mglavin
CA, USA Status: offline
quote:
ORIGINAL: StevieM From Bcer-Rcer query back in Nov, with regards to the "cycle" mode:- - "But when in either cycle mode (Discharge to Charge; or Charge to Discharge), it appears to ignore my set cutoff voltage and drop the pack to below 0.8V per cell before stopping the discharge" - Mine does the same...ie, despite set cut-off voltage for 9.6v pack as 8v, in cycle mode it will discharge to 6.4v, before charge cycle. - Tested this with one cell also.....discharges to 0.8v, regardless of actual cut-off voltage set. - Wonder what happens if set to 1.25v per cell (maybe it then discharges to 1v per cell???)...anyone tried this ??? - So, imagine if use this charger for 14-cell pack in cycle mode, could be high risk of reversing a cell if set cut-off to 14v? - Anyone else found this "feature"? - Rgds, Steve The charger is working properly IMO, 0.8V is the industry standard or thereabouts (some use 0.9V) for cycling NiMH-NiCD cells. You'll find your batteries will not come close the capacity ratings @ 1.0V cut-off. You'll not hurt your batteries and the programmed parameter for discharge will exercise their design tolerances, worry not about cell reversal. Since full capacity discharge regimens are not recommended on a routine basis and it’s typically performed to garner battery pack condition it’s all good occasionally. Discharge cut-off voltage levels are NOT to be confused with NO-FLY Voltage, whereas terminating flight @ a loaded 1.0V is more than reasonable approach.
_____________________________
Michael Glavin RCU Community Moderator Hitec * Multiplex Field Representative
