post #: 31
RE: The Jacknife-new mega jet out of S.Texas - 7/20/2005 10:07 PM
hornet driver
Score: 100
Status: offline
jack
rudy is right it was a 100 yards....after 21 years of football i know exactly how far that is...cant tell how many sprints of that length i have done over the years :-)
gregg
Hide Signatures
(in reply to helipad)
       Post #: 32
RE: The Jacknife-new mega jet out of S.Texas - 7/20/2005 10:40 PM
SDCrashmaster
Score: 110
Status: offline
In the video, it was so fast that the sound couln't even keep up with it.
I think there was an audio sync issue.
Paul
Yeah, I use mixing... Balsa & Dirt. ©
Hide Signatures
       Post #: 33
RE: The Jacknife-new mega jet out of S.Texas - 7/20/2005 11:23 PM
flycatch
Score: 100
Last Login: 11/5/2009
Status: offline
Very impressive design. The video was outstanding and so was the pilot. You have provided a remarkable "Made in USA" product. I have a two questions on your design.
1. What influenced you to use an anhedreal horizontal stablizer?
2. Could it be possible to turn this platform into a UAV by doubling
its' size.
Hide Signatures
       Post #: 34
RE: The Jacknife-new mega jet out of S.Texas - 7/20/2005 11:45 PM
Jack Holland
Score: 100
Last Login: 9/11/2009
Status: offline
Hi Pat,
Here is the info:
Jack Holland
Rt.2 Box 130A
Mile 2 East & Bus.83
Mercedes,Texas 78570
Great pics!!
Jack
Hide Signatures
(in reply to flycatch)
       Post #: 35
RE: The Jacknife-new mega jet out of S.Texas - 7/21/2005 12:49 AM
Jack Holland
Score: 100
Status: offline
Hello to everyone inquiring about the Jacknife. Let me start here. The Jacknife is currently offered as completely molded aircraft, except for the wing. The wing is foam cored, balsa sheeted, glassed like what were all use to. It works, it's easy to repair any minor dings if needed, and cheaper to replace for the consumer if the event of something unfortunate. I will be offering the Jacknife for now as a TRUE RTF custom built jet. It will be completely built , with JR-8611's on the flight controls, all JR high end servos for the other functions. No micros in this jet anywhere. It will be on it's gear, hinged, horned, and hooked up. The fuel cells are installed and plumbed with lines run forward to pump location. Air system, gear doors, etc will all be installed. The radio and accessory tray, with air gauges (2) 1 for gear, one for brakes-separate systems. I currently have AMT and JET-cat bypass/tailpipe which buyer will have a choice of. Currently with the cure time in between lay up and vac-bag stages, It takes me 3 days to do the whole tail feather section, and 2-3 days for a fuse and hatch. Clear canopy is and included. All the gear is mounted low enough in the hatch area to allow for a full cockpit and "blue box" type pilot figure...not included. $7500.00 ARF built, on it's gear, hinged, base white paint-less servo pack, $8500.00 base white paint RTF w/full servo pack( your choice JR or Fut digital) $10,500.00 RTF 3 color sport paint . Exotic paint available. The RTF versions will be rigged with your turbine, TX/RX. and battery system. I will install your turbine and CG it for you. Add fuel,air, charge and fly...a true RTF. Call 956-565-1584 for more info after 5:30 PM Mon-Fri
Hide Signatures
       Post #: 36
RE: The Jacknife-new mega jet out of S.Texas - 7/21/2005 2:06 AM
helipad
Score: 100
Status: offline
Here a picture of Jack and his jet. You can see the size of it with out the pig sticker.
Rudy
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 37
RE: The Jacknife-new mega jet out of S.Texas - 7/21/2005 2:27 AM
Details 4 Scale
Score: 100
Last Login: 11/8/2009
Status: offline
Jack,
Does it come with it's own trailer? LOL. I mean, come on. Congrats man, what a beautiful jet.
I finally saw the video. Very impressive. Glad to see the project completed, your way...Nice to see that Kero-smile on your face again.
Dano
Dan Gill
website: www.details4scale.com
e-mail:support@details4scale.com
Authorized Skymaster Dealer
Hide Signatures
       Post #: 38
RE: The Jacknife-new mega jet out of S.Texas - 7/21/2005 2:33 AM
Justanotherjetguy
Score: 100
Last Login: 6/24/2009
Status: offline
Nice airplane. Just wondering how many people we will see posting 6 months from now looking for Jack?
Hide Signatures
(in reply to Details 4 Scale)
       Post #: 39
RE: The Jacknife-new mega jet out of S.Texas - 7/21/2005 4:37 AM
Lownverted
Score: 100
Last Login: 9/5/2009
Status: offline
Whats that supposed to mean?
Red
Mach 3 with my hair on fire!
Hide Signatures
(in reply to Justanotherjetguy)
       Post #: 40
RE: The Jacknife-new mega jet out of S.Texas - 7/21/2005 4:52 AM
Joe C
Score: 100
Status: offline
Jack,
Great looking jet, best of luck. Joe Castelao
Hide Signatures
(in reply to Lownverted)
       Post #: 41
RE: The Jacknife-new mega jet out of S.Texas - 7/21/2005 1:09 PM
GlennisAircraft
Score: 100
Status: offline
All of us serious jet guys know Jack has been around for a long time.
