RE: Byron P-47 build....
Tower Hobbies
Logged in as Guest
  Printable Version
PARK ZONE F-4U CORSAIR
Seller:  harleydoberman
Details:   $279.99   |  8/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Byron P-47 build....
Page: <<   < prev  1 2 [3]
Login
RE: Byron P-47 build.... - 2/17/2006 12:19:03 PM
warbird-RCU
Status: offline
I have used www.aeromaster.com for paint schemes They have alot of them for the jug. Here is one of a Aerotech kit I had and some other pics. Thanks Donzie
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by warbird-RCU -- 2/18/2006 1:08:29 AM >
(in reply to Goggles)
       Post #: 51
RE: Byron P-47 build.... - 2/20/2006 6:44:04 AM
Goggles
Status: offline
Thanks for the pics, every one is appreciated.
Well I got around to mounting the cowl tonight. The kit comes with aluminum brackets and 1/4" nylon screws, however the screws have very big heads on them an so I drilled out new holes for some smaller headed screws. I threaded them into the bracket then mounted a rubber gasket on top of the bracket. I need to find a small rubber washer for the screw but I'm confident it will be strong. If not I can always add another set of screws but it's better looking than that big head sitting on the cowl.
There is nothing worse than a flimsy cowl and I felt the joint between the two halves were not that strong and could easily flex and perhaps chip the paint or something worse, so.......Carbon Fiber to the rescue!! 2 layers of 5oz on the center line should make it nice and strong.
I decided it was time to start glassing the control surface. I had some 2.3oz satin cloth kicking around so I thought I would us it on the aileron to make it a little more durable. The ball link sticks out from the surface and I was trying to think of what I could use so it doesn't get damaged or resin on it. I looked around and .........hey.....look at that fuel tubing over there..... perfect fit!!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Goggles -- 2/20/2006 6:46:12 AM >
_____________________________
Gailvin Air Models
Preformance Aircraft Unlimited; Fromeco Batteries Canadian Distributor
(in reply to warbird-RCU)
       Post #: 52
RE: Byron P-47 build.... - 2/20/2006 7:10:45 AM
Goggles
Status: offline
hmmmm......why did these pics turn out full sized
Gailvin Air Models
       Post #: 53
RE: Byron P-47 build.... - 2/21/2006 3:19:59 AM
WolverineRC
Status: offline
hmmmm what are you doing online at 2AM?????
Nevermind I don't want to know.
Did you ever stop to think, And forget to start again?
Wait,,, What was I doing???
       Post #: 54
RE: Byron P-47 build.... - 2/28/2006 5:10:01 AM
crashnburn
Status: offline
Hi Kelvin. Sure enjoyed chatting with you tonight. Looks like your well on your way to a very nice aircraft. I'll stop by from time-to-time to see how your doing.
Cheers,
Ron
< Message edited by crashnburn -- 2/28/2006 5:11:14 AM >
If it was easy-Everyone would be doing it!
(in reply to WolverineRC)
       Post #: 55
RE: Byron P-47 build.... - 1/14/2008 10:29:51 PM
RickVB
Status: offline
Did this project ever get finished? I was really looking forward to the front end construction details...
Rick Vera-Burgos
Novi, Michigan
(in reply to crashnburn)
       Post #: 56
RE: Byron P-47 build.... - 1/16/2008 12:48:59 AM
Goggles
Status: offline
Well i'm sad to say the project has been sitting on the shelf for the last 2 years. I guess I just needed a break form it but I think this year I'm going to finish it....starting to feel the need to build again. I was given a G62 and I'm going to try and use it with the purr power muffler, it'll take some altering but I think it can be done.
When I start in on it again i'll be posting here.
Thanks.
Gailvin Air Models
(in reply to RickVB)
       Post #: 57
RE: Byron P-47 build.... - 4/18/2008 5:02:45 AM
MarvinLoomis
Status: offline
Well hope to see you at the build again! I'm also building a P47 bout the same stage of construction. Mines been sitting for about 5 years before I got motivated to finish it! Soon as I find where someone hid the camera, I'll post a few pics!!
       Post #: 58
RE: Byron P-47 build.... - 4/23/2008 5:36:51 AM
MarvinLoomis
Status: offline
Finally found the camera, heres mine about ready for some paint!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to MarvinLoomis)
       Post #: 59
RE: Byron P-47 build.... - 5/12/2008 4:24:31 AM
MarvinLoomis
Status: offline
Well finally got mine completed!! Anybody else gettin close? Is anybody even reading this?? lol Here are some pictures if ya are!!!!
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 60
RE: Byron P-47 build.... - 5/12/2008 12:06:07 PM
warbird-RCU
Status: offline
I looks like you done a very good job on it and when is the test flight? They are very good flyers I have had both versions flying before. I also have a Byron P-47 bubble version I need to build it is still in the boxes from byron. Thanks Donzie
       Post #: 61
RE: Byron P-47 build.... - 5/12/2008 6:26:07 PM
MarvinLoomis
Status: offline
Not sure about the maiden flight yet! Trying to get the engine running. Zenoah G62, having trouble getting it started. It fires but will not seem to run. Checking out carb might have to put a kit in it. Bought engine on RCU, and have never had it running yet. Hopefully things come around and I can get it in the air very soon!! Thanks for the comments!
       Post #: 62
Jump to:
