crazymustang
NY, USA Status: offline
quote:
ORIGINAL: mglavin What kind of power source are you using? If I follow, your having problems with every battery you've attempted to charge? And your noting disparaging voltage values as compared to other devices. hi, Mike, i am using a "Meanwell" power supply with input 110 volt and output 11-15 volt, 18 amp, i bought this power supply from ebay. i had measured the voltage for both input and output, its reflecting input 123.1 volt AC, and output 12.8 DC. while i am reading this forum, my 2 cell-1300 mah lipo, was cut off at 265 mah about 30 minutes !!! then i press and hold the "Batterytype/stop" button, it showed input 12.21 volt, and output as 7.70volt. i know my lipo pack is not feeding enough, so i reconnect and start the charge process again, its been 21 minutes with feeding 101 mah, and the voltage at the right hand corner shows 8.400 volts, and its still charging, but i am sure its going to stop pretty soon... by the way, what is this voltage value at the right hand bottom corner during charging ?? and also, what is meant by "disparaging voltage values " ??? is there anything wrong with my LN-5014 ?? thanks again for your prompt reply, hope to hear back from you soon. thanks