Dennis
Hide Signatures
(in reply to Joe C)
       Post #: 42
RE: The Jacknife-new mega jet out of S.Texas - 7/21/2005 2:28 PM
FalconWings
Score: 100
Status: offline
quote:
ORIGINAL: GlennisAircraft
Dennis
Very elegantly said.
I do argue with idiots and let them win on purpose.
Hide Signatures
(in reply to GlennisAircraft)
       Post #: 43
RE: The Jacknife-new mega jet out of S.Texas - 7/21/2005 7:12 PM
Jack Holland
Score: 100
Status: offline
Thanks Joe,
You'll be seeing a Jacknife out on the West Coast real soon...in Exotic colors. As for the guy in BFE, have the "nads" to put your name on your post where the jet world can put a face to your comments. I have been building jets for a living full time for 10 years, and been in Rc for 30 years. During these ten years, I have moved around South Texas looking for the best spot to operate and keep my family happy. I have tried other lines of work, never stopping the jet building, only slowing down on the build times. The customers I had during these times may have been dissappointed with the time frame...BUT never the product, except maybe for an L-39. The point is "the real jet guys" who know me, can always reach me. PERIOD! When I am ready to accept Jacknife orders, I will have a order line wireless set-up strapped to my A$$ and will be available during normal business hours for calls and questions. BFE..make sure I get your email so I can send you my number
Hide Signatures
(in reply to FalconWings)
       Post #: 44
RE: The Jacknife-new mega jet out of S.Texas - 7/21/2005 7:44 PM
Tom Antlfinger
Score: 100
Status: offline
Jacknife Jack---------
Old Senor Blowhard couldn't have said it more concisely......
T.....
Hide Signatures
       Post #: 45
RE: The Jacknife-new mega jet out of S.Texas - 7/24/2005 1:53 AM
hornet driver
Score: 100
Status: offline
jack
amen
hornetdriver
Hide Signatures
(in reply to Tom Antlfinger)
       Post #: 46
RE: The Jacknife-new mega jet out of S.Texas - 7/25/2005 11:35 PM
Jack Holland
Score: 100
Status: offline
Hi everyone,
Just checking in to let you know that the 1st production Jacknife parts are almost complete. The fuse will be done and out of the mold here shortly. I will post a pic of all the composite parts when their done. Looking good. A phone line should be in here shortly within a day or two. Thanks to everyone emailing. I really appreciate the support and excitement over the Jacknife.
Jack Holland genesisjets@juno.com
956-565-9347
< Message edited by Jack Holland -- 7/30/2005 4:11 PM >
Hide Signatures
       Post #: 47
RE: The Jacknife-new mega jet out of S.Texas - 8/6/2005 7:22 PM
Jack Holland
Score: 100
Status: offline
News release!! After numerous requests from you..the jet builders, I have decided to offer the Jacknife in a kit form. Here is what you will get.
All molded parts (the fuse, hatch, tail feathers, elevators, and rudder (pre-balanced), a fuel tank system, bypass) and a tailpipe. I will include a hardware package for all the heavy duty linkage hook-ups (elevator, rudder, aileron, flaps)... these are carbon fiber shafts with titanium ends. Tanks are pre-built and pressure checked w/BVM hardware. The formers are installed in the fuse for you. The canopy hatch is done for you. A clear canopy is included. You will have minor cosmetics to do on the pre-primed parts. A pre-sheeted foam cored wing is included. Flap pockets (split flaps) are done for you, and molded flaps are included. The ailerons are also cut out and capped for you. The instruction manual will guide you through this VERY easy assembly process with a few photos to help along the way. No gyros needed. If you have built ANY other jets before, you will enjoy this "walk through the park" process. This jet was designed for Robart 635 retracts. They may be purchased directly from Robart or if you have JMP Firebird gear, use them...as this jet was designed to accept them with ease also. Kit price as listed is $3800.00 and does not include shipping. A deposit is required to reserve a Jacknife and balance is due prior to shipment. Bypass for AMT, or Jetcat available. The jet is an all epoxy lay-up, with contest grade balsa or ply used throughout. The guide for this design throughout the tooling and design phase was "it has to WITHSTAND the AMT Olympus" I invite you to call with more questions or to place your order 956-565-9347 God bless!
Hide Signatures
       Post #: 48
RE: The Jacknife-new mega jet out of S.Texas - 8/7/2005 2:13 AM
bcovish
Score: 111
Status: offline
Jack
Are you gonna bring it to the Southwest?
Bob-O
Austin TX
Hide Signatures
       Post #: 49
RE: The Jacknife-new mega jet out of S.Texas - 8/7/2005 6:30 PM
Jack Holland
Score: 100
Status: offline
Hi Bob,
I will know for sure after this upcoming week. I plan on being there.
Hide Signatures
(in reply to bcovish)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.656RCU1
