RCP57
TX, USA Status: offline
Well the charger arrived today. Upon opening the box I was pleasantly surprised at the small size of the unit and its overall appearance. I immediately read the rather flimsy, two sheet manual about three times while using the buttons to familiarize myself with the unit. If you are not a battery knowledgeable person and rely solely on the instructions I think your in trouble, they are not well written. However, even someone with limited knowledge like me the unit is very easy to operate. The screen is well lit and you have enough information on the screen for the function, but not too much to become confused. The only thing that took a little thought is in the “Discharge” mode. The unit wants you to put in the “Final Discharge Voltage”. This is actually the number of cells times whatever cut off voltage you want to use. My first battery was a 6 cell, so I took 6 cells x .9v cut off voltage = 5.4v That is the number I plugged in. Maximum “Discharge” current has a maximum voltage of 1A, but that voltage goes down as the number of cells increases. A battery with 1-5 cells can be discharged at 1A, but a 6 cell battery has a max of 0.83A, 7 cells has 0.71A, and it decreases as the number of cells gets higher. On the charge side the only thing that is not adjustable is the “Trickle” charge voltage. If it is adjustable the manual does not state how to, and I sure can’t see a way to adjust it. Overall I like the unit and I’m sure it will see some good use.
_____________________________
Later, Mike
