RE: Great planes ultimate 160    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Great planes ultimate 160 Page: <<   < prev  267 268 [269] 270 271 272 273 274 275 276   next >   >>
Login
RE: Great planes ultimate 160 - 11/14/2011 12:17 AM
Uncas
Score: 105
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: huntndux
OK Guys, I need some help.  Can someone show me how you came out of the top wing and into the fuse to hook up your servo leads.  I have about 6 inches of servo lead hanging out of each upper half of my wing.   I was thinking I could just push what I dont need back into the hole of the wing and install some sort of plug to keep it in there, then attach the Y and hook somewhere on the cabane.  A picture or two would help me if you have one to share.
I also bought a 4titude 16 oz gas tank.  Any thoughts on how to do a nice install with that.  I may have to buy some balsa and engineer it.
Thanks for any help
I ran the aileron leads out of the top wing then hooked them to a Y connector, then shoved everthing back in as far as I could up to the Y, then used blue tape to secure it. Out of a fuse cabine slot (had to be enlarged a little) I ran a female connector and I duct taped it to a cabine. So I can unplug the top wing at the cabine strut. All of my ailerons run off a single receiver output channel. They are all Y-d together and mechanically set. So I have 3 sets of Y's for the ailerons. 1 for the top wing, one for the lower wing, and one for the receiver that the wings plug into.
Hide Signatures
(in reply to huntndux)
       Post #: 6701
RE: Great planes ultimate 160 - 12/2/2011 8:23 PM
mrdhud
Score: 110
Status: offline
Hello all
I have the GP 160 ultimate still in the box and a Zenoah G 45 sitting on the shelf. Do you think this engine would work?? Any thoughts would be appreciated.
Dan
_____________________________
Dan Hudson WACO Brotherhood #45
GIT-ER-DUN "Build a WACO"
Hide Signatures
(in reply to Uncas)
       Post #: 6702
RE: Great planes ultimate 160 - 12/3/2011 1:02 AM
iflywhenican
Score: 100
Last Login: 5/15/2013
Status: offline
quote:
ORIGINAL: mrdhud
Hello all
Dan
I sure wouldn't let it go to waste....I think that it will do just fine, maybe a bit down on power, but that is all according to what type flying you do. If not mistaken, somewhere in all of this thread, someone did just what you are wanting to do.
If you have to bend over more than once, it wasn''t a good landing....
Hide Signatures
(in reply to mrdhud)
       Post #: 6703
RE: Great planes ultimate 160 - 12/3/2011 5:36 AM
noterman
Score: 105
Status: offline
I flew mine with a Quadra- 40. It had better than scale power, but would not hover. If you don't fly 3D it would be fine.....
Hide Signatures
(in reply to iflywhenican)
       Post #: 6704
RE: Great planes ultimate 160 - 2/18/2012 10:52 AM
PropsnWings
Score: 110
Status: offline
Forgive me if I have overlooked the information, but where would I find some CF to do the wing joiner mod?
And what was used to apply this mod? (epoxy?)
quote:
ORIGINAL: a1pcfixer
quote:
ORIGINAL: bubbagates
quote:
ORIGINAL: a1pcfixer
Would embedding a strip or two of flat CF, into each wing joiner, help strenghten that - prior to assembling a new GP Ult?
Jim,
Sorry, I did miss this...
I beleive it would. It certainly could not hurt...
Here's 2 photo's of my modified wing joiners;
Hide Signatures
(in reply to a1pcfixer)
       Post #: 6705
RE: Great planes ultimate 160 - 2/18/2012 11:16 AM
PropsnWings
Score: 110
Status: offline
I forgot to add my other question,
What would be the minimum gas engine to hover this plane with?
Hide Signatures
(in reply to PropsnWings)
       Post #: 6706
RE: Great planes ultimate 160 - 2/18/2012 1:20 PM
iflywhenican
Score: 100
Status: offline
P&W...You can usually get the carbon fiber strips at your local hobby store. The answer to your second question, IMO would be a 50cc and no less. You could probably hover with a smaller engine, but your pullout would not be there.
