RE: Step by Step Trailer Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> RE: Step by Step Trailer Build Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Step by Step Trailer Build - 1/27/2006 9:16:06 PM
rtn9105
Status: offline
Anymore progress on your trailer? I'm planning to do this same build in the spring.
(in reply to bps)
       Post #: 51
RE: Step by Step Trailer Build - 1/28/2006 3:00:46 AM
bps
Status: offline
Yes, I have been busy building the top and an opening mechanism that does not work the way I invisioned it. I will replace with standard hinges and take plenty of pictures of both. I just have been to busy to keep up. Hope to make some progress tomorrow. Thanks for asking.
JEB
_____________________________
JEB
(in reply to rtn9105)
       Post #: 52
RE: Step by Step Trailer Build - 1/29/2006 12:38:27 PM
bps
Status: offline
I have finaly had some real time to work on the trailer. Tried to design an opening mechanism that did not work as expected. Seems like I just could not bring myself to purchase 8 feet of piano hinge and pay the price. In the end I wound up buying some "T" hinges at the local hardware and using (4) of them. Cost for the hinges was 6 dollars. Any way here is the failed hinge arraingment. Next post I will update the cost so far and post pictures of my current hinge set up.
JEB
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
JEB
(in reply to bps)
       Post #: 53
RE: Step by Step Trailer Build - 1/29/2006 12:47:55 PM
bps
Status: offline
I inteded to update the cost of construction so far. Here is my investment to date.
Prior Total $373.60
Additional plywood at $10/sheet 3 sheet $ 30.00
Additional boards $ 17.56
Hardware $ 13.96
Glue $ 10.00
Current Total $ 445.12
JEB
JEB
(in reply to bps)
       Post #: 54
RE: Step by Step Trailer Build - 1/31/2006 11:22:03 PM
Prop Nut
Status: offline
You have inspired me, I got together a list of materials I need to build my own. I have an old popup that sits on a 7x10 frame that will work as a dandy platform to build from. The popup isnt worth fixing but the frame is great. My wife even OK'd the projected cost (after she said to double it just in case, lol)!!! I am going to make a box six foot high but with two 4x8 lift doors on the sides and a small swing door on the back. I will use gas springs to lift the doors. I found a website with tons of info on making your own camper trailers. I will post the URL if you are interested.
Scope? Listerine? Or Prop Wash?
(in reply to bps)
       Post #: 55
RE: Step by Step Trailer Build - 2/1/2006 1:53:41 AM
Flying Hog
Status: offline
Prop nut... I'm intrested in the URL. Thanks
Bob
(in reply to Prop Nut)
       Post #: 56
RE: Step by Step Trailer Build - 2/1/2006 2:18:14 AM
bps
Status: offline
Prop nut please post it. I am getting ready to take pictures of my opening mechanism. I would suggest you keep the clasps on the outside of the pop up if your unit has them. I am looking for a couple of these that I can get so that I can latch down the lid and lock it. Here is a url for some reasonably priced gas struts. http://www.surpluscenter.com/item.asp?UID=2006011909403778&item=1-2561&catname=misc
JEB
JEB
(in reply to Flying Hog)
       Post #: 57
RE: Step by Step Trailer Build - 2/1/2006 2:28:31 AM
Prop Nut
Status: offline
Here is the URL, you need to do a search for the info you want but its in there......someplace
http://www.mikenchell.com/forums/
I have four of those latches, I only need two. I will see if I can pull a couple off tommorow.
(in reply to bps)
       Post #: 58
RE: Step by Step Trailer Build - 2/1/2006 3:39:44 AM
Prop Nut
Status: offline
Here is an article on painting with latex (its actually about painting boats but this should illistrate the point very well).
http://www.angelfire.com/nc3/davecarnell/articles.html#Waterproofing%20Wood
       Post #: 59
RE: Step by Step Trailer Build - 2/1/2006 11:34:25 AM
bps
Status: offline
Prop nut,
Thanks for the offer. If it works just let me know how much I owe you. Also I will take pictures of my opening system for the lid. Works well for me and I did not have to order gas struts. Here is a link that explains how to deturmine strut size. http://www.mcmaster.com/
JEB
JEB
       Post #: 60
RE: Step by Step Trailer Build - 2/2/2006 7:48:07 AM
pundi
Status: offline
nice trailer,
your posts are great, they have given me enough info to go to school and build one in my metal work lesson. the only change i am making is i will be building it all out of metal (afterall it is a metalwork lesson) hopfully my trailer will look as great as yours!
how many planes do u fit in?
cheers
(in reply to bps)
       Post #: 61
RE: Step by Step Trailer Build - 2/3/2006 11:18:50 AM
bps
Status: offline
Here are some pictures of my opening mechanism. Works great for me and I did not have to purchase any gas springs. I still have some work to do to make the lid support arms automaticaly extend and retract. Right now I must manualy move them over the center point to get them to lock open or retract. Another trip to the hardware and here is what I spent for fittings and metal.
Prior Total $ 445.12
This trip $ 18.90
Current Total $ 464.02
Next hardware trip to purchase oil based wood sealer and final paint. Still have to build the flight box container on the front of the trailer and a spoiler on the rear. A buddy of mine owns a fiberglass shop so I might get some help here. I have worked with glass before having built a Rand-Robinson KR-2 wood/foam/fiberglass full scale aircraft.
JEB
Click for fullsize
Click for fullsize
Click for fullsize
JEB
(in reply to pundi)
       Post #: 62
RE: Step by Step Trailer Build - 2/4/2006 5:32:05 AM
Prop Nut
Status: offline
Your lid system looks great. How did you make the mechanism? Here is a great field table for you to put in your trailer I use one of these when I go to flyins during the summer. I made up a bunch of them today to take to a swap meet this weekend.
Click for fullsize
Click for fullsize
(in reply to bps)
       Post #: 63
RE: Step by Step Trailer Build - 2/4/2006 1:50:11 PM
krossk
Status: offline
quote:
ORIGINAL: Prop Nut
Wow - is that slick! Is that your own design? Or are there plans available somewhere?
Very nicely equipped workshop as well!
       Post #: 64
RE: Step by Step Trailer Build - 2/4/2006 2:04:25 PM
Prop Nut
