RE: New 81" P-47 ARF coming from Hangar 9
Tower Hobbies
Logged in as Guest
Users viewing this topic: valr
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: New 81" P-47 ARF coming from Hangar 9
Page: <<   < prev  107 108 [109] 110 111 112 113 114 115 116   next >   >>
Login
RE: New 81" P-47 ARF coming fr... - 3/14/2008 2:59:52 PM
blkmerlin1
Status: offline
To those running dl-50 or da-50 is there a prop hub available for this configuration? any help appreciated
(in reply to sweetpea01)
       Post #: 2701
RE: New 81" P-47 ARF coming fr... - 3/14/2008 3:39:19 PM
san26141
Status: offline
I'm using a Tru-turn prop-hub (#TTH-1500-B) with a backplate (#TTH-BP-1500-A). You have to specify to modify the backplate for the engine you are using.
_____________________________
Uhmmmm....why isn't it coming back?
(in reply to blkmerlin1)
       Post #: 2702
RE: New 81" P-47 ARF coming fr... - 3/14/2008 8:51:06 PM
blkmerlin1
Status: offline
Thank you for the info
(in reply to san26141)
       Post #: 2703
RE: New 81" P-47 ARF coming fr... - 3/19/2008 10:19:02 AM
Tisoy909
Status: offline
Hey Guys, just wanted to throw this question out here to anyone that might be able to help. Although this isn't a forum on radials but just wondering if anyone here can give me some useful input. I'm curious about the Saito Fa-325 Radial engine, first if it would fit in our Jugs Cowling and second, what kind of performance can one expect it to produce for the 150 sized Jug. thanks for the advice in advance.
Louie
" To thine own self be true "
       Post #: 2704
RE: New 81" P-47 ARF coming f... - 3/19/2008 1:12:45 PM
ramboman
Status: offline
Hi courageous people,
I am at the retracts since two days...
- no 4-40 taps to find in Belgium, so I changed to metric, 3mm is OK;
- no JT servo to find in Belgium, so I changed to HS-75BB;
- need to file nice oval holes for screws of the servo;
- better to disassemble the retract BEFORE;
- no way to tap an oval hole ;o))
- countersinkink and using flat head 3mm screw is OK;
- no metal arm to find, but having goog friends helps;
- change ball and clevises to 3mm;
- file where needed to make it work...
- correct one scisor angle, force in the other direction...
- add a dedicated 6V battery, 4.8V seems to be short;
- add a reversing wye and connect to channel 9 of my FF9.
Honestly, air retracts are much more easy to implement.
May be somebody has replaced the servo with a cylinder...
(in reply to Tisoy909)
       Post #: 2705
RE: New 81" P-47 ARF coming f... - 3/19/2008 8:41:24 PM
pdubree
Status: online
Ramboman. Couple hints for you. Run the HS-75BB servos on 6v. This will increase effective torgue to about 115 oz. This will provide enough for good operation. If you use bigger wheels make sure they are treaded light wheels. Need set servo horn so gear will stay down position when turning radio on off. Diassemble retracts and burnishish all metal moving parts especially the copper bushing. This will loosen up the gear for better movement. Then grease all metal moving parts with high temp disc brake grease. Will last forever.
Pete
(in reply to ramboman)
       Post #: 2706
RE: New 81" P-47 ARF coming f... - 3/20/2008 7:38:01 AM
ramboman
Status: offline
Thank you for your suggestions.
I use teflon oil (for weapons) and a dedicated 6V battery.
How do you set the servo horns?
When I shut power on the radio, the retract does not move any more...
(in reply to pdubree)
       Post #: 2707
RE: New 81" P-47 ARF coming from Hangar 9 - 3/20/2008 10:43:04 PM
alqwad
Status: offline
Hello-
To any one with this model, can you please tell me what the overall diameter of the included static propeller is? Thanks in advance.
-RME
MIGJAM
(in reply to TLH101)
       Post #: 2708
RE: New 81" P-47 ARF coming f... - 3/20/2008 11:39:59 PM
pdubree
Status: online
Set horn and gear in down position with radio gear select for down. when you turn offf transmitter then back on the gear should stay down not cycle up then back down.
Pete
       Post #: 2709
RE: New 81" P-47 ARF coming from Hangar 9 - 3/20/2008 11:41:12 PM
pdubree
Status: online
close to 24 inches which is just about scale size.
Pete
(in reply to alqwad)
       Post #: 2710
RE: New 81" P-47 ARF coming from Hangar 9 - 3/21/2008 4:07:57 PM
alqwad
Status: offline
Thanks for the information on the prop. Gotta love RCU...
MIGJAM
       Post #: 2711
RE: New 81" P-47 ARF coming fr... - 3/25/2008 9:05:37 PM
Art G.
Status: offline
I have read this entire forum. I see where people are using G38 TO FLY THE P47, and have said it flies well, but have not said if it has enough power to do large loops, or how the vertical is. etc.. i want to fly faster than scale. Can anyone give me information on the G38. How about the Quadra 52? It flies my 1/5 scale P51 great. Would appreciate an answer.
       Post #: 2712
RE: New 81" P-47 ARF coming f... - 3/26/2008 10:45:01 PM
slowglowflyer
Status: offline
There have been a few of us that have decided to use the DA 50 as a power choice. I believe that mine will handle it quite well and all you have to do is make some firewall mods and it fits perfectly. I figure that just becuase you have the extra power doesn't mean that you have to use it all the time. Just my two cents!
(in reply to Art G.)
       Post #: 2713
RE: New 81" P-47 ARF coming f... - 3/27/2008 2:29:31 AM
Art G.
Status: offline
Thanks for the reply. I would still like to hear from someone who has tried the G38.
(in reply to slowglowflyer)
       Post #: 2714
RE: New 81" P-47 ARF coming f... - 3/27/2008 3:47:35 AM
