Who makes a good tach
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Who makes a good tach
Page: [1]
Login
Who makes a good tach - 1/8/2002 3:31:12 AM
TopShelf
Status: offline
A few years ago I was given as a gift one of those globee tachometers. I find myself using it more often and find myself suspecting it is not very accurate for fine tuning.
So, who makes a good/the best tach?
Kent
_____________________________
He Who is a Slave to the Compass has the Freedom of the Sky.
www.TopShelfRC.com
       Post #: 1
What is the best Tach - 1/8/2002 4:34:28 AM
Steve Collins
Status: offline
Master Tach is the best. It has an analog readout and 7 different RPM range scales. It is not cheap but is extremely accurate. I have owned mine for about 10 years. Sold by:
Master Line Products
1836 Alabama Avenue
Fort Wayne, Indiana 46805
With this tach, you will soon discover that the less expensive digital tachs such as the Hobbico and others like it consistently read as much as 200 rpm or more too high.
(in reply to TopShelf)
       Post #: 2
TACHOMETER - 1/8/2002 4:35:02 AM
KRC
Status: offline
CHECK THIS WEB http://www.ulster.net/~tnc/tncweb.html
Talk to Tony.
       Post #: 3
tach - 1/8/2002 8:42:50 AM
Teachu2
Status: offline
I've been in this hobby close to 30 years, and used dozens of tachs. The only one I own is a TNC PT-10S.....'nuff said?
Trent Combs
Fly 'em until the last piece stops!
       Post #: 4
best tach - 1/9/2002 4:08:41 AM
Steve Collins
Status: offline
Hey Teachu2,
I am not familiar with your favorite tach. Tell us why you like it over all the others you have owned and what others you have owned as well. I was wondering if you are familiar with the Master Tach that I recommended in an earlier post and if so, what features of your favorite tach beat out those of the Master Tach.
       Post #: 5
Re: best tach - 1/9/2002 4:54:57 AM
Teachu2
Status: offline
[QUOTE]Originally posted by aptar
Hey Teachu2,
[/QUOTE]
As KRC posted above, http://www.ulster.net/~tnc/tncweb.html
shows the TNC tachs. I like five things about it over the Hobbico/Tower/Globee/etc tachs: 1) It reads a 10" prop from about 3' away 2) It works in the shade 3) It uses a standard 9V battery 4) It has a large display and 5) It's built very ruggedly.
Mine gets used by my students (high school students) and I really like the safety of the extended range. Makes syncronizing a twin a piece of cake, too.
I may have used a Master Tach, but don't recognize the name. Do they have a website?
Trent Combs
       Post #: 6
Master Tach - 1/9/2002 5:28:12 AM
Steve Collins
Status: offline
The Master Tach can be seen here on the Performance Specialties wepage:
http://www.pspec.com/tach.html
Many of the pilots in the pylon racing community use and swear by this tach. This one also uses one of the rectangular 9 volt batteries which I like as you do with yours. The Master Tach is quite pricey.
       Post #: 7
Master Tach - 1/9/2002 5:41:11 AM
Teachu2
Status: offline
Yes, I used one of these a couple of years ago when some of the F1 guys were practicising at my field. It's a fine piece of equipment, far superior to the standard grade digitals, but the TNC is rock solid on the readings, easier to read, reads to 10 rpm (in the PT-10S model) and just a touch over half the price. To each his own, but if the prices were reversed, I'd still buy the TNC.
Trent Combs
       Post #: 8
Optical tachs - 1/9/2002 5:53:48 AM
Teachu2
Status: offline
for a good read on the differences in optical tachs, try http://www.ulster.net/~tnc/opconds.html
Trent Combs
       Post #: 9
Tach test - 1/12/2002 5:55:48 AM
oakley
Status: offline
Aim your tach at a fluorescent light; if it say 3.7, it's correct.
R/C provides about as much fun as I can stand!
       Post #: 10
tach calibration - 1/12/2002 6:58:49 AM
Teachu2
Status: offline
Sorry, the above post is wrong. Here in the US, electricity cycles at 60 cycles/second - which is 3600/minute - so the reading should be 3.6. Mant tachs will not read the florescent lights, but will do fine with an incandescent bulb. Also, electricity is not always exactly 60 cycles.
Trent Combs
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
