sideshow
CA, USA Status: offline
[QUOTE]Originally posted by MikeC Hi Larry, Reducing the normal max. RPM of a turbine by a few thousand RPM will NOT have any significant beneficial effect on bearing life (assuming that correct bearings for the design RPM are being used), engine life, EGT's, OR fuel consumption. Mike C [/QUOTE] Being able to dial down the max RPM (thrust) might, however, make the engine usable for models (that aren't equipped with a speed limiter) that weigh less than 32.22222 pounds at an AMA sanctioned club or event. : Not to speak for wd40, but I think that's what he meant. Bob
_____________________________
Bob Convery
