RE: Yak 54 .40-.50 ARF need help with pull-pull elevator setup
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Sport Flying >> RE: Yak 54 .40-.50 ARF need help with pull-pull elevator setup Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: Yak 54 .40-.50 ARF need help with pull-pull elevat... - 11/9/2005 11:51:17 AM
BaldEagel
Status: offline
NV
this is the pic in my manual its for a Yak 54 @ 52" span and for 2C 46~50 and 4C of 52~63 hope this helps its in a very bright yellow and blue colour as shown in earlier posts.
Mike
Click to see fullsize image.
Click for fullsize
_____________________________
No matter what anyone says 100% is the maximum you can get.
(in reply to NV)
       Post #: 26
RE: Yak 54 .40-.50 ARF need help with pull-pull elevat... - 2/11/2006 3:54:17 PM
Dennis H.
Status: offline
quote:
ORIGINAL: STLPilot
My UltraRC Yak-54
I was looking at your photo, The first one, the close up of your engine, It look like you have your engine servo mount on the fire wall? If so, how did you connect your thor. cable? Can you show some photo how you did it?
I'm putting a Satio 100 in mine.
Dennis
(in reply to STLPilot)
       Post #: 27
RE: Yak 54 .40-.50 ARF need help with pull-pull elevat... - 2/12/2006 5:08:00 PM
Jonathan.Lam
Status: offline
Where can u buy ultra rc's yak 54?
Jonathan.Lam
(in reply to BaldEagel)
       Post #: 28
RE: Yak 54 .40-.50 ARF need help with pull-pull eleva... - 2/12/2006 5:24:44 PM
Dennis H.
Status: offline
Hi, You can get it here!
http://www.ultrarc.com/yak50/index.htm
A very nice ARF, I'm still working on mine, slowly lol....
Dennis
(in reply to Jonathan.Lam)
       Post #: 29
RE: Yak 54 .40-.50 ARF need help with pull-pull eleva... - 2/12/2006 7:34:19 PM
Jonathan.Lam
Status: offline
thanks but the thing is that i live in the uk and i dont know how much it will cost to ship and how long it will take
thanks for your reply
Jonathan.Lam
(in reply to Dennis H.)
       Post #: 30
RE: Yak 54 .40-.50 ARF need help with pull-pull eleva... - 2/12/2006 7:43:42 PM
Jonathan.Lam
Status: offline
and also can i ask anyone if they have any videos of their yak 54 flying
thanks alot if you could put in a thread
Jonathan.Lam
       Post #: 31
RE: Yak 54 .40-.50 ARF need help with pull-pull eleva... - 2/12/2006 7:57:56 PM
Dennis H.
Status: offline
Hey, you can e-mail them what the cost would be, or if there is a dealer in the U.K.
       Post #: 32
RE: Yak 54 .40-.50 ARF need help with pull-pull eleva... - 2/13/2006 10:06:26 AM
Jonathan.Lam
Status: offline
can anyone giv me any videos of their yak 54?
Jonathan.Lam
       Post #: 33
RE: Yak 54 .40-.50 ARF need help with pull-pull eleva... - 2/13/2006 10:11:38 AM
Jonathan.Lam
Status: offline
also can i ask how comes FLAIR's and JAMARA's yak 54 .50 is the same as ultra rc's yak 54?
Jonathan.Lam
       Post #: 34
RE: Yak 54 .40-.50 ARF need help with pull-pull eleva... - 2/13/2006 4:18:11 PM
BaldEagel
Status: offline
Lil chinky
Flair inport the YAK from China into the UK, Ultra inport into the USA.
The Pic below shows how I arranged my servos to give Ailivators ie independant elevator response as ailerons, also full closed loop linkages used, this is my second YAK my first one I crashed by my own volition my fault, a high aspect ratio wing llike the one on the YAK will tip stall if you pull too much elevator too quick, this is not a fault, but is how you get an extreamly manouverable aerobatic aircraft, you make it unstable.
Mike
Click for fullsize
       Post #: 35
RE: Yak 54 .40-.50 ARF need help with pull-pull eleva... - 2/13/2006 8:05:43 PM
Jonathan.Lam
Status: offline
also can i ask you about how it flies like --- Excellent --- Good --- OK --- Crap
Jonathan.Lam
       Post #: 36
RE: Yak 54 .40-.50 ARF need help with pull-pull eleva... - 2/14/2006 12:47:14 AM
Dennis H.
Status: offline
Hi Mike, That a neat setup you got there! As you know the throttle servo, there not much room to get your hands in there and srew the sevro down, did you mount the sevro there, or some other place? If so in other place, can you post a photo of where you put it?
I'm thinking of putting it on the fire wall, with the engine, what engine are you useing? I'm going with a Satio 100.
Dennis
       Post #: 37
RE: Yak 54 .40-.50 ARF need help with pull-pull eleva... - 2/14/2006 1:18:38 PM
BaldEagel
Status: offline
Dennis
On my first YAk I mounted the servo at the top of the fus just by gluing it there, this was required to make a decent job of the push rod allignement due to using a four stroke (OS70) which incidently was over powered. Satio 100 I think you are asking for lots of torque rolling tendancies on throttle with that one.
In this one I'm using a JEN 56 two stroke with a pitts silencer to keep the cowl neat, being a two stroke the carb is in such a position that the standard mount works, I did not have a problem getting the screws in just used a very long screwdriver, so it all depends on your carb position.
This aircraft is not an easy 3D machine it will bite if you let it get the better of you, but its snap manouvres are the best i'v seen or ever done, they are so quick, I did perfect with my first YAK a climbing snap roll, that was inpressive, just dont overdo the elevator movement or slow it up too much on landing, I also have reinforced the undercarridge area with carbon tows as a bit of a preventive measure, I thought it was a bit fragile for our grass strip.
Mike
Click for fullsize
< Message edited by BaldEagel -- 2/14/2006 1:22:26 PM >
       Post #: 38
RE: Yak 54 .40-.50 ARF need help with pull-pull eleva... - 2/15/2006 1:30:15 AM
Dennis H.
Status: offline
Mike, Thanks for the photo. maybe I'll try a longer sevro arm for the thor. link to clear the fuel tank. I don't think I'll try 3D with it, I have a Jap. Zero and it will snap too, with to much elev. too! On your control, on the low side, did you go by the book? On the CG where did you set yours? I'm planing starting at the 80mm and see how it gose from there.
Dennis
       Post #: 39
RE: Yak 54 .40-.50 ARF need help with pull-pull eleva... - 2/15/2006 1:38:49 PM
