Worldmodels Ultimate 40S
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Sport Flying >> Worldmodels Ultimate 40S
Page: [1]
Login
Worldmodels Ultimate 40S - 7/18/2005 5:38:43 PM
thevirginian
Status: offline
Hi, everyone;
I just got me an Ultimate 40S from Worldmodels. A buddy of mine flies one with a Saito 56. Flies great but could use a bit more power in vertical. So I decided to put my Saito 72 in it. At the LHS I was told I should have unlimited vertical with that engine. W'll see. Anybody here with the same palne? One thing I don't like too much: Only one servo for four ailerons. On the other hand, the ailerons are small. Overall quality is good, built very beefy, not necessarily the lightest plane in its class. Any input is appreciated!
       Post #: 1
RE: Worldmodels Ultimate 40S - 7/18/2005 7:38:01 PM
bhole74
Status: offline
A buddy of mine just put one together and we maidened it Thursday night. He installed a Saito 82, heck with the manufacturers warnings, and it had plenty of power. Thottle management is a MUST! It doesn't like to pull a loop because engine torque rolls the plane hard left if you give it any throttle at all and low rate aileron is not enough to correct it. I did a snap roll with it and the hs-81 broke a gear but I was able to get it down ok. Metal Gear servos would be highly recommended if using the 81s or similar.
_____________________________
Had I known that flight was going to cost me $100 per second, I wouldn't have flown 30 seconds!
(in reply to thevirginian)
       Post #: 2
RE: Worldmodels Ultimate 40S - 7/19/2005 12:41:24 PM
thevirginian
Status: offline
Hey, bhole;
Where did your buddy use the HS81?
(in reply to bhole74)
       Post #: 3
RE: Worldmodels Ultimate 40S - 7/19/2005 1:55:37 PM
bhole74
Status: offline
Ailerons.
       Post #: 4
RE: Worldmodels Ultimate 40S - 7/19/2005 6:50:51 PM
thevirginian
Status: offline
I reckon he used two of them, one for each pair of ailerons.
       Post #: 5
RE: Worldmodels Ultimate 40S - 7/19/2005 11:10:21 PM
bhole74
Status: offline
I'm not sure, but I believe he said it only uses one servo for the ailerons. I personally would have used two.
       Post #: 6
RE: Worldmodels Ultimate 40S - 8/8/2005 1:08:47 AM
planetwister
Status: offline
sounds like a good flyin plane Im ordering one tommorow, going to put an 0.S 46 AX, If thats not enough power I will probably put a saito 91 in it the 46 should be enough.
Team losi 8IGHT- O.S VZB V-Spec- Futaba 9351''s-Spektrum DX2.0
       Post #: 7
RE: Worldmodels Ultimate 40S - 8/8/2005 5:26:00 PM
thevirginian
Status: offline
Hey, planetwister;
A Saito 91 is way too much power and weight up front for this plane. The max. engine size is a Saito 72, believe me. Don't go overboard with redundant motor power. The 72 gives you unlimited vertical.
(in reply to planetwister)
       Post #: 8
RE: Worldmodels Ultimate 40S - 8/31/2005 7:06:15 PM
pcm1024
Status: offline
JUST ORDERED MINE. iT SHOULD BE A GREAT FIT FOR MY YS 63.
AND BY THE WAY WHY WOULD ANYONE USE HS-81 SERVOS FOR CONTROL SURFACE IN A 40 SIZE MODEL?
TO EACH IS OWN I GUESS
       Post #: 9
RE: Worldmodels Ultimate 40S - 9/8/2005 4:38:47 AM
BULL-RCU
Status: offline
My bud just baught this plane. he is planing on putting a Magmum 52 in it. He has a saito 72 just sitting around. Is yours still together or did you rip it up with the saito 72?
Visit my WEB Site www.nobullsales.com Check out my gallery!
(in reply to pcm1024)
       Post #: 10
RE: Worldmodels Ultimate 40S - 7/11/2006 9:38:03 AM
derbydog
Status: offline
i just want to know how it flys
(in reply to BULL-RCU)
       Post #: 11
RE: Worldmodels Ultimate 40S - 7/11/2006 9:41:54 AM
derbydog
Status: offline
at low speeds
i am only 14 but flying for 9 years looking for a update from my uproar dos it like to stall how fast are rols. i herd it was like a 40 size 3-d is it and would a 40 have enuf power to huver
(in reply to derbydog)
       Post #: 12
RE: Worldmodels Ultimate 40S - 7/27/2006 12:53:45 AM
richardshakan
Status: offline
I'm new to this addiction. I Have an almost done 40S w/saito 72. From all reviews read, this plane should be excellent to fly. I have found 2 reviews that point out CG differences compared to the manuals 3.74. One review states 3 inches from upper wing tip, another says 3.2. I also have a shuttle 30/50 evolution-37 OS-GY401/S9254,JR770PCM. T-REX-XL w/many upgrades.
The planes just looks awesome with True turn polished spinner.
       Post #: 13
RE: Worldmodels Ultimate 40S - 7/29/2006 7:59:16 PM
Stubshaft
Status: offline
Mine flies great with a Magnum .52 RFS in front.
If the Professor can make a battery out of a coconut. Why can''''''''''''''''t he fix a hole in the boat?
(in reply to richardshakan)
       Post #: 14
RE: Worldmodels Ultimate 40S - 9/6/2006 2:17:48 AM
tdrnmartin
Status: offline
I had (yes had) an ultimate 40s that had a Saito 72. It flew well under power. It was on the heavy side at 5 pounds, 7 ounces dry. The heavies was due to my over use of epoxy. Be very sure of how much time the included ~9 ounce fuel tank will provide with a larger engine. Also be sure to keep the plane as light as possible to help out your glide in a dead stick landing.
       Post #: 15
RE: Worldmodels U