Cut a new wing joiner out of either hardwood or pine and you would not need the carbon fiber. I used the suppplied joiner with Gorilla Glue and have not had any problems and I have been flying it since the beginning of this thread.
Hide Signatures
       Post #: 6707
RE: Great planes ultimate 160 - 2/18/2012 1:29 PM
PropsnWings
Score: 110
Status: offline
Thanks! I sure appreciate the info.   I may have a DA50 for it. (working a deal for seller to send to DA for inspection before I buy)  I think that would be a nice combo.
quote:
ORIGINAL: iflywhenican
Hide Signatures
       Post #: 6708
RE: Great planes ultimate 160 - 2/18/2012 2:20 PM
a1pcfixer
Score: 168
Last Login: 8/16/2012
Status: offline
quote:
ORIGINAL: PropsnWings
I got my CF strips from a LHS, but they can be found online in various hobby shops. The mfg of mine is Midwest Products Co., Inc....a few miles away from me actually. Part #5744 - .092 x .220 x 24" $5.59
I cut (2) 6" strips, used my Dremel and a carbide router bit to create the 'trench', then used J-B Weld, and layed the strips into place. Afterwards, each sits maybe 1/16" below surface level. That's important (at least to me), so that when I epoxy the joiners into the wings, then some epoxy wil bond into the groove as well.
I'd considered a tube style piece of CF, but don't have a drill long enough. Ya'd think that after 30 years of being a machinist, I'd have every size, length, and size concievable.
As for why I did this; considering I'll have round abouts 2 grand wrapped up in it, such a simple mod seems so appropriate.
But, for every thing we strengthen, something else may then fail.
As to whether or not it's needed, Bob put it very well....
"Whether or not "needed", it is apparent that this is an area of improvement that could be made, with little hassle, little weight gain, possible significant strengthening of a very stressed joint. "
Btw, there's been only a few reports (in this thread) of wing failure, which might -or- might not be an issue to the majority of us. My take on it is why take the risk, when a simple fix is so easy.
As to hovering & eng choice, I'm running a DA-50r with smoke and two tanks and AUW of 16.5 lbs, and I can easily hover at around abouts 60% throttle. Pull-outs are easy!
Click to see fullsize image.
Click for fullsize
Jim L.
Learn from the mistakes of others.You won,t live long enough to make all of them yourself.
Hide Signatures
       Post #: 6709
RE: Great planes ultimate 160 - 2/18/2012 2:44 PM
a1pcfixer
Score: 168
Status: offline
Here's another 'mod' which hasn't (yet) been added to the list.
It's something that's NOT needed, but sure does make assembling at the flying field soooo much easier & quicker.....
http://www.rcuniverse.com/forum/fb.asp?m=10734614
Might want to drill out the two holes in the "aluminum wing rib" before assembling the top wing & epoxying.
Kinda hard to drill after assembly.
Got the idea after watching my friend assembling his at the field and his fumbling with wrenches and cussing the whole time.
Jim L.
Hide Signatures
       Post #: 6710
RE: Great planes ultimate 160 - 2/18/2012 2:45 PM
bubbagates
Score: 121
Last Login: 5/17/2013
Status: offline
I'd agree with everyone else so far. A decent 50cc and you'll have a mini-missile on your hands, start out with a 22x8 to get a decent pull and then move to a 22x10 or a 23x8, you want to keep the pitch down since any biplane is a draggy plane and needs pull to help it, not speed (higher pitch number = more speed). You definitely do not want to fly this plane fast, those are huge elevators and flutter is a very real possibility but it's slow speed abilities will astonish you. Be mindful of your throws as well, especially on the ailerons. The book throws are OK but on low rates it will still roll amazingly fast so be ready for it. You have 4 of those bad boys and they are powerful, though just a tad bit on the weak side in a hover. I've added some right thrust to mine to help with tracking and it seemed to help with torque rolling in a hover as well but then I fly IMAC and I am used to doing the trimming on all my planes and that means going way beyond the trim tabs on the TX.
