RE: Great planes ultimate 160    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Great planes ultimate 160 Page: <<   < prev  267 268 269 [270] 271 272 273 274 275 276   next >   >>
Login
RE: Great planes ultimate 160 - 2/27/2012 9:48 AM
a1pcfixer
Score: 168
Last Login: 8/16/2012
Status: offline
Considering the large size of this plane's ail/elev surfaces I went with Hitch HS-5645MG's there, and for that barn door rudder it got a HS-5955TG (current #HS-7955TG). The manual has settings for Low & high rates for control throws, but for myself I set it up to have a low/mid/high(3D).
On 'mid' level flying at 1/3 throttle, barrel rolls look like a Waring blender on 'puree' setting......flat out awesome!.....and a bit scary, I love it!
As for the muffler; a couple years back my flying buddy & I went to the Toledo RC Show and he talked with the folks from DA at their booth, regarding getting more ooompf out of his DA-50 (his Yak weighs almost 19#! - my Ultimate w/smoke is about 16.5#). They told him their stock single pipe muffler netted almost 200 more rpm on that -vs- a pitts style wrap around. In actual real world you can't notice the difference, but it IS louder! Now you're using a DLE55, but the results might be similar I'd guess. However this bird looks best with a pitts. Food for thought.
When I put this Ultimate together TBM was carrying a pitts wrap around they called a "Silent Beauty" which was baffled (sort of). It's ever so slightly quieter than the std pitts on my DL50 in my SD/TOC-260 Extra. Not sure if anybody carries those now days. Stock pitts have the 2 stingers welded onto the expansion chamber. On that 'Silent Beauty' they go all the way inside that expansion chamber but have side holes drilled into each stinger.....hence my 'sort of baffled' statement.
_____________________________
Jim L.
Learn from the mistakes of others.You won,t live long enough to make all of them yourself.
Hide Signatures
(in reply to acerc)
       Post #: 6726
RE: Great planes ultimate 160 - 2/27/2012 10:42 AM
PropsnWings
Score: 110
Last Login: 5/19/2013
Status: offline
What you using for throttle servo?  I, in the past have used just some cheapy  plastic analog that was laying around, but I can see where I might want to use metal gear and speedy for 3Ding.
Hide Signatures
(in reply to a1pcfixer)
       Post #: 6727
RE: Great planes ultimate 160 - 2/27/2012 12:39 PM
mstcitabria73
Score: 100
Last Login: 5/16/2013
Status: offline
acerc,
        I used the following Hitec servos;
Ailerons-5625 MG 1ea. (4)
Elevator-5985 MG 1ea. (2)
Rudder-7954 SH 1 ea.
Throttle-HS 635 1ea.
< Message edited by mstcitabria73 -- 2/27/2012 2:21 PM >
Hide Signatures
(in reply to acerc)
       Post #: 6728
RE: Great planes ultimate 160 - 2/27/2012 12:43 PM
a1pcfixer
Score: 168
Status: offline
HS-65MG, touted as being somewhat shockproof.
Used by many 3D/profile fliers.
Cheaper, lesser servos can be used, but consider that after all is said & done
it IS controlling a rather important feature of your model....the throttle!
Jim L.
Hide Signatures
(in reply to PropsnWings)
       Post #: 6729
RE: Great planes ultimate 160 - 2/27/2012 12:49 PM
acerc
Score: 221
Status: online
Thank's for the support guy's. But taking into consideration the mfg only call's for 50oz I'm going with Futaba 3010's. I have those on a 20cc profile and do very well with the size of control surface on it. If it don't go well with this ultimate I will let you all know and you all can say you told me so. I have a number of gas powered and never had a servo fail because of nylon gear's. We'll see with this one.
Again Thank's, Robert
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to mstcitabria73)
       Post #: 6730
RE: Great planes ultimate 160 - 2/27/2012 12:53 PM
acerc
Score: 221
Status: online
Take into consideration that for me the manual's low rate willl probably be my high.
Jim, I will be using the pitt's mostly for fit. Thank's!
PnW, 3010's on throttle as well.
