New Product - PowerCube Battery Analyzer
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> New Product - PowerCube Battery Analyzer
Page: [1]
Login
New Product - PowerCube Battery Analyzer - 8/4/2005 2:39:01 AM
YNT uDesign
Status: offline
YNT uDesign is proud to announce the availability of
-The PowerCube -
A Complete, High-end, Advanced, Battery Analysis System
To view the PowerCube, learn more about it, and it's sophisticated analysis software in-depth...Browse to www.lomcovak.cz/charger/powercube1.html , But for now here's the "basics"...
Supported Chemistrys
NiCd/NiMH 1-30 cells, Pb, Li-xx (any Lithium based cells)
Power Requirements
Power supply Pb 12V DC, min. 40Ah, (car or tractor)
Power supply voltage 11-15 VDC
Min. power supply voltage (load) 10.8VDC
Min. power supply voltage (no load) 10.5VDC
Protection output - short circuit, reverse polarity, overheating
Charging
Output voltage 1-49VDC
Output current <0.1A-10A (Yes, a FULL 10A!)
Max. charge power cca 300W @ power supply voltage 12V
Automatic mode for NiMH, NiCd cells
Manual mode for NiMH, NiCd, Pb, Li-xx (any Lithium based cells)
Discharging
When discharging is in progress, energy is transfered to the source battery. An external discharging resistor will be available as option.
Voltage of discharged battery 1-49VDC
Discharge current 0.3-10A depending on type/capacity of source battery
Max. discharge power cca 150W
Manual mode for NiMH, NiCd, Pb, Li-xx cells (any Lithium based cells)
Cycle Mode
Number of cycles discharge/charge 1-9 (user programmable)
Delay time between charge/discharge or discharge/charge cycles 1-60 mins
PC-Interface/Data Format
Charging 1:ttttt:uuuuu:iiii:0AH 0DH
Discharging 1:ttttt:uuuuu:iiii- 0AH 0DH
Data output for PC serial line RS232, speed 9600Bd,1Start Bit, 8 Data Bits, 1 Stop Bit, No Parity (software is included)
Additional
Number of user-defined settings 9
Display LCD 2 x 16 characters, backlight viewing area 95 x 20mm
Weight aprox. 1300g
Dimensions 130x160x70mm
Operational environment temperature -5 ... +50°C
Contact: sheldon@yntdesign.com - A Soaring Nationals Supporter
YNT uDesign is the North American Distributor for the PowerCube
       Post #: 1
RE: New Product - PowerCube Battery Analyzer - 8/4/2005 11:00:31 AM
JNorton
Status: offline
Quite interesting. I like out of the box thinking and the PC interface is exceptional. Do you plan on having a distributor in the states?
John
< Message edited by JNorton -- 8/4/2005 11:09:18 AM >
_____________________________
Have desk ... Will Fly....
Saito Member #467
(in reply to YNT uDesign)
       Post #: 2
RE: New Product - PowerCube Battery Analyzer - 8/7/2005 7:59:50 PM
YNT uDesign
Status: offline
You can contact YNT (see the website) for information, quesitons, and orders.
I've now got the website updated with more information on the PowerCube but still have a little "tweaking" to do. Soon I'll have some examples of the tests that I, myself, have performed. We're also planning on developing an updated version of the documentation, with more specific examples and samples procedures, to meet the needs of the North American market.
-Sheldon-
YNT uDesign
(in reply to JNorton)
       Post #: 3
RE: New Product - PowerCube Battery Analyzer - 8/8/2005 12:45:48 AM
RPM
Status: offline
YNT uDesign -
Very interesting unit.
FWIW, I for one would prefer a direct USB connection rather than having to use an RS232 with a Converter. Of course, that's just MHO.
Good luck with it.
       Post #: 4
RE: New Product - PowerCube Battery Analyzer - 8/8/2005 1:57:36 AM
YNT uDesign
Status: offline
I hear ya' RPM, I hear ya'. The designers are working on it as we speak. I have no idea why they just didn't implement USB to begin with, but the RS232 is working flawlessly and I have no issues there. The other addition that I, personally, would like to see is a temp probe safety sensor. I've not had any problems with ANY of the packs that I've been working with. I have an infrared temp gun and frequently check the temperature as they charge or discharge. Haven't run into any thermal issues to this point, but I'd feel a little better with the addition of a temp probe cut-off, as I say, as an additional safety device.
Thanks for the good-luck wishes!
-Sheldon-
YNT uDesign
(in reply to RPM)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.641RCU1