I'd also do the wing joiners as well. CF works just fine but to me a better replacement is different wood. If you do use CF, then yes, epoxy is the way to go. I'd use at least 30 minute to give it time to soak into the wood as well. There will be more strength than shorter time epoxies and no difference in weight.
I used Gorilla Glue to join my wings, give the joiner area a nice mist of water, only a tiny bit, apply the glue, put everything together and tape the halves together tightly across the joint and not with the joint and babysit it for about 30 minutes or so as you will need to wipe away some of the foam every few minutes that you are going to get using rubbing alcohol. Once done, there is nothing that is going to separate the wings from each other. I did this with all of mine one but my first one was taken out in mid-air on approach and while totally destroyed, the wing joints did not separate one tiny bit, though everything around them was toast
Bill James
Hide Signatures
       Post #: 6711
RE: Great planes ultimate 160 - 2/18/2012 6:56 PM
PropsnWings
Score: 110
Status: offline
Well closed the deal on the DA-50-R .  Should see it in a week or so. Its being sent off to DA for a health check up before its final destination as my new power plant.
I like the idea of modding the wing attachment.  I have a smaller biplane that has the same method and yes at times its a pain!
For smoke system, I have in the past used the TME simple smokers.  I have a couple still,  are these ok, or are there better options out there now?
Would I need to purchase a smoke muffler for the DA or can I tap the stock muffler for smoke?
Hide Signatures
(in reply to bubbagates)
       Post #: 6712
RE: Great planes ultimate 160 - 2/18/2012 7:55 PM
a1pcfixer
Score: 168
Status: offline
I never (yet) used a TME, but have a Sullivan Skywriter on mine. If TME has worked well for you, stick with it.
If you have -or- want a smoke muffler, DA sells them pre-made, but I much prefer to simply drill & tap mine so I install the fitting in the hottest area of the muffler.
Here's some fittings;
http://www.troybuiltmodels.com/items/TBMSMOKEFITTING.html
http://shop.dubro.com/products/search/101.0?q=smoke&submit.x=0&submit.y=0
Now, as to where to locate your fitting. When the muffler is bolted on, the bolts pass through what's essentially two 'sleeves'.
I drill & tap mine so the fitting gets aimed at one of those bolt sleeves (above/below don't matter). You'll then have it located in THE hottest area of the muffler and aimed so the output gets sprayed.
Just be certain that it does NOT get any sort of direct aim to the exhaust port of you eng! That'll cause a engine flame out.
I've done mine as described above, and smoke output is AWESOME! I've had it where in a hover I couldn't see my bipe!
Jim L.
Hide Signatures
       Post #: 6713
RE: Great planes ultimate 160 - 2/26/2012 8:36 PM
acerc
Score: 221
Last Login: 5/24/2013
Status: online
Just picked me up one of these ulti's. Read the thread and plan on a few of the mod's. Jim, I have gotten good advise from you on many other thread's so, what would you say would be an adequate cc without being overpowered. I don't fly hard/ extreme 3-D.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 6714
RE: Great planes ultimate 160 - 2/26/2012 8:43 PM
bubbagates
Score: 121
Status: offline
I don't know it the fuji 45cc is still around but that was the recommended engine and I had one and properly propped it dig well. It was heavier than a da50 and almost the same price. Stick around 40 to 45cc and if you stay reasonably light and you'll be fine
Bill James
Hide Signatures
(in reply to acerc)
       Post #: 6715
RE: Great planes ultimate 160 - 2/26/2012 8:59 PM
acerc
Score: 221
Status: online
Just out of curiosity would a DLE 55 be to much or to heavy. I have one on the shelf.
Robert
Hide Signatures
       Post #: 6716
RE: Great planes ultimate 160 - 2/26/2012 9:05 PM
huntndux
Score: 100
Last Login: 4/16/2012
Status: offline
It will be a rocket.  Thats a great engine for this plane
Hide Signatures
(in reply to acerc)
       Post #: 6717
RE: Great planes ultimate 160 - 2/26/2012 10:35 PM
mstcitabria73
Score: 100
Status: offline
 with the DLE 55 in the nose and 3 servos in the tail my CG was dead on.........use it you will like it.
