RE: Official Nitro Evader ST Thread v2.0
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> RE: Official Nitro Evader ST Thread v2.0 Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Official Nitro Evader ST Thread v2.0 - 7/31/2005 11:41:38 PM
dicko
Status: offline
just start your truck up & lift the back wheels off the ground. if they are spinning while the truck is idling the clutch is worn. it is much safer than having a clutch spinning with nothing holding it in place. you should be able to have your truck sit at idle & not have the wheels spin.
_____________________________
The answer is always more power.
(in reply to brownstone101)
       Post #: 51
RE: Official Nitro Evader ST Thread v2.0 - 7/31/2005 11:48:01 PM
brownstone101
Status: offline
lol i forgot about that i was thinking of that when i was typing that like, if that spring is worn then it snaps well that would be realy bad
BUT, the one bad thing about that idea dicko, is that if your idler is in to much it can engage cause the RPMs are up cause its trimed wrong or idling high but, alot of people eather have the idler set to high or way to low where its trying to keep alive but it cant so, i think its when u feel like its going, replace it. and i find this funny my clutch spring broke on me like 3 days ago waiting on tower!!!!! i didnt seam like it was going to brake but o well i got 4 ST-15 springs so i have a mess load of back ups
< Message edited by brownstone101 -- 7/31/2005 11:49:52 PM >
TA-05 - Trinity P2K2 27T, Novak Cyclone TC, JR XR3
Nitro Evader ST rebuild project.
(in reply to dicko)
       Post #: 52
RE: Official Nitro Evader ST Thread v2.0 - 8/1/2005 12:32:30 AM
brownstone101
Status: offline
well i was wondering before i do this rebuild what should i watch out for when i replace my clutch spring like is it hard or just hold the 2 pads in the spring and pop them on i just want to know before i do it when i get my shipment?
       Post #: 53
RE: Official Nitro Evader ST Thread v2.0 - 8/1/2005 12:36:39 AM
dicko
Status: offline
put the shoes together, join the spring & roll it on. sometimes it is easier to leave the shoes on the fly wheel. if the old spring has a visible wear mark from rubbing on the CB, your shoes are worn as well. you will either need to replace them or cut the groove that the spring sits in deeper. you may also need to clip a bit off the spring to shorten it if this is the case. the white shoes tend to wear out pretty quick.
       Post #: 54
RE: Official Nitro Evader ST Thread v2.0 - 8/1/2005 1:58:33 AM
dpawl
Status: offline
Got a strange question. When my car idles now, it idles down to a decent RPM, it is a bit too high and is SLIGHTLY engaging the clutch. Problem is it them idles ever further down, after about 5 seconds. It idles so low I have to hit the gas every few seconds to make sure it doesn't die. Do you think this is a problem related to the LSN? I got it decent but since I go the idle good, I never did the pinch test for the LSN.
Savage X F4.6
Nitro Evader ST Hopped Up (Dead Motor... damn you DTX)
(in reply to dicko)
       Post #: 55
RE: Official Nitro Evader ST Thread v2.0 - 8/1/2005 2:00:16 AM
dicko
Status: offline
that's how it is supposed to idle, these engines aren't designed to idle for long periods of time, they are designed to race at high rpm. if it revved up at idle it would be mean your LSN is set too rich.
(in reply to dpawl)
       Post #: 56
RE: Official Nitro Evader ST Thread v2.0 - 8/1/2005 2:55:39 AM
brownstone101
Status: offline
ya i think i need cut a grove maby my cb has a DEEP track in it i hope its fine
o will get a pic
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by brownstone101 -- 8/1/2005 2:56:47 AM >
(in reply to dicko)
       Post #: 57
RE: Official Nitro Evader ST Thread v2.0 - 8/1/2005 3:25:27 AM
RC_Racer005
Status: offline
hows it goin all
1) aluminum parts....if these are so bad (cause when you crash and break a part, an a-arm lets say, then it'll bend) so why not just bend it back and you're good to go?
B) crystals.....i got a pair of (green) crystals from my old traxxas electric rustler, and i tryed puttin them in my evader (and controller) and it doesnt work, anybody know what gives? I mean crystals are crystals, they should work on any receiver/controller.
Your best friends: Duct-tape and zip-ties
       Post #: 58
RE: Official Nitro Evader ST Thread v2.0 - 8/1/2005 3:31:15 AM
brownstone101
Status: offline
aluminum dosnt bend back thats why>>> it snaps! or its realy weak but it mostley snaps
(in reply to RC_Racer005)
       Post #: 59
RE: Official Nitro Evader ST Thread v2.0 - 8/1/2005 3:35:53 AM
dicko
Status: offline
there are crystals for Rx & Tx, wrong way round & they won't work, there are also different frequencies, ie 40mhs, 27mhs 36mhs & 70 mhz. again a 40 mhz won't work in a 70 mhz radio. some brands (ie futaba) have crystal specific radios, so a JR crystal won't work properly in them. and also crystals have a shelf life, after a while they start to glitch, then die.
       Post #: 60
RE: Official Nitro Evader ST Thread v2.0 - 8/1/2005 3:50:43 AM
khlept0
Status: offline
My clutch is toast and both my shipments (18 CV-RX and dump load of tower stuff) were lost in mail or something.
Doing fedex and ups tracking. *sigh*
Some people are wise, other people are otherwise.
(in reply to dicko)
       Post #: 61
RE: Official Nitro Evader ST Thread v2.0 - 8/2/2005 4:15:01 AM
dpawl
Status: offline
As you guys might know I am new to Nitro, had a competition electric a while ago. My old differential was HUGE, like over an inch tall. I saw the NEST's diff in the LHS today, TINY! Ever since I got the truck running good, it makes a metallic noise when I turn one wheel with the engine off. I tightened it pretty good, I think it could go tighter. If you go as tight as possible, it would make it almost like a solid axle right? Why don't they make these things with solid axles anyway... I mean when I am out in the loose dirt and the right tire is in softer sand, it tends to take off faster than the left and cause it to swing to the left as I punch the throttle. Is this a symptom of a loose diff?
Savage X F4.6
(in reply to khlept0)
