 New 81" P-47 ARF coming from Hangar 9 >
Old 03-06-2006 | 03:18 PM
  #501
Default RE: New 81" P-47 ARF coming from Hangar 9
the onley thing that jumps out at me is fuel line for gas and a fuler
ok after spending some time dry fitting just a few nit pics the gaps between the flaps &ali are a little wide there seems to be a step between top of wing and top of flap
Old 03-06-2006 | 05:55 PM
  #502
WLJ's Avatar
WLJ
My Feedback: (108)
Birthday came early. I got my call this afternoon. It's on the rack, i'm starting on the engine installation. Lots of room for G-38.
ORIGINAL: WLJ
ORIGINAL: go vertical
I'm glad to see that they have reached the East Coast. I'm looking for mine tomorrow. G-38 waiting.
well I have picked up my 47 today after un packing I have definitly decided to put my brison 2.4 in it it looks lost in the cowl the plane is big enough to handel a gas engine no problems
Old 03-06-2006 | 06:53 PM
  #503
WLJ's Avatar
WLJ
My Feedback: (108)
Fifteen Min. after opening the box. Top two supplied engine mount holes matched Bennett Cup mount on G-38. Cup mount too thick, engine sticks out a little far. Flat plate mount, maybe spacers, and a little work to the fire wall will fix that. More later.
ID:	421524   Click image for larger version
ID:	421525   Click image for larger version
ID:	421526   Click image for larger version
Old 03-06-2006 | 08:28 PM
  #504
WLJ, I think I saw a spring starter on your G-38, am I correct? Try without it.
Old 03-06-2006 | 08:34 PM
  #505
Bob, when you get your 2.4 mounted send me some pics I 'm thinking of using the same motor set up.Thanks [email protected]
Old 03-06-2006 | 08:43 PM
  #506
Gosh, I wished I had a FE 2.4 waiting for this babe. Well, I guess I'll have to go with my G-38.[]
Old 03-06-2006 | 09:26 PM
  #507
mirwin's Avatar
[quote]ORIGINAL: WLJ, ", , , , , Lots of room for G-38. . . . . "[quote]ORIGINAL: WLJ
For certain? Because that's what I was thinking about using. My LHS still hasn't gotten the plane in though.
Mike
Old 03-06-2006 | 09:29 PM
  #508
mirwin's Avatar
ORIGINAL: WLJ
Will the muffler fit too? If not, what is your plan?
Mike
Old 03-06-2006 | 09:33 PM
  #509
WLJ's Avatar
WLJ
My Feedback: (108)
It'll go. I may have to modify the Fire wall a little. I put a G-38 in the H-9 Mustang. I had to work on the firewall on that a little also.
ORIGINAL: mirwin
ORIGINAL: WLJ
Mike
Old 03-06-2006 | 10:53 PM
  #510
goboom's Avatar
Hey Guys, any idea if a DA50 will fit in this bird ? (I know its a bit much)
Old 03-06-2006 | 11:14 PM
  #511
the lenth would be the only problem it's onley 5 1/2 in. deep to the fire wall as far as power dave platt told me once that you can allways throtle back but you can't add power that isn't there
Old 03-07-2006 | 12:14 AM
  #512
WLJ's Avatar
WLJ
My Feedback: (108)
Couple Hrs. later, home made plate mount, plywood spacers, modify firewall (nothing really structural) hard work done. Front of prop spool, 5 1/2 in. I'll box in the firewall cut out to keep heat out of Fuse.
ID:	421736   Click image for larger version
ID:	421737   Click image for larger version
ID:	421738   Click image for larger version
ID:	421739   Click image for larger version
ID:	421740   Click image for larger version
Old 03-07-2006 | 08:43 AM
  #513
BOLTMAN's Avatar
What is everyone's thoughts on the method of attaching the elevator, aileron & rudder horns to the surfaces? The instructions say to drill, then fit screw, then remove again & soak the hole & surrounds with CA & then re-fit the screws. There is no hardwood or ply in these locations, only balsa from what I could feel by having a prod around with a pin on one of the elevators. My feeling is that I should cut in some ply plates to screw to. Has anyone out there used the suggested method & with what results?
