E-Pattern Observations
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> E-Pattern Observations
Page: [1] 2   next >   >>
Login
E-Pattern Observations - 7/28/2005 5:20:20 AM
VerneK
Status: offline
If you're truly interested in flying electric pattern, the first thing to do is search on "electrified partner" in RC Universe. It's a thread started a couple years ago by Tony Frackowiak on how he constructed an electric PL Products Partner. Read the whole thread because it's loaded with info that's as good today as when it was written. The only real thing that's changed since then is that the lipos have gotten lighter and more powerful.
I spent the last month flying with Andrew Jesky and Peter Collinson in preparation for the Nats. After the second day, I knew my next pattern plane would be electric. Since then, I've been gathering as much data about it as possible. The majority of what I've learned comes directly from watching and occasionally helping Andrew and Peter. In no particular order, here's a list of observations I've made:
1. For power, a Hacker C50-14XL, Hacker Acro 90 speed controller, APC 22-12 electric prop, and Thunderpower 5S-4P 5300 batteries will give you more power than anything out there, glow or electric. There's one maneuver in the FAI schedule that convinces me this is true and my judging assignment for FAI at the Nats convinced me even more.
2. To be able to realistically practice pattern with electric, you need a minimum of 4 batteries and 6 would be better ( it takes two batteries per flight).
3. Field charging batteries is a primary consideration. If you don't have the ability to charge 4 packs at a time, you'll end up waiting a long time between flights. This means you either need 4 chargers or 2 chargers capable of charging 10S packs (2 5S packs in series). All the chargers I've seen run off of 12 to 13.5 volts DC. That means your car battery but only if there's always someone at your site that can give you a jump start when it's time to go home. Other options include a deep-cycle marine battery that you bring along (heavy and awkward plus it's something else to charge each night) or a generator. The Honda EU1000i is a lightweight (26 pounds) generator that only puts out 56 db at 900 watts continuous/1000 watt surge. The street price on that is $750.00 but a little shopping on EBAY will get you one for about $500.00 or so used or $629.00 new from an EBAY vendor.
4. If you go the Honda route, you'll need two power supplies capable of running two chargers each. That equates to an 18 amp power supply. Forget the Diamond power supplies. They overheat and shut down. There's a guy on EBAY that sells a 20 Amp (18 Amp continuous) power supply for $59.00 and he'll reduce the shipping charge if you buy two of them (you need two). Look for him in the Hobby R/C section on EBAY. However, these power supplies may not be adequate depending on which chargers you select. If you use Astro 109 chargers, the Honda and the above power supplies will work just fine. According to the specs I've read on some of the other chargers, the power supply probably won't cut it.
5. Andrew already discussed the cell balancers and that just makes sense to me given the cost of a battery pack. In fact, the cost of a pack has me thinking a seperate charger for each pack makes a lot of sense. If something goes wrong with a charger, you only lose one pack instead of two!
6. The weak link in the whole setup is the gearbox on the Hacker. I witnessed Andrew's implode and the aftermatch was pretty ugly. These things need regular, documented, maintenance. Every 50 flights or sooner if necessary. I tracked down Tony F at the Nats and he showed me what to watch for. Tony rotates the prop each way by hand to "feel" the gears. If it doesn't feel the same, he pulls it out for service, regardless of the number of flights and opts to let Hacker clean and grease the gearbox for him. Hopefully, he'll see this and respond in case I got anything wrong or left something out.
7. From what I've read and seen, Plettenberg and AXI outrunners are starting to appear as viable alternatives, but cooling seems to be an issue since they sit so close to the nose of our planes. In addition, there's still a lot of experimenting on props going on with those two motors.
In case you haven't figured it out by now, I'm planning on going electric next season. My shopping list has already started and I actually have the power supplies, speed controller and the Honda. Yet to purchase are:
1 - C50-14XL w/ 6.7:1 gearbox
4 - AstroFlight 109 chargers
4 - Thunderpower cell balancers
1 - Raytek MT-4 Tempgun
1 - AstroFlight Wattmeter
1 - APC 22-12 Electric prop
6 - Thunderpower 5S4P 5300 battery packs (I'm making this my last purchase late in the winter in case something better comes out)
Anybody want to buy a 2003 Harley Dyna WideGlide in great shape....... ;>
Verne Koester
       Post #: 1
RE: E-Pattern Observations - 7/28/2005 11:18:46 AM
patternrules
Status: offline
Eletrified Partner post Verne refers to.
http://www.rcuniverse.com/forum/m_1425422/anchors_1425422/mpage_1/key_electrified%252Cpartner/anchor/tm.htm#1425422
_____________________________
Steve Maxwell
(in reply to VerneK)
       Post #: 2
RE: E-Pattern Observations - 7/28/2005 11:45:50 AM
patternrules
Status: offline
Other links and watch dates of post as some will be outdated.
