RE: Multiplex LN-5014 Charger Ships & Review
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> RE: Multiplex LN-5014 Charger Ships & Review
Page: <<   < prev  1 2 3 4 [5] 6   next >   >>
Login
RE: Multiplex LN-5014 Charger Ships & Review - 3/21/2006 5:22:13 AM
ernest2
Status: offline
thanks anchorman!
can you set the voltage for the discharge in a cycle mode?
(in reply to jkkrobbins)
       Post #: 101
RE: Multiplex LN-5014 Charger Ships & Review - 3/21/2006 5:55:14 AM
ernest2
Status: offline
quote:
ORIGINAL: jkkrobbins
So what will happen if the input cables are reversed? I know if the outputs to the battery are reversed you get an error. But what about the power input? Does it detect this or will it fry?
i don't know if its the same with this charger, but in the manual for rip-max pro peak prodigy (which is the same with my swallow digital charger), its says in the features that reverse polarity protection on both input and output. maybe you can check with the manual.
       Post #: 102
RE: Multiplex LN-5014 Charger Ships & Review - 3/25/2006 9:04:24 AM
StevieM
Status: offline
From Bcer-Rcer query back in Nov, with regards to the "cycle" mode:-
"But when in either cycle mode (Discharge to Charge; or Charge to Discharge), it appears to ignore my set cutoff voltage and drop the pack to below 0.8V per cell before stopping the discharge"
Mine does the same...ie, despite set cut-off voltage for 9.6v pack as 8v, in cycle mode it will discharge to 6.4v, before charge cycle.
Tested this with one cell also.....discharges to 0.8v, regardless of actual cut-off voltage set.
Wonder what happens if set to 1.25v per cell (maybe it then discharges to 1v per cell???)...anyone tried this ???
So, imagine if use this charger for 14-cell pack in cycle mode, could be high risk of reversing a cell if set cut-off to 14v?
Anyone else found this "feature"?
Rgds, Steve
(in reply to hilleyja)
       Post #: 103
RE: Multiplex LN-5014 Charger Ships & Review - 3/25/2006 2:06:31 PM
RC Accessory
Status: offline
quote:
ORIGINAL: StevieM
Rgds, Steve
Steve, which charger has the issue you describe above? I can't tell if you are referring to the RipMax or the Multiplex. Thanks.
(in reply to StevieM)
       Post #: 104
RE: Multiplex LN-5014 Charger Ships & Review - 3/25/2006 3:13:35 PM
StevieM
Status: offline
Ripmax...Propeak Prodigy II
Rgds, Steve
(in reply to RC Accessory)
       Post #: 105
RE: Multiplex LN-5014 Charger Ships & Review - 3/25/2006 4:16:20 PM
RC Accessory
Status: offline
Thanks. I have seen very little feedback on that charger. Thanks.
       Post #: 106
RE: Multiplex LN-5014 Charger Ships & Review - 3/25/2006 9:23:46 PM
StevieM
Status: offline
Believe same as ln-5014.
Comparing spec./physical layout/intruction manual, appear identical.
November post I referred to related to 5014, identical discharge characteristics in cycle mode for my Ripmax.
Totally reliable in straight "discharge" mode though...will accurately cut discharge accdg. to c-off voltage set.
It's just a quirk of the charger and I will just avoid cycle mode..not a pbm.
rdgs, Steve
       Post #: 107
RE: Multiplex LN-5014 Charger Ships & Review - 3/26/2006 3:03:17 PM
mglavin
Status: offline
quote:
ORIGINAL: StevieM
Rgds, Steve
The charger is working properly IMO, 0.8V is the industry standard or thereabouts (some use 0.9V) for cycling NiMH-NiCD cells. You'll find your batteries will not come close the capacity ratings @ 1.0V cut-off. You'll not hurt your batteries and the programmed parameter for discharge will exercise their design tolerances, worry not about cell reversal. Since full capacity discharge regimens are not recommended on a routine basis and it’s typically performed to garner battery pack condition it’s all good occasionally.
Discharge cut-off voltage levels are NOT to be confused with NO-FLY Voltage, whereas terminating flight @ a loaded 1.0V is more than reasonable approach.
_____________________________
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
       Post #: 108
RE: Multiplex LN-5014 Charger Ships & Review - 3/29/2006 5:24:39 AM
RCP57
Status: offline
I see quite a few people trying to charge new Ni-Cad or Ni-MH at a higher rate than a C10. This is not a good idea because you are not performing a “Forming” charge. I have used this charger many times to form new batteries with perfect success. I set up a cycle of 5 times and charge the new batteries at a C10 rate (1000 mAh / 10 = 100 mAh charge). I set the discharge rate at C5 (1000 mAh / 5 = 200 mAh discharge). The batteries never get hot and will take full capacity after this routine.
Later,
Mike
(in reply to mglavin)
       Post #: 109
RE: Multiplex LN-5014 Charger Ships & Review - 3/29/2006 5:35:22 AM
ernest2
Status: offline
when charging nimh, is it ok to recharge again after a charge? like i charge my IB3800 pack 2.5amps. it peaks after putting 3500++ mah. and then i charge it again, this time at 1amp rate, and it still goes to about 800mah, before i stop it, fearing i might overcharge it, (cause i thought 3800 is the peak capacity and 3500+800 is already 4300).
(in reply to RCP57)
       Post #: 110
RE: Multiplex LN-5014 Charger Ships & Review - 3/29/2006 6:58:35 PM
jkkrobbins
Status: offline
I was wondering the same thing. After charging NiMH and NiCD at 1C, the batteries will take an extra 90-200 mAH at 0.1C depending on size. Am I hurting the battery? Or will the battery take more if you put it in slowly?
(in reply to ernest2)
       Post #: 111
RE: Multiplex LN-5014 Charger Ships & Review - 4/20/2006 2:25:21 PM
Alfalfameister
Status: offline
TRICKLE CHARGE question
When I charge over 1 amp (6-cell subC pack), whether NiCD or NiMH, after the charge, the Multiplex (or, in my case, the Swallow Advance) changes to a trickle charge. Is there a way of disabling the trickle charge?
       Post #: 112
RE: Multiplex LN-5014 Charger Ships & Review - 4/22/2006 3:21:20 PM
RCP57
Status: offline
quote:
ORIGINAL: Alfalfameister
No
Later,
Mike
(in reply to Alfalfameister)
       Post #: 113
RE: Multiplex LN-5014 Charger Ships & Review - 5/18/2006 5:20:59 AM
RVM
Status: offline
What exactly would I need to do to convert a PC PSU to a unit to power the Multiplex LN 5014? I don't want to spend $80-$100 on a PSU when I have several spare PC PSUs sitting around. Thanks!
There is no substitution for human competition.
       Post #: 114
RE: Multiplex LN-5014 Charger Ships & Review - 5/18/2006 7:33:44 AM
ernest2
Status: offline
very simple. if you know how to solder and cut wires.
try this link http://www.rcbatteryclinic.com/
(in reply to RVM)
       Post #: 115