Old 03-07-2006 | 09:09 AM
  #514
i have had a H9 funtana 90 that used this method and had no problems
Old 03-07-2006 | 10:34 AM
  #515
Hmmmmm
I think I'll remove a square of covering about 1 1/2" square, use CA to scab a piece of 1/16 ply on both sides, replace the covering, drill and THEN soak those holes w/ more CA.
Does that sound like a plan?
Old 03-07-2006 | 12:10 PM
  #516
mobyal;
I'm going to do the same thing what you just described. I am not taken a chance.
Old 03-07-2006 | 01:53 PM
  #517
Fitted the engine today, saito 180 with flex muffler extension (see pictures). Cowl fitted a treat, the removable fusalage hatch will not fit once the cowl is fitted. You have to make the slots longer on the fus. Also check the battery and reciever tray as mine was lose.
ID:	422078   Click image for larger version
ID:	422079   Click image for larger version
ID:	422080   Click image for larger version
Old 03-07-2006 | 05:51 PM
  #518
Flyjets's Avatar
My Feedback: (51)
Alans
Looks like the slot is just missing a small amount can u just cut an angle on the Metal and make her fit?
Guy's
I had my buddy call Horizon Hobby this morning and they told him that no shipments have went out. I couldn't figure this out since everyone here is reporting them arriving. Well it gets better by the afternoon my buddy calls me back and tells me my P47 arrived..........
Go Figure
Ian
Old 03-07-2006 | 07:05 PM
  #519
WLJ's Avatar
WLJ
My Feedback: (108)
About a minute and a half with a DREMEL on the rear of the front slots only.
ORIGINAL: Flyjets
Alans
Guy's
Go Figure
Ian
Old 03-07-2006 | 09:40 PM
  #520
Guess what: I called Horizon this evening and have been told that "we have not received any shipments from our factory. We have not shipped out any airplanes, yet" After I told that guy that there are numerous people on RCU posting pictures of their building progress already he gave in and "admitted" that their were a very limited number of shipments made. Why this guy is even answering phonecalls is beyond me. There is no reason to lie to a customer. Especiakky if the customer is better informed than the sales person. Anyway I was told I would have to wait till April before I can even think about mine. I am not too happy about that.[>:]
Old 03-07-2006 | 10:20 PM
  #521
WLJ's Avatar
WLJ
My Feedback: (108)
Drive down to Roanoke Rapids. We've got another. Some dealers are part of a priority receive program.
ORIGINAL: thevirginian
Old 03-07-2006 | 11:04 PM
  #522
Veltro's Avatar
It sounds like the folks on the phone need a little better training.
I know for certain that mine is a sneak preview. It's a program the hobby shop belongs to where they get an advance copy of whatever is new - even if they don't want it. I imagine you would have to be a busy hobby shop for that to work out in the long haul. My LHS thought he would see the other eight he has on order in three weeks. Hang in there. It looks like this plane will go together really fast once you get it.
Old 03-08-2006 | 10:33 AM
  #523
Sorry for the confusion guys. I dont think our customer service person was trying to be dishonest. For some reason the information that we shipped these didnt get throughout the company. Its a downside to being a big company I guess. I'll let them know.
Yes, we shipped what we call the Fast Forward, which is essentially like described above. They however arent advanced copies of anything. Its just a program we have for dealers so they get the new products first if they are signed up for the program. Usually we have enough of a new product that we ship all orders shortly after the fast forward goes out. On this one, the rest of the orders will go out two or three weeks later.
But, the info you got isnt correct. It wasnt a very limited number went out.This model is out in big number now and though we are out of stock for a few weeks, is readily available at many LHS.
Old 03-08-2006 | 11:01 AM
  #524
ORIGINAL: MMcConville
Sorry for the confusion guys. I dont think our customer servoce person was trying to be dishonest. For some reason the information that we shiped these didnt get there. Its a downside to being a big company. I'll let them know.
Yes, we shiped what we call the Fast Forward, which is essentially like described above. They however arent advanced copies of anything. Its just a program we have for dealers so they get the new products first if they are signed up for the program. Usually we have ebnough of a new product that we ship all orders shortly after the fast forward goes out. On this one, the rest of the orders will go out tow or three weeks later.
But, the info you got isnt correct. It wasnt a very limited number went out.This model is now readily available and lots are out.
Old 03-08-2006 | 11:27 AM
  #525
mike can you tell us wat was wrong with the first run that promted the recall i have mine it looks great i have the engine a brison 2.4 allready instaled i am very pleased os far