Robert
Hide Signatures
(in reply to acerc)
       Post #: 6731
RE: Great planes ultimate 160 - 2/27/2012 12:56 PM
bubbagates
Score: 121
Last Login: 5/17/2013
Status: offline
Since I had a few JR8611's laying around that I had just rebuilt, that is what I used all around on my current one (yea I know, way overkill but I like overkill), but without looking at my posts way earlier in this thread, like 5 or so years ago, I seem to think I used 5645's everywhere and the servo that was the precursor to the 7955, I want to say it was a 5945 but that just does not sound correct.
As far as throttle is concerned, I would never ever use a used servo. I like fast servos for the throttle, especially for 3D. I have been using the HS-7775MG recently for all my throttle setups.
With a 50cc in the plane, I think I would go with the pitts muffler. I think it looks better, you do not have to chop a big hunk out of the cowl and the extra 200rpm you'll gain on the straight stack muffler will make really no difference in the end since this plane tends to come in around 16+/- lbs and that is just about perfect for a 50cc.
Bill James
Hide Signatures
       Post #: 6732
RE: Great planes ultimate 160 - 2/27/2012 12:58 PM
PropsnWings
Score: 110
Status: offline
Dont forget though, you are putting a 55cc on it, gonna have a bit more authority than what the manufacturer called for on engine size.
I use the 3010's on a 40cc and they are a great servo though.   Just all depends on flying style.
Hide Signatures
(in reply to acerc)
       Post #: 6733
RE: Great planes ultimate 160 - 2/27/2012 1:00 PM
acerc
Score: 221
Status: online
Holy cow Bubba.
Like I said, Their low will probably be my high, That should be a good indication of how mild my wild is.
Robert
Hide Signatures
(in reply to bubbagates)
       Post #: 6734
RE: Great planes ultimate 160 - 2/27/2012 1:03 PM
PropsnWings
Score: 110
Status: offline
quote:
ORIGINAL: a1pcfixer
I like the looks of that for throttle.... thanks !
Hide Signatures
       Post #: 6735
RE: Great planes ultimate 160 - 2/27/2012 1:57 PM
mstcitabria73
Score: 100
Status: offline
acerc,
       notice the pencil line drawn on the wood handle, it's at 1 inch from center of rear screw, with the wings off this is your CG location..........
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to acerc)
       Post #: 6736
RE: Great planes ultimate 160 - 2/27/2012 2:07 PM
blhollo2
Score: 204
Status: offline
i just got one with a moki 2.10 and it flys like a beast while remaining extremely light! unlimited everything and a real 3d monsta!
Hide Signatures
       Post #: 6737
RE: Great planes ultimate 160 - 2/27/2012 2:48 PM
PropsnWings
Score: 110
Status: offline
quote:
ORIGINAL: acerc
Where did you see that?  Just curious as this is the specs I have :
Ailerons: 4 servos at 98 oz-in torque Elevator: 2 servos at 98 oz-in torque Rudder: 1 servo at 100 oz-in torque or 2 @ 50 oz-in torque Throttle: 1 servo at 30 oz-in torque
Just thought I'd share ...
Hide Signatures
(in reply to acerc)
       Post #: 6738
RE: Great planes ultimate 160 - 2/27/2012 4:56 PM
a1pcfixer
Score: 168
Status: offline
quote:
ORIGINAL: mstcitabria73
acerc,
Check my list of links to 'mods' in Post #1, that one's covered there.
Jim L.
Hide Signatures
       Post #: 6739
RE: Great planes ultimate 160 - 2/27/2012 9:23 PM
acerc
Score: 221
Status: online
Got the 1inch thing, that will be handy. Here's my manual in regard's to the servo's. This is why I was holy cowing the suggestion's on torque. Now I went looking and Tower does list the above post torques. And on GreatPlanes web site they just say high torque but list the Futaba 3010 as the servo's. I bought everything I thought I needed this morning so well see.
Click for fullsize
Click for fullsize
Robert
Hide Signatures
       Post #: 6740
RE: Great planes ultimate 160 - 2/27/2012 11:11 PM
PropsnWings
Score: 110
Status: offline
Hmm, now I feel I went a bit overboard with my HD9150's on all but rudder and its a HD1218
Whats others thoughts?  Could I get by with lesser?   or should I just stick with my plan?
