Aerotech
FL, USA Status: offline
Hello, No the wings are cut correctly. The slit in the top for the phenolic tube is the top of the wing. Also I have never balanced a plane without it the wings finished on the plane. It is safe to go 1"-1 1/2" behind my mark on the plans. We also dont run servos for the rudder in the rear of the fuse. Its a long tail moment and moving servos that far back can create some small challenges for the CG. Below is one latest customer comments concerning the same plane. Let me know if I can help further. Thanks John Posts: 189 Joined: 11/16/2004 From: Toronto, ON, CANADA Status: offline Hi guys today we went out to put this baby through some tests day 2 in the air was well so so the plane flew incredible herier pass was slow and steady it hovered like like it was hung from the ceiling the rudder needed little bit of coupling on Knife edge Herier rols no problem it was rock steady in most 3 D menuvers but it was slopy in IMAC menuvers it needs aileron defrential and some rudder coupling for most IMAC rols and snaps 4 pointers and specialy knife edge menuvers ...........................the air was so humid and hot the engine was I would say at 80% and on the second flight I had a dead stick this plane is so huge I could not judge how far away we were, my spoter told me to go around,and that was a big mistake so I just had to put her down in the corn it was so far out I should have gone with my instincts and just head for the runway but it just flew in to the corn with a lot of flair and after we spend almost half an hour looking for it it had no damage at all only striped the gears of the left elevator servo < Message edited by Arthur K -- 7/18/2005 2:40:07 AM > _____________________________ Artin arthur@legg.com
