RE: Christensens JWM Hungary Hi-Rez diary
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
JetCat P-70 - RTF
Seller:  bevar
Details:   $1,900.00   |  11/20/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Christensens JWM Hungary Hi-Rez diary
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 3:11 AM
RPM
Score: 100
Last Login: 5/5/2006
Status: offline
John -
As always, your digi-pix coverage of the event is absolutely awesome.
I want'a D2X so badly I can taste it. Are you shooting these in Jpeg "Large Fine" or "Raw" format? If you have any additional information to share, it would be greatly appreciate.
Keep up the good work and enjoy your stay.
Thanks.
Hide Signatures
(in reply to -JC-)
       Post #: 101
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 4:48 AM
SDCrashmaster
Score: 110
Last Login: 11/21/2009
Status: offline
Looks like the camera's working fantastic now. Phenominal shots of some phenominal aircraft.
Enjoying the show from this end for sure. Thanks for bringing it to us through fantastic imagery and imagination, John.
Paul
_____________________________
Yeah, I use mixing... Balsa & Dirt. ©
Hide Signatures
(in reply to RPM)
       Post #: 102
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 9:59 AM
john agnew
Score: 100
Last Login: 11/19/2009
Status: offline
John
Thanks from Scotland for the great pics of Lindsay Dickie's G91. As usual beautifull clear shots, I am greatly enjoying your pics, the flying shots are superb, keep up the good work.
John
Hide Signatures
(in reply to SDCrashmaster)
       Post #: 103
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 2:49 PM
jettset99
Score: 100
Last Login: 8/7/2007
Status: offline
Thanks John for the Pictures, Good luck to Sung and the rest of the USA Team. Looks like more fun than a barrel of monkeys
Hide Signatures
(in reply to john agnew)
       Post #: 104
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 3:19 PM
-JC-
Score: 104
Last Login: 11/20/2009
Status: offline
Monday, August 1st, 2005 @ 1600 hours
The official flying competition started today, with Stephan Voelker from Germany flying the first flight of the competition. The winning team from last year is the first team to fly at the next JWM.
AND THE WEATHER IS GETTING COOLER!!! WAS 85 TODAY
The Hawk was repaired from last flight, but it looked to me as if the tail was fluttering again during the final stages of this flight. But, even so, the flight was outstanding.
< Message edited by John Christensen -- 8/2/2005 10:33 PM >
John C
Hide Signatures
(in reply to jettset99)
       Post #: 105
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 3:49 PM
-JC-
Score: 104
Status: offline
Here are the flight judges in action. The way the system works is that all 5 judges gives their individual scores for each flight maneuver. When the flight is over, the scores are added up. In order to insure the most fair scoring, the highest and lowest scores are thrown away. So, if a judge is biased for or against a particular pilot, it does not matter, since an extremely high or extreme low score will be thrown out anyway... Pretty clever huh?
John C
Hide Signatures
(in reply to -JC-)
       Post #: 106
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 4:06 PM
-JC-
Score: 104
Status: offline
Flight maneuvers:
All pilots must pick one flight maneuver from 5 different groups in order to put their flight together. Lets use Sung as an example (Since I am his caller, I should know the program by now )
1. Take off Judges want to see the plane on the center line and on a centerline heading for at least 5 seconds after take off. In those 5 seconds, they also want to see the gear retracting.
2. Straigh flight Flight at a constant heading, following the far side of the runway. No variation in speed, heading or altitude allowed.
3. Inverted Flight Same as straight flight, but inverted. The roll into and exiting the maneuver is judged also
4. Immelman turn Roll on top must be at an exact point in front of judges. No variation in heading allowed.
5. Military Roll Climb at 45 degrees for 2 seconds, roll 360 degrees at the center while still climbing at a 45, then another 2 seconds of continious climb followed by break to level flight.
