RE: Sig Something Extra Kit
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Sig Something Extra Kit
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: Sig Something Extra Kit - 8/26/2005 2:35:59 AM
DamonTX
Status: offline
Dale...Below are a few pics of one of my old SSE's that is starting to show it's age (built on a TV stand during one of my cross country moves). The receiver battery is braced just ahead of the landing gear mount block. I hear some people are building hatches under the fuel tank and that sounds like a great idea. If I had done that on this plane I probably wouldn't have needed the heavy hub to balance it.
The other pic is just a picture of the stabilizer where I always write the channel #, weight and make a little mark for each flight.
Damon
Edit---Wanted to point out the aileron and elevator hinges are done with Monokote and have held up for almost 4 years and almost 60 flights. A lot of people boo hoo this idea but I'll tell ya, there is no chance of flutter and it doesn't look like it's anywhere near failing.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to SLOWFLY58)
       Post #: 76
RE: Sig Something Extra Kit - 8/26/2005 2:49:38 AM
tychoc
Status: offline
My battery is stuck under the tank as far forward as possible. I used velcro and stuffed foam around it.
-tychoc
_____________________________
Good judgement comes from experience. Experience comes from bad judgement.
       Post #: 77
RE: Sig Something Extra Kit - 8/26/2005 2:58:45 AM
MannyEdge
Status: offline
DamonTX:
That looks GREAT!!! Can you cover my plane, when will you be in Nashville?? I hope I can do have the half the job you did. Where is the other plane? Want to see the double fuselage.
Team Losi 8ight, O.S. .21 VG, Hitec Servos 5955 all around & Specktrum DX3.0
(in reply to DamonTX)
       Post #: 78
RE: Sig Something Extra Kit - 8/26/2005 3:23:09 AM
DamonTX
Status: offline
Manny...I posted pics of the twin earlier tonight. It ended up on the previous page, post #72. LOL!!!! The last time I was in Nashville was two years ago when I drove through there when I moved from Dallas to Vermont. Moving again next spring but Nashville is a wide swing when you're going from Vermont to North Carolina.
(in reply to MannyEdge)
       Post #: 79
RE: Sig Something Extra Kit - 8/26/2005 4:41:33 AM
MannyEdge
Status: offline
Hey DamonTX:
I missed those replies. All I have to say WOW LOL!!! You sure are a very good builder.
I was working on my Edge and I made a mistake on the joiners for it. I put the right front joiner in the rear. I cannot believe I made that mistake. I emailed VF and I have to wait to see what I need to do.
I was even taking my time.
       Post #: 80
RE: Sig Something Extra Kit - 8/26/2005 7:12:58 PM
DamonTX
Status: offline
Manny..Oh boy! Has VF gotten back with you yet? I'd like to know what their fix is. Hopefully they'll send you another joiner and you can make due with having the front one in the rear.
Dale & Tychoc have you guys got any pics...and have you figured out what you're gonna do with the battery? If you can, it would be nice to see some pics of any ideas for having an access hatch under the tank. I think I'm going to delay covering that area until I can see where the balance is going to fall so I can have the option to put a hatch there if need be.
       Post #: 81
RE: Sig Something Extra Kit - 8/26/2005 8:05:52 PM
tychoc
Status: offline
I was playing with the idea for a hatch for the tank compartment and/or battery up front but decided to scratch the idea on my first build. Partly because the manual discouranged this due to structual strength, although, I've seen many having at least done the tank hatch.
I'm at work now, but my battery installation basically consisted of putting a piece of velcro up front under the tank. The battery is stuck in there pretty good now, in fact, when trying to remove it I had to use a flat metal ruler to release the grip of the velcro since there's not enough space to get your fingers in there.
I'll see if I can't post a picture later tonight. The more I read, the more convinced I'm that putting a hatch in is generally a good idea. A little planning/work up front could possbly save tons of work later
-tychoc
       Post #: 82
RE: Sig Something Extra Kit - 8/26/2005 8:53:44 PM
daven
Status: offline
The C.G. on the SE is extremely conservative. I was at least a half inch behind the recommended spot and it still landed like a trainer. I really doubt you will need your battery up that far to fly this plane. Maybe for the first couple of flights, but it flies much better with the C.G. back further.
Dave Norman
klasskote.com
supertrc.com
(in reply to tychoc)
       Post #: 83
RE: Sig Something Extra Kit - 8/27/2005 8:49:17 PM
PointMagu
Status: offline
GREETINGS!
Just bought a 95% completed SSE from a fellow builder. There's still plenty to do and all the parts appear to be in the box, 'cept the landing gear.
Problem is, no plans and no construction manual. I'll get by without the plans but I'd sure like a copy of that construction manual if anyone out there has theirs in PDF format, (or otherwise). I know I can buy one from SIG, (Top Flite has theirs on their website for their kits...)
but I really don't wanna order them if I can download a copy from another modeler.
Appreciate any assistance rendered.
Don
(Point Magu)
Ah yes, snakes in the cockpit....
       Post #: 84
RE: Sig Something Extra Kit - 8/27/2005 10:56:47 PM
SLOWFLY58
Status: offline
Hi Damon
Here's a couple of ideas you might try. I used an 1100mil flat pack and with a bit of trimming on the back of the tank tray managed to get it to fit very nicely under the bottom rear of the tank. This is probably similar to what Tychoc did with the velcro tape. The only draw back is the tank must be removed to get the battery out. As per making a hatch the quickest way I could think of would be to cut FB-2 and add some 1/4" square braces and small screws to close the hatch. With this area being so tight I don't think you can get a square pack in there. Also I don't know if you could get the battery in the front half of the tank compartment as I already had FB-2 in place before I saw your post.
Are all of these kits coming out this tail heavy ??
Are you using the wheel pants ??
The reason I ask is that I will not be using them as I am using a larger 60 size gear, I checked the weight on the wheel pants and they came in at 3oz. Thought maybe not using the pants was contributing to the tail heaviness, Though they are not on the front of the plane they are in front of the CG balance point. I am not sure how far this would throw the balance to the rear.
Sorry I did not reply faster but I have been setting up this new computer and transferring everything from the old one I will get some more pics on tomorrow.
Dale
Click for fullsize
Click for fullsize
< Message edited by SLOWFLY58 -- 8/27/2005 11:30:38 PM >
GETTING BORED WITH THE SAME OLD PLANE AND THE SAME OLD FLYING ROUTINE ??? TRY A FULL THROTTLE INVERTED TOUCH AND GO !!!
       Post #: 85
RE: Sig Something Extra Kit - 8/28/2005 7:49:03 AM
DamonTX
Status: offline
Dale...Every one I've done has come out tail heavy and I haven't heard of anyone who hasn't had the same experience. It might not be if we didn't put the flying wires on the tail and I'm not doing it one this one because it would look dumb with twin fuselages.
I'm also not using the wheel pants on this one since our field is grass and kind of rough in places.
Tonight I covered the bottom of the fuselages then remembered about the hatch! Oh well, maybe next time. With twin engines, it might be nose heavy anyway.
Damon
       Post #: 86
RE: Sig Something Extra Kit - 8/29/2005 3:14:46 AM
MannyEdge
Status: offline
What type of spinner are you using? I am thinking about putting a tru-turn on mine. I would think that would add weight. I am also going to put on the OS 70 II engine. That gives about 3 oz more than OS .46AX. What kind of engines are people putting on? I am wondering if I will have the same problem everybody else is having since I am putting on different items explained above.
< Message edited by Manny5150 -- 8/29/2005 3:23:39 AM >
       Post #: 87
RE: Sig Something Extra Kit - 8/29/2005 3:20:42 AM
DamonTX
Status: offline
Manny...You might just balance right on with that engine without adding weight anywhere. I recently switched from Tru-Turn to the Great Planes spinners, they run about $5 less for a 2.5" spinner and are shinier.
Damon
       Post #: 88
RE: Sig Something Extra Kit - 8/29/2005 3:30:20 AM
