STG
WI, USA Status: offline
quote:
ORIGINAL: huey-pilot Another way to think of it is two buckets the same size full of water, one of the buckets has 4 holes in it, the other bucket has 5 holes of the same size. The bucket with 5 holes will empty first. If you want the 5 hole bucket to last as long as the 4 hole you will need a larger bucket. That is true if it were the case that the servos were allowed to draw full torque all the time, but wont the servos just draw enough power to get the job done? ---------------- I finally found something on this... http://www.rcgroups.com/links/index.php?id=4592&cat=281&t=articleprint "Centering Test - 58 oz-in of torque As expected, as the load increased on the servo, the deflection from the zero-load center position increased. At 4.8V, the median deflection was -10.5 degrees and at 6V, it was -6.8 degrees. The currents drawn at 4.8V and 6V were 438mA and 460 mA respectively." Ok, here we have the same amount of torque (58oz) and the 4.8v was at 438ma and the 6.0v was at 460ma---very close(within 5%), but the 6.0 volt is accomplishing more work! As it was only allowing for 6.8 degrees of deflection and not 10.5 degrees as with the 4.8v (both these #'s sound like a lot ha?) It makes sense to me that it can give better centering as it is putting out more watts at 58oz load. 6v x 460ma=2760 4.8 x 438ma=2102. "With the application of 40 oz-in of torque, it is readily apparent that the servo does not reach the same position as it does under no load. At 4.8V, the servo had a median deflection from the median zero-load position of -4.7 degrees. While this may seem like a lot, it still represents only about 7.8% of the total servo travel, meaning that the control surface deflection is still a very large portion of what the pilot is asking for. At 4.8V under 40 oz-in of torque, the servo was drawing 222 mA. It was interesting to note that at higher voltage, the performance of the servo was markedly improved. The angular deflection at 40 oz-in decreased to approximately -4.0 degrees and the servo only drew about 8% more current (239 mA). This makes a good case for using 5 cell receiver packs if you have the option and your servos are rated for it. " As you can see again 8% more, but increased performance! I think I am on to something here.
< Message edited by STG -- 8/3/2005 4:18:39 AM >
_____________________________
Good Flying to you! See Blog for RCU Video's