6. Slow Flight Same as straight flight, but at lowest possible altitude with retracts and full flaps extended. On the Panther, the tail hook is also lowered, canopy open, blow in doors open and speed brakes extended.
7. Slow Roll Slow rool of a minimum of 3 second duration with constant roll rate, heading, speed and altitude.
8. Landing pattern Rectangular landing pattern. Gear extended on downwind leg. Constant speed and no climbing allowed. Flaps added at prototypical speeds in the pattern.
9. Landing Touch down should be on the centerline in front of the judges for maximum score.
Finally, the whole flight is judged for realism from the time of taxi out to taxi back. They want to see smooth turns, realistic speed and realistic roll and climb rates.
John C
Hide Signatures
(in reply to -JC-)
       Post #: 107
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 4:07 PM
-JC-
Score: 104
Status: offline
Nicely restored Willy's Jeep on the flight line today
< Message edited by John Christensen -- 8/2/2005 10:34 PM >
John C
Hide Signatures
(in reply to -JC-)
       Post #: 108
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 4:12 PM
-JC-
Score: 104
Status: offline
Here is the Russian team. i showed this L-39 earlier, but today I got a chance to shoot a few close ups. Pilot is Vitaliy Robertus. The Dragon took 2 months to airbrush!!!
Note the boarding steps, scale hinged canopy with working scale latches plus tons of added surface detail.
John C
Hide Signatures
(in reply to -JC-)
       Post #: 109
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 4:13 PM
-JC-
Score: 104
Status: offline
Cockpit area. The latches underneath the cockpit are scale and working.
John C
Hide Signatures
(in reply to -JC-)
       Post #: 110
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 4:17 PM
-JC-
Score: 104
Status: offline
BVM F-100F belonging to my good friend Steve Elias from England. Steve was pilot no. 2 to fly in the competition today.
John C
Hide Signatures
(in reply to -JC-)
       Post #: 111
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 4:22 PM
-JC-
Score: 104
Status: offline
Miles Student from northern Ireland. The first flight was... eh. Interesting home built turbine and airframe.
< Message edited by John Christensen -- 8/2/2005 10:35 PM >
John C
Hide Signatures
(in reply to -JC-)
       Post #: 112
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 4:24 PM
-JC-
Score: 104
Status: offline
The team from Holland and their BVM F-100D
John C
Hide Signatures
(in reply to -JC-)
       Post #: 113
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 4:26 PM
-JC-
Score: 104
Status: offline
Our host country's entry. A 1/5th scale Albatross in Hungarian colors. Painted like the full size that performed for us.
John C
Hide Signatures
(in reply to -JC-)
       Post #: 114
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 4:27 PM
-JC-
Score: 104
Status: offline
The US team had a good practice session today. Here Bryce is blasting off.
< Message edited by John Christensen -- 8/2/2005 10:40 PM >
John C
Hide Signatures
(in reply to -JC-)
       Post #: 115
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 4:33 PM
schroedm
Score: 100
Status: online
Sweet job John - be sure to snap some close ups of Stephen's new Airworld Hawk - beautiful model!!
Hide Signatures
(in reply to -JC-)
       Post #: 116
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 4:36 PM
-JC-
Score: 104
Status: offline
Another shot of Nightwalkers F-5
John C
Hide Signatures
(in reply to -JC-)
       Post #: 117
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 4:38 PM
-JC-
Score: 104
Status: offline
Here is the railway station in Jakabszallas where the even is held.
John C
Hide Signatures
(in reply to -JC-)
       Post #: 118
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 4:53 PM
-JC-
Score: 104
Status: offline
That is all for today folks. Again, thanks for all the comments. It is nice to get some feedback.
Also, please remember to support our great sponsors for this event. Without them, this would not have been possible.
These are the main sponsors. If someone back home could list a link to the other sponsors, it would be great.. Shipley?