Hide Signatures
(in reply to acerc)
       Post #: 6718
RE: Great planes ultimate 160 - 2/26/2012 11:03 PM
acerc
Score: 221
Status: online
Ok, DLE 55 it is. Thank's gents.
Robert
Hide Signatures
(in reply to mstcitabria73)
       Post #: 6719
RE: Great planes ultimate 160 - 2/26/2012 11:07 PM
PropsnWings
Score: 110
Status: offline
It so awesome to see interest in this bi plane still.  I have not started on mine yet, but have been reading this thread, and gathering all my components.  Power will be the DA50r  Using Power HD 9150's on Ail and Elev, with a Power HD 1218th on rudder.   Havent decided what to use for throttle yet.   Will be using my new JR 11X as guidance.
Hide Signatures
(in reply to acerc)
       Post #: 6720
RE: Great planes ultimate 160 - 2/27/2012 12:35 AM
a1pcfixer
Score: 168
Status: offline
quote:
ORIGINAL: acerc
Yep, your DLE55 will be a great match!
Mine has a DA-50r, but if I were to do it again I'd use a DLE55....just to save some $$.
Both use the same bolt patterns for both the eng mounting & prop drilling.
On your DLE55 if you haven't yet dumped that crappy stock DLE/3 plug, do so and get a NGK/CM-6 spark plug.
Honda number is 98052-56471, it's an NGK CM-6 in a Honda box.
At the auto supply store it's (NGK/CM-6) listed as a Stock #5812
Jim L.
Hide Signatures
(in reply to acerc)
       Post #: 6721
RE: Great planes ultimate 160 - 2/27/2012 12:40 AM
a1pcfixer
Score: 168
Status: offline
Bill,
Maybe you meant the Fuji 43?
Either way, Tower Hobbies no longer carries that brand nor will they service them.
The Fuji brand for us hobbyists is kaput! Parts will be hard to come by.
But it's claimed Fuji's commercial line will continue on.
Jim L.
Hide Signatures
       Post #: 6722
RE: Great planes ultimate 160 - 2/27/2012 1:04 AM
bubbagates
Score: 121
Status: offline
quote:
ORIGINAL: a1pcfixer
Bill,
Thanks for the correction Jim,
I never had much love for fuji but the 43 was a decent engine, at least the one I had I had it in the plane first then in the GP Cap232 but in the end the DA50 was the way to go. I also used a Brison 3.2 which basically was a 52 or 53cc (not really sure) which was a huge powerhouse on this plane as well but I do not think Brison is around anymore but then again, my knowledge with smaller gas engines and what is still around has twindled quite a bit since I'm pretty much a DA person any more using mainly 170cc and 200cc power plants
No doubt that any 50cc is the way to go on this plane, stuff one in the nose, use whatever spinner type you wish, personally I lite the CF Ultimate type of spinner the best but Aluminum works well (I did not use the included one at any time, seems a bit weak to me when tossing a good powerful gas engine in the plane), stuff the rudder servo in the tail, put everything else pretty much where the manual says and you'll be really close on balance with gobs over power. You can always throttle back to fly more scale like but there having the extra power is never a bad thing
Bill James
Hide Signatures
       Post #: 6723
a1pcfixer
Score: 168
Status: offline
It so awesome to see interest in this bi plane still..............
Yeah it sure has a long standing history & GP STILL produces them!
Other bipes come & go.
First post here that started this msg thread was by drumbum on 8/8/2005, and here we are 6 & 1/2+ years later still going.
This GP Ultimate must be related to the Energizer Bunny!
Jim L.
Hide Signatures
       Post #: 6724
RE: Great planes ultimate 160 - 2/27/2012 2:05 AM
acerc
Score: 221
Status: online
Thank's Jim, PnW, and Bill. Meant to say reading thread. And after the past couple hours it seem's the 55 would be the best choice. As for the spark plug, been there done that. Buy cm6's at the local lawn shop for $4. Right now my only real concern is with servo torque. What is truly sufficient. And whether to stay with the stock pipe or get a pitt's wraparound.
Robert
Hide Signatures
       Post #: 6725
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.109RCU1
