bps
Joined: 10/16/2002 From: Indianapolis, IN, USA Status: offline
I wanted to mention a couple of things about the foaming Polyurethane glues. It takes a small amount of glue applied to the joint to result in a good glue joint. This stuff will foam like you will not belive. If you decide to use it, practice first. You can control the foaming action of the glue to some degree by the amout of moisture in the wood you are glueing toghether. If you live in a very dry climate you will need to wet one side of the wood to be glued and place glue on the other. I live in a very humid climate so the wood generaly has a high moisture content. That means I do not need to add additional water to the wood. I place a small bead of glue on each surface to be glued and clamp, nail or mechanicaly hold together the two surfaces for 6 hours or so. If the surface to be glued is rather wide I use a scrap of wood to spread the glue for better coverage. I have found that these glues have some great advantages in model construction as well. Hope this is informative, Latter JEB
< Message edited by bps -- 8/10/2005 4:42:43 PM >
_____________________________
JEB