AMT USA
BVM Jets
Repair Technologies International
RCJET.net
JPO
And finally, I want to thank my camera sponsor. Samy's Camera from Los Angeles. Thanks to Samy, all photos are shot with the latest and greatest nikon gear.
Samy's Camera
John C
Hide Signatures
(in reply to -JC-)
       Post #: 119
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 4:57 PM
jair
Score: 100
Last Login: 11/18/2009
Status: offline
Awesome pictures!!Thanks a lot!!!
I wish, that you´de have enough power and energy to continue writing and take pictures the next days!!!
Greetings from Germany,
Julian
Hide Signatures
(in reply to -JC-)
       Post #: 120
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 5:51 PM
-JC-
Score: 104
Status: offline
quote:
ORIGINAL: RPM
John -
Thanks.
RPM,
Yes, the D2X is awesome. I shoot the photos in RAW +fine. This is a setting that stores an unedited RAW file on the memory card and an aditional identical jpeg/fine image. Very usefull when uploading to the web. I now have my magazine/calendar quality images and my web ready photos on the same 4 GB memory card. But, in that seting, it eats up memory in a hurry. It also means that post editing of the RAW files requires a powerful PC. I just bought a new Pentium 4 Laptop with 1GB of ram and a Geforce 6200 videocard. It seems to be able to do the editing fast and without crashing so far.
Here are the stats for a typical flight shot like the one of the Hawk above.
Nikon D2X
2005/08/01 07:06:35.2
JPEG (8-bit) Fine
Image Size: Large (3216 x 2136)
Lens: VR 70-200mm F/2.8 G
Focal Length: 110mm
Exposure Mode: Programmed Auto
Metering Mode: Multi-Pattern
1/250 sec - F/8
Exposure Comp.: 0 EV
Sensitivity: ISO 100
Optimize Image:
White Balance: Auto
AF Mode: AF-C
Flash Sync Mode: Not Attached
Auto Flash Comp: 0 EV
Color Mode: Mode I (sRGB)
Tone Comp.: Auto
Hue Adjustment: 0°
Saturation: Normal
John C
Hide Signatures
(in reply to RPM)
       Post #: 121
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 6:29 PM
FliteMetal
Score: 100
Status: offline
The .jpg slur isn't apparent in today's images. The heat may have effected the card. Might try wiping the contacts with a Kleenex to remove oily residue from handling. The D2X is doing a fabulous job capturing what you've been able to trap in the lens at speed....no small task in itself!
Have the static results been posted yet? The attention to detail on the L-39 is good.
It appears aside from the gross weight differential they are using FAI for flight judging...I assume they used "0" distance in static conforming with FAI as well.
Doing an excellent job John! Can't applaud loud enough.
Ed Clayman
FliteMetal.com
Hide Signatures
(in reply to -JC-)
       Post #: 122
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 7:23 PM
t_burley
Score: 106
Status: offline
awsume pics John, keep em coming buddy. good luck guys
Todd
Meister, Aero Acc., Sierra, Glennis, Get Stencils, Shinden, Warbird Colors, Fliteskin customer
Hide Signatures
(in reply to FliteMetal)
       Post #: 123
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 9:33 PM
jetmodeller
Score: 100
Last Login: 11/3/2009
Status: offline
Fantastic pic,s you are doing a great job,keep them coming i look forward to more of the same,many many thanks best regards Keith W
Hide Signatures
(in reply to -JC-)
       Post #: 124
RE: Christensens JWM Hungary Hi-Rez diary - 8/1/2005 10:12 PM
CJ2002
Score: 100
Status: online
John,
Excellent pics - as always, thanks for sharing them.
You mentioned before that the sun is presenting a challenge with picture taking from the 'crowd' side of the runway in the afternoon. Are the organisers allowing photographers to go the other side of the runway to get decent shots, or have the pics you've posted all been taken in the morning?
Cheers,
Dick
England
Hide Signatures
(in reply to -JC-)
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.436RCU1