Hide Signatures
(in reply to acerc)
       Post #: 6741
RE: Great planes ultimate 160 - 2/28/2012 2:23 AM
a1pcfixer
Score: 168
Status: offline
You haven't stated their spec so I can't say.
But look at it this way, overkill & your fine......too little and, well....carry a trash bag.
Jim L.
Hide Signatures
       Post #: 6742
RE: Great planes ultimate 160 - 2/28/2012 2:42 AM
PropsnWings
Score: 110
Status: offline
HD9150
180 in oz @ 4.8
222 in oz @ 6.0
HD1214th
230in oz @ 7.4
200in oz @ 6.0
Both are metal geared, and the 1214 is double BB (rudder application)
I was kinda thinking this was a general range for a 50cc size plane?  I mostly have had 30cc and smaller planes.
Hide Signatures
       Post #: 6743
RE: Great planes ultimate 160 - 2/28/2012 4:02 AM
Rhino0_6
Score: 100
Status: offline
Awesome plane! I love mine it has a DLE 55 in it and will 3D all day long has all the power you are looking for. Brought up the wing load a little but nothing bad. Plane will land very nice do not have to keep to much throttle! I love the plane one thing that I would suggest is up grade the hardware on the ailerons! The stock gear will wear out and not hold as well hanger 9 pro links are the way to go.
Hide Signatures
(in reply to BoneDoc)
       Post #: 6744
RE: Great planes ultimate 160 - 2/28/2012 8:24 AM
a1pcfixer
Score: 168
Status: offline
quote:
ORIGINAL: PropsnWings
HD9150
180 in oz @ 4.8
222 in oz @ 6.0
HD1214th
230in oz @ 7.4
200in oz @ 6.0
Seeing as how you won't be running 5 servos @ 4.8v., and 1 @ 7.4v., but rather all @ 6.0v., I'd say you got 'em backwards so to speak.
You'd be better off with 4 ail servos of a bit less torque, but overall you'll do just fine. Nothing to fret about.
Jim L.
Hide Signatures
       Post #: 6745
RE: Great planes ultimate 160 - 2/28/2012 10:50 AM
PropsnWings
Score: 110
Status: offline
I goofed..... I shouldnt type when its that late lol
try this again
1214th (rudder) is 292in oz at 6v
9150's (ail,elev) is 200in oz at 6v
My thinking was the rudder needed a buit more push
< Message edited by PropsnWings -- 2/28/2012 11:12 AM >
Hide Signatures
       Post #: 6746
RE: Great planes ultimate 160 - 2/28/2012 2:06 PM
a1pcfixer
Score: 168
Status: offline
Ahhh, that's better!
You'll be fine.
Jim L.
Hide Signatures
       Post #: 6747
RE: Great planes ultimate 160 - 2/28/2012 2:44 PM
PropsnWings
Score: 110
Status: offline
quote:
ORIGINAL: a1pcfixer
You'll be fine.
Ya, it was very late when I typed that originally, and was looking down at my notebook at what I thought was specs for my servos, but was notes on some others I have been looking at.....   Well at least I know to stay out of the workshop when its after midnight lol....
Hide Signatures
       Post #: 6748
RE: Great planes ultimate 160 - 2/28/2012 3:39 PM
a1pcfixer
Score: 168
Status: offline
Used to be I'd go downstairs and work on a model for hours and hours. Now days,
I'll work on something for far shorty periods before getting to that point of 'I've had
enough' hits me. Besides, there's always tomorrow.
Jim L.
Hide Signatures
       Post #: 6749
RE: Great planes ultimate 160 - 2/29/2012 1:16 AM
Uncas
Score: 105
Status: offline
quote:
ORIGINAL: acerc
Here is the Great Planes Tech Note regarding servo torque:
Performance Series Ultimate Biplane 3D 1.60 ARF (GPMA1307)
Tech Note
June 18, 2008
Servos with a minimum torque rating of 98 oz-in must be used for all of the control surfaces of this plane (ailerons, elevators, rudder). However, there is an additional recommendation for the servos which is that they should have metal gears.
Hide Signatures
(in reply to acerc)
       Post #: 6750
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.969RCU1
