RE: Official Nitro Evader ST Thread v2.0
Tower Hobbies
Logged in as Guest
  Printable Version
AXIAL AX10 SCORPION CRAWLER 12MM HEX WHEEL EXTENSIONS - RTR
Seller:  wheelextensions
Details:   $20.00   |  8/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> RE: Official Nitro Evader ST Thread v2.0
Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: Official Nitro Evader ST Thread v2.0 - 8/15/2005 2:17:39 PM
David D
Status: offline
Hey snipin which clutch shoes did you order?
(in reply to boarding2427)
       Post #: 226
RE: Official Nitro Evader ST Thread v2.0 - 8/15/2005 2:31:36 PM
fga
Status: offline
guys, i had broken my spring pin in an axle. in the manual, its. 2.5 x 12 mm.
my local shops don't carry anything DTX, but he had some HPI ones that size. when i got home. they totally didn't fit. these where alittle bigger.
i noticed a big difference in the HPI ones, cuz they are solid metal, as opposed to the hollow spring pins that were in there. i decided to simply drill the axle out so i can fit it, and it worked perfect and appears to be alot stronger. not bad for a $2.50 upgade and 10 minutes.
Later on driving that day, ofciurse the other stock spring pin broke.. i knew i should have upgraded both sides at the same time... i'll fix that one later.
just thought i give a heads up..
here a pic of it drilled out and on, and one of the solid pin. i can't do a side by side comparison, cuz the other is busted.. but you see the difference.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by fga -- 8/15/2005 2:32:07 PM >
_____________________________
Adam, Nitro Evader ST, Monster GT, RC10 GT, RC18T, Ultra LX Comp Buggy, Micro-T, Vendetta ST
(in reply to David D)
       Post #: 227
RE: Official Nitro Evader ST Thread v2.0 - 8/15/2005 6:34:07 PM
InfinitySpeed04
Status: offline
The exact motor you need to drop in an evader is an o.s. .18 cv-rx with the 11/J rotary carb. I have put one in my evader as well
Going for the Fastest Evader in the World! Hopefully!
(in reply to fga)
       Post #: 228
RE: Official Nitro Evader ST Thread v2.0 - 8/15/2005 8:32:05 PM
boarding2427
Status: offline
ok thanks i found it online for like $99 might get it in a month or two see how it runs on my evader
(in reply to InfinitySpeed04)
       Post #: 229
RE: Official Nitro Evader ST Thread v2.0 - 8/15/2005 10:16:09 PM
Snipin_Willy
Status: online
evaderstman: I ordered the ssrc racing shoes for the traxxas rustler/t-maxx.
DuraTrax Nitro Evader ST: Racing in ARRC Series and Elite Arkansas Fall season series.
       Post #: 230
RE: Official Nitro Evader ST Thread v2.0 - 8/15/2005 11:54:58 PM
David D
Status: offline
Cool i am about to order a set too. I also just got a used .15 cv-rx to use in the evader i had to clean it up a lot and remove to stripped cooling head screws, but now all i need is a new head shim then i will have to let it rip.
(in reply to Snipin_Willy)
       Post #: 231
RE: Official Nitro Evader ST Thread v2.0 - 8/16/2005 12:03:09 AM
Snipin_Willy
Status: online
I'd wait till I get my set installed before you order one, it might save you money if mine doesn't fit. Speaking of which, I have the shoes in my hand right now and they are very cool looking. I'll have them installed after I finish some chores I'm doing.
       Post #: 232
RE: Official Nitro Evader ST Thread v2.0 - 8/16/2005 12:37:12 AM
boarding2427
Status: offline
yeah i wish i could put a bigger engine in my evader like a .21 or bigger see how much faster i can get it to go. because it only goes about 35 stock(when i had it running) and i would like to get it to go like 50-60 w/ a new engine and a hole bunch of upgrades. could i make a custom mount and custom everything for it so it can fit?
       Post #: 233
RE: Official Nitro Evader ST Thread v2.0 - 8/16/2005 12:43:53 AM
dicko
Status: offline
there is an evader kicking round with a .21 in it. it took some modding, but it got in there. you need to cut the chassis to get it to fit i think.
The answer is always more power.
       Post #: 234
RE: Official Nitro Evader ST Thread v2.0 - 8/16/2005 12:45:10 AM
David D
Status: offline
Well a high reving small block and a custom clutch bell from dyno tech could push it that fast.
       Post #: 235
RE: Official Nitro Evader ST Thread v2.0 - 8/16/2005 12:45:57 AM
boarding2427
Status: offline
dang that thing must fly i could probly fit a .26 in it if i get the right kind you think?
i'll be looking around for a new engine to put in it
< Message edited by boarding2427 -- 8/16/2005 12:
