RE: Bad Boy V2 Build!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: Bad Boy V2 Build!
Page: <<   < prev  6 7 8 9 10 11 12 13 [14] 15   next >   >>
Login
RE: Bad Boy V2 Build! - 10/5/2005 3:41 AM
flyboyz43
Score: 100
Last Login: 6/7/2009
Status: offline
Here is a few photos of my Bad Boy without the wing tips.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to flyboyz43)
       Post #: 326
RE: Bad Boy V2 Build! - 10/5/2005 11:59 AM
Precision Aerobatics
Score: 100
Last Login: 12/24/2009
Status: offline
That's great shots, well done to the camera man!!
Man what a field you’ve got there!!
Do you have higher res format of those photos?
Shaun
Precision Aerobatics Team
Hide Signatures
       Post #: 327
RE: Bad Boy V2 Build! - 10/5/2005 7:22 PM
flyboyz43
Score: 100
Status: offline
I'll have to check with the cameraman on the higher res photos. I'll also tell him what a good job he did on the picture taking. I had a heck of a time trying to get him to stand behind and off to the right of me to take em.
Hide Signatures
(in reply to Precision Aerobatics)
       Post #: 328
RE: Bad Boy V2 Build! - 10/13/2005 7:27 AM
onemetre
Score: 100
Last Login: 5/11/2008
Status: offline
Sorry in advance for my dumb question. How does the tail wheel stay on when mounted the PA recommended way? It looks like the one wheel collar keeps it from going up to far. When keeps it the other way?
Rob
Hide Signatures
       Post #: 329
RE: Bad Boy V2 Build! - 10/13/2005 7:44 AM
novabill
Score: 100
Last Login: 5/5/2013
Status: offline
quote:
ORIGINAL: onemetre
Rob
Are you mounting it to be steerable?
_____________________________
William McClooney
Hide Signatures
(in reply to onemetre)
       Post #: 330
RE: Bad Boy V2 Build! - 10/13/2005 5:01 PM
onemetre
Score: 100
Status: offline
I was going to go with the recommended non-steerable method. My preference is to go with the solution that's robust. What do you recommend and how do I do it?
Rob
Hide Signatures
(in reply to novabill)
       Post #: 331
RE: Bad Boy V2 Build! - 10/13/2005 5:06 PM
novabill
Score: 100
Status: offline
quote:
ORIGINAL: onemetre
Rob
I would just set it up to be steerable. To do that, you just drill a hole in the rudder and bend the wire @ a 90 degree angle to insert it into the rudder. The collar just prevents additional stress on the rudder on rough landings. It'll hold up just fine.
www.carolina3d.com
William McClooney
Hide Signatures
       Post #: 332
RE: Bad Boy V2 Build! - 10/20/2005 1:28 AM
Primodus
Score: 100
Last Login: 1/1/2008
Status: offline
Hey, have you guys died? Or are you too busy flying the wings off your Bad Boy V2's like I am?! This thing gets better all the time. And, it makes me look alot better than I am at 3D. Anyone even thinking of getting one of these should jump on it while they are still in stock. Maybe Novabill will chime in with a stock status?
I fly all my planes like I am mad at them, so if I crash I can't be anything but happy.
Hide Signatures
       Post #: 333
RE: Bad Boy V2 Build! - 10/20/2005 1:38 AM
novabill
Score: 100
Status: offline
STATUS UPDATE.
Only 16 Bad Boys left. They are all red and have been test fit to assure perfect planes. These last planes won't last long, so if you have been thinking about ordering, you better get off your duff
www.carolina3d.com
William McClooney
Hide Signatures
(in reply to Primodus)
       Post #: 334
RE: Bad Boy V2 Build! - 11/1/2005 6:13 AM
onemetre
Score: 100
Status: offline
What's the preferred method of running the antenna? My preference will be to mount it so the BB can be stored / transported with the wings off.
Rob
Hide Signatures
       Post #: 335
RE: Bad Boy V2 Build! - 11/1/2005 8:53 AM
Score: 100
Status: offline
quote:
ORIGINAL: onemetre
Rob
Per the instruction manual. Drill a hole in the rx wing and stick the antenna out through a piece of fuel line tube and attach it all the way over the black cover strap with sticky tape
Simple
Shaun
Hide Signatures
       Post #: 336
RE: Bad Boy V2 Build! - 11/2/2005 4:17 AM
novabill
Score: 100
Status: offline
Check out this video of Kyle flying e-BB #2 this stuff is awesome.
E-FLIGHTLINE is one of our official dealers and you can order through them at www.e-flightline.com
http://www.e-flightline.com/movie.htm you have to click on this link and then right click on the picture of the Bad Boy and save target as...
Enjoy the vid....it's the best BB footage yet!!!!
William McClooney
Hide Signatures
       Post #: 337
RE: Bad Boy V2 Build! - 11/3/2005 4:15 AM
Cobri
Score: 100
Last Login: 4/7/2007
Status: offline
Good day guys,
Yep we ( www.e-flightline.com ) are very happy to add Precision Aerobatics to the line aircraft we are sell and powering. Here are the specs for our BB.
Specs on the Bad Boy are as follows:
Wingspan 53 inches
Wing area 805 sq/in
AUW 4lbs 9oz
Motor Mega 22/30/2 (gas version is 46 size)
Gearbox Mini Inner Demon 3.5:1
ESC Castle Creations Phoenix 60
Battery pack Tanic 3s2p 4440
Prop APC 19x8 (yep that big)
Static Amp 49.8 amps
If you have any questions please just let me know. Ill post some pix once I figure out how to do thumbnails.
Splash
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 338
RE: Bad Boy V2 Build! - 11/3/2005 5:15 AM
Score: 100
Status: offline
Outstanding photos Splash !!
Have you considered one pack setup instead of two?
Also going with smaller prop?
Shaun
Hide Signatures
(in reply to Cobri)
       Post #: 339
RE: Bad Boy V2 Build! - 12/17/2005 10:52 PM
novabill
Score: 100
Status: offline
Stay tuned As we will be posting the new website this weekend. It will have new products as well as some video links.
William McClooney
Hide Signatures
       Post #: 340
RE: Bad Boy V2 Build! - 12/18/2005 5:51 AM
novabill
Score: 100
Status: offline
OK, I had to put it up 99% complete because of the new product release. I'll get the link to the home page and the picture thumbnails working soon.
Check it out. The video page will be up in a week and it'll have 30 or 40 vids on it.
www.carolina3d.com
< Message edited by novabill -- 12/18/2005 6:07 AM >
William McClooney
Hide Signatures
       Post #: 341
RE: Bad Boy V2 Build! - 12/18/2005 7:11 AM
dhooks
Score: 100
Last Login: 5/10/2012
Status: offline
Killer site dude, I see you have the new V2 Katana 40 an 70 there too.
Dan - TEAM ME
Hide Signatures
       Post #: 342
RE: Bad Boy V2 Build! - 1/5/2006 2:26 AM
novabill
Score: 100
Status: offline
GO HERE TO WIN A FREE BAD BOY
http://www.rcuniverse.com/forum/m_3731923/anchors_3731923/mpage_1/key_/anchor/tm.htm#3731923
William McClooney
Hide Signatures
(in reply to dhooks)
       Post #: 343
RE: Bad Boy V2 Build! - 1/24/2006 5:21 PM
joel231
Score: 100
Last Login: 4/26/2007
Status: offline
I am just about to order my Badboy. And i have a Katana Mini, and was very impressed with the quality of that plane from PA. But what i want to know is would standard futaba s3003 servos be sufficient for this plane, or will i need something a bit better. As im working on a budget. I have the engine a OS 46AX which from what i have seen should power it just nicely.
Cheers Joel
if its broke hit it with a hammer... if its still broke... add duct tape!
Hide Signatures
       Post #: 344
RE: Bad Boy V2 Build! - 1/24/2006 8:48 PM
novabill
Score: 100
Status: offline
Those servos will be fine.
William McClooney
Hide Signatures
(in reply to joel231)
       Post #: 345
RE: Bad Boy V2 Build! - 1/27/2006 10:55 PM
novabill
Score: 100
Status: offline
Hey all,
We have announced the new name on the rename Carolina 3D threads.
Go here
http://www.rcuniverse.com/forum/m_3731923/mpage_4/key_/tm.htm
http://www.rcuniverse.com/forum/m_3832308/tm.htm
William McClooney
Hide Signatures
       Post #: 346
RE: Bad Boy V2 Build! - 8/24/2007 7:19 AM
674nathan
Score: 100
Last Login: 6/8/2010
Status: offline
I have balanced my badboyv2 and when flown for its 1st time it was rolling left quite a bit to level it i had to add 60grams to the right wing anyone have any suggestions?
Hide Signatures
       Post #: 347
RE: Bad Boy V2 Build! - 8/25/2007 5:56 AM
Score: 100
Status: offline
You definitely don’t need the 60gr weight
Check for any warp in the ailerons from rear view and use a heat gun to fix this warp if any
Email us directly to: support@precisionaerobatics.com and we will help you out if needed
Shaun
Hide Signatures
(in reply to 674nathan)
       Post #: 348
RE: Bad Boy V2 Build! - 1/10/2008 12:31 AM
RoysterDW
Score: 100
Last Login: 5/19/2013
Status: offline
Which engine?
What engine would best suit the BB:
I have an OS 70 Surpass 4 stroke and an OS 55AX 2 stroke and also a Rossi 40. I know the 70 has been used but does that mean adding a ton of lead in the tail to balance it?
I do have a 46AX but thats in another plane.
Hide Signatures
       Post #: 349
RE: Bad Boy V2 Build! - 1/10/2008 3:17 AM
Dave McDonald
Score: 115
Last Login: 5/21/2013
Status: offline
Given those three options, the OS 55AX is the hands down winner.
An APC 13x4 on the 55 AX will make that BB into a very capable 3D machine.
McDDD
ProBro 415
Hide Signatures
(in reply to RoysterDW)
       Post #: 350
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.891RCU1