Composite ARF Revolution Pro Electric conversion
http://www.rcuniverse.com/forum/m_1590356/anchors_1603146/mpage_1/key_/anchor/tm.htm#1603146
Hacker C50 mounting
http://www.rcuniverse.com/forum/m_2239137/anchors_2239153/mpage_1/key_/anchor/tm.htm#2239153
Raised voltage
http://www.rcuniverse.com/forum/m_2501172/anchors_2501830/mpage_1/key_/anchor/tm.htm#2501830
CPLR goes electric
http://www.rcuniverse.com/forum/m_2411533/anchors_2427490/mpage_1/key_/anchor/tm.htm#2427490
< Message edited by patternrules -- 7/28/2005 12:51:28 PM >
Steve Maxwell
(in reply to patternrules)
       Post #: 3
RE: E-Pattern Observations - 7/28/2005 3:35:35 PM
can773
Status: offline
quote:
ORIGINAL: VinnieK
Verne Koester
Hi Verne
Couple of things :-) If you are truly serious about going "green" for next season I think you will find that it will be best to wait until the last possible minute to purchase. Hacker already has a new motor, as well as a controller with an "F3A Brake" (I have no other details) that the Matt's will be using in France (probably others as well). Next spring I would imagine everything ran at this years Nats will be obsolete
I know that the new TP charger is due out shortly which is probably the best bang for the buck ($180 for a 220W charger, the equivelent Schulze will run you around $400). 2 of the TP chargers will charge as fast as 4 109's and will be cheaper, plus they are smaller. The other beauty of the TP chargers is it hooks to their balancers to shut down the charge if ANY cell exceeds 4.24V.....IMO this is a MUST have safety feature. Unfortunately this will only work with the TP charger.
On to the balancers, within a week or so the 10 cell balancers will be out allowing safe series charging on every charge without voltage checking (and taking your balancer numbers from 4 down to 2). The other issue with the Astro's is they wont charge 10s, only 9s.....so if you ever want to charge a 10s pack you will be out of luck.
Power supplies, 18A is not sufficient for 10s charging (we have tried, 4A charge rate is the max)....you need around 25A to make a go of it for 1 10s pack, 45A if you want to run 2 chargers with 10s packs (this is assuming you are charging at 1C...or 5A for the 5300's). Its all in the watts,....at best the Astro is a 140W charger, while the TP is 220W, so whatever you use the best bet is to have a power supply that can deliver 10-15% more watts than your charger can consume (to account for losses). So to run 2 TP chargers a true 500W (40A@12.5V) supply would be the minimum I would use. I would probably go for 600 or 700 just to reduce the load on the supply.
I think you will find that the new motor from Plettenberg is pretty much on par with the Hackers (and who knows what will be out by the spring), plus there is also the Cyclon outrunner but I have not seen this run (they will be in France). Cooling is tricky but my motor ran no hotter in Muncie than any of the Hackers and in some cases it ran cooler. There were days it was running down around 125F, while I heard of Hackers up in the 150F range. The Plett that I ran in Muncie mostly was the 25-13, that is pretty much a proven setup. I use the 19x12W prop and peak current in the air is 60A, dont know if you judged either Adam or I, but typically we are not at full throttle more than once or twice during P-05. I have 200 flights on that motor without ever looking at it once (no gearbox!)....IMO the Hackers gearbox makes it no more reliable than a glow motor....I know that I never had to remove my 140DZ engine every 50 flights to work on it so that it would not implode!!
Chad Northeast
       Post #: 4
RE: E-Pattern Observations - 7/28/2005 6:01:29 PM
JRW
Status: offline
Hi Chad,
Thanks for the tips. I enjoyed watching the finals and chatting with yourself and Adam. Best of luck in France.
Jim W.
Team Futaba
(in reply to can773)
       Post #: 5
RE: E-Pattern Observations - 7/28/2005 7:40:11 PM
patternrules
Status: offline
I have a Duratrax Flashpoint Infrared Temperature Gauge it seems to work very well, any thoughts?
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEMG5&P=ML
Also I have a Radio Shack power supply thats 10 amps, that they don't seem to carry anymore this is the closest I can find on there website and it's 15 amps, the 10 amp I have should be enough for one charger?
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=22-508
Steve Maxwell
(in reply to JRW )
       Post #: 6
RE: E-Pattern Observations - 7/28/2005 8:47:35 PM
can773
Status: offline
quote:
ORIGINAL: patternrules
IR guns seem to all be close, Adam has the Duratrax one and I have another brand and they read about 2C out from each other so thats pretty close.
Again its all in the watts, 13.8V (typical of commericial supplies, PC supplies are 12-12.5V) @ 10A is 138W output.....10s (42V peak) charging away at 5A is 210W consumption....so you would need 2 supplies to charge a complete pack.
18A supplies will deal with 5s packs at upwards of 6A without problems.
If you want a serious supply check out these....
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5793132280&ssPageName=MERC_VIC_RSCC_Pr4_PcY_BIN_Stores
$122 but capable of charging x2 10s packs @ 5A. They also sell a 55A model which will allow me to do x2 10s packs @ 5A and a single 10s pack @ 3A.
Chad Northeast
       Post #: 7
RE: E-Pattern Observations - 7/28/2005 9:20:08 PM
VerneK
Status: offline
Chad,
Unfortunately, I already have the generator and power supplies which is why I'm steering away from the other chargers. No doubt they're good, but the 59.00 each I paid for my two power supplies is part of the over-strapped budget already spent. Even if I didn't have them, I suspect the price of two good 45 amp power supplies might well be the proverbial straw. The controller was too good a deal to pass up. A friend had two brand new Acro 90's that he got via miscommunication with a vendor and only needed one. I bought the un-needed one at a very good price.
I didn't have a chance to see or judge you, but both judged Adam and talked to him at length later about his setup. I was very impressed on both accounts. Nice guy and one of the best pilots I judged on !QUOT!howling Monday!QUOT!.
I'm aware of the new F3a Hacker coming out and will wait and see how the price and motor looks when released. I'm not ignoring the other motors out there either, but I'll have to decide on something this fall when I start building.
The whole purpose of me writing what I did was to give other guys considering electric an idea of what to expect and what I've witnessed so far. This stuff is still a bit of black magic for many of us and I'd still be totally in the dark if it weren't for my practice time with Andrew and Peter. I think we'd all agree is that for the short term, these things are gonna be like computers. Anything you buy now will likely be obsolete 6 months from now. In the interim, I'm gathering up things that will work within my budget and holding out as long as I can on the motor and batteries. My shopping list already has lots of changes in it.
Verne Koester
       Post #: 8
RE: E-Pattern Observations - 7/29/2005 1:12:28 AM
sjm
Status: offline
Hi Steve,
I use that Duratrax temp gage on my R/C cars and frankly when I make the move to electric pattern I will get a better one. It just doesn't repeat that accurately. Sometimes the old saying has truth to it.....'you get what you pay for'
Sam Monteleone
Sure-Link Custom Control Systems
       Post #: 9
RE: E-Pattern Observations - 7/29/2005 4:07:45 AM
nxtdoor
Status: offline
Chad,
What rpm are you turning the 19 x 12 at on 10s?
I am running a Neumotor 1515/2Y with 5.2 gearbox, unfortunately the gearbox has shelled itself for the second time in 20 flights. I am with you now about the geared motors reliability. It produces great power, but limited reliability so far.
Jeff
(in reply to sjm)
       Post #: 10
RE: E-Pattern Observations - 7/29/2005 4:39:57 AM
can773
Status: offline
quote:
ORIGINAL: nxtdoor
Chad,
Jeff
The 19x12W spins at 6450 rpm on 10s with the 25-13 motor...65A draw static, 60A peak during P-05 (not sure where in the sequence though)
I dont know the 19x12 standard and I cannot use it, the Schulze 32.55K ESC current limits to 72A max and the 19x12 draws more than that (its really obvious when the ESC limits the motor!)
Depending on how well your packs hold voltage will dictate the current draw and rpm, so you may be lower or greater by a bit with those numbers.
Chad Northeast
(in reply to nxtdoor)
       Post #: 11
RE: E-Pattern Observations - 7/29/2005 4:52:10 AM
Adamg-RCU
Status: offline
Sam, the Duratrax is good enough for my use. I don't think we have any reason to desire more than ±2degC repeatability on measurements, which the Duratrax seems to offer. If my motor comes down at 58 one flight and 56 the next, I don't think "I wonder what changed?" If it comes down 56 one flight and 76 the next, I need to do some tests before I fly again. If my battery is 43 when I land, then next flight is 50, I know instantly that I have pushed the discharge depth on that second pack.
       Post #: 12
RE: E-Pattern Observations - 7/29/2005 5:08:47 AM
VerneK
Status: offline
When Andrew first got started with his electric Brio, he had a laser temp gun that worked just fine (don't remember the brand).
