RE: Great planes ultimate 160    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Great planes ultimate 160
Page: <<   < prev  109 110 [111] 112 113 114 115 116 117 118   next >   >>
Login
RE: Great planes ultimate 160 - 9/11/2006 10:59 PM
Maudib
Score: 114
Last Login: 7/29/2011
Status: offline
A 5645 might not be enough alone... and twin ruddder servos have been done... but direct push-pull with two servos need to have special attention to matching performed or they may fight throughout the travel.
The cost of two 5645's i about the same as a 5955... and the latter will weigh less, provide less lash in the gear, one less failure point, easier setup and perform excellent.
If I had two 5645's I'd sell them to buy a 5955... just for these reasons...
Hide Signatures
(in reply to dubd)
       Post #: 2751
RE: Great planes ultimate 160 - 9/12/2006 12:09 AM
BoneDoc
Score: 100
Last Login: 4/18/2011
Status: offline
I think 1 x 5645 is probably enough for a 15 lb plane. However, having said that, 5955 is just so much better.
_____________________________
Josh
Hide Signatures
(in reply to Maudib)
       Post #: 2752
RE: Great planes ultimate 160 - 9/12/2006 12:23 AM
Slyder
Score: 100
Last Login: 6/2/2010
Status: offline
I have 5955 on rudder and 5645 on elevators.
Elevators are sloppy already.
Rudder is still tight as day one.
Wish they would make Titanium the standard for all metal gears. Wishfull thinking huh? Then sales would drop.
Eric H
Hide Signatures
(in reply to BoneDoc)
       Post #: 2753
RE: Great planes ultimate 160 - 9/12/2006 1:28 AM
ncrego
Score: 100
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: riotgear
ncrego, can you post a pic of your battery setup? i am trying to get ideas on how to best mount my fromecos... i lost the last plane because the battery tray broke during a snap.
thanks!
Wish I could, but it's all covered , so all I could show you is a blue belly of an airplane, or where the leads come up into the middle of the fuse and attach to the regulator. If you cut the covering on the bottom of the plane under the cockpit area, there is the underside of the cockpit, a ply support that goes aroudn the whole fuse and the stringers going back lengthwise. What I did was make a ply tray that fits between those stringers, and attaches to the ply former that goes around the fuse. It is attached with 30 minute epoxy and screws. Then the fromecos sit on foam and are velcroed a few times aroudn the plate and through the fuse former. They aren't going anywhere. I'm planning on moving them back when I finally get it to a CG I'm happy with, and I'll make a similar tray farther back, probably right behind the same fuse former.
Hide Signatures
(in reply to dubd)
       Post #: 2754
RE: Great planes ultimate 160 - 9/12/2006 2:56 AM
ice2
Score: 100
Last Login: 9/7/2010
Status: offline
very nice
Hide Signatures
       Post #: 2755
RE: Great planes ultimate 160 - 9/15/2006 3:23 AM
Slyder
Score: 100
Status: offline
I guess my Ulty does not want me to fly it.
Put new 645's on the ail. Sitting there working them and they sometimes over rotate, lock, then release. With only 3 pluged in it is fine. Thought maybe it was a y so I started switching them around. No matter where they are plugged 3 is fine and 4 is too much.
Any ideas?
Then I thought while it was all together I would run it since it has not run for over a month. Fired her up and let it warm at a high idle. When I tried to advance the throttle it sounded like a v8 running on 2 cylinders. Started playing with the needles but no change. Screwed them in and back out to last known good setting. fired up and sounded good. Went to full thr. and it ran great long enough for me to grab the tach next to me and see it run at 7000- then it just quit. Pulled the plug and grounded it against the engine. Turn the switch on and it sparks. Went through CH's guide and it says the pulse switch. Tried 2 others that were good (unless they went bad sitting in the box) but still no spark.
Guess I will send the ign and pulse switch to CH and see what they say.
Eric H
Hide Signatures
(in reply to ice2)
       Post #: 2756
RE: Great planes ultimate 160 - 9/15/2006 11:51 AM
bodywerks
Score: 100
Last Login: 7/10/2011
Status: offline
Are you trying to run all 4 servos into one receiver port via 3 y-harnesses? If so, that's your problem. You need a minimum of 2 ports or a signal amplifier most likely.
STRAIGHTEN UP AND FLY LIGHT!!!
Hide Signatures
(in reply to Slyder)
       Post #: 2757
RE: Great planes ultimate 160 - 9/15/2006 8:13 PM
LuvBipes
Score: 100
Last Login: 5/18/2013
Status: offline
Guys, I just got one of these beauties for my birthday from my better half It replaces my world Models 27% Ultimate that met an untimely demise when the receiver or switch quit working (damage from crash was so extensive I can't tell exactly what quit working).
Anyways, not wanting read thru 111 pages on this thread can anyone summarize the consensus for mods/improvements on the plane. I've already noted substituting CA hinges for flat pinned hinges and after looking at the fuse, I'll move the tank to behind the firewall since I'll be using a Moki.
Keep your eyes in the skies and your future should follow.
Hide Signatures
(in reply to dubd)
       Post #: 2758
RE: Great planes ultimate 160 - 9/15/2006 8:48 PM
ncrego
Score: 100
Status: offline
I built mine stock except for pinned hinges in the elevators after reading the whole thread. Now that it has some flights on it, I've observed that while the tailwheel arrangement is awesome, the wheel/tire itself is a joke. Replace it from day 1, it won't even last through the first day if it's like mine. Other than that, I'm planning on putting plugs for the upper ailerons in the top of the fuse with the ernst connectors like they show in the manual, and that's about it. I'm contemplating another gear arrangement, as with a 23 inch prop like I'm swinging, the ground clearance is minimal (less than an inch with it at a level takeoff attitude, but a Moki won't swing that big of a prop, so it shouldn't be an issue for you.
What are the rest of you guys running DA50s thinking about the gear? I don't mind the flexing, but if I ever have a less than soft touchdown, I'm betting it'll prop strike.
< Message edited by ncrego -- 9/15/2006 9:06 PM >
Hide Signatures
(in reply to LuvBipes)
       Post #: 2759
RE: Great planes ultimate 160 - 9/15/2006 10:20 PM
Slyder
Score: 100
Status: offline
Nope. Ch. 1&6 on a 138DP
Eric H
Hide Signatures
(in reply to ncrego)
       Post #: 2760
RE: Great planes ultimate 160 - 9/15/2006 11:05 PM
BoneDoc
Score: 100
Status: offline
go with either 22x8 or 3 bladed 21x8.
Josh
Hide Signatures
       Post #: 2761
RE: Great planes ultimate 160 - 9/15/2006 11:43 PM
LuvBipes
Score: 100
Status: offline
Thanks ncrego - have noted tail wheel. Prefer metal hubbed units anyway (so I can solder the washer on).
Hide Signatures
       Post #: 2762
RE: Great planes ultimate 160 - 9/16/2006 1:54 AM
fishdeth
Score: 100
Last Login: 9/18/2012
Status: offline
quote:
ORIGINAL: LuvBipes
I've already noted substituting CA hinges for flat pinned hinges and after looking at the fuse.
At least replace the stock hinge material with some GOOD stuff.
I purchased some 1/4 scale "Pro Hinges" from Radio South
I also doubled up at crucial points for added strength and security.
Jim
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2763
RE: Great planes ultimate 160 - 9/16/2006 1:57 AM
fishdeth
Score: 100
Status: offline
quote:
ORIGINAL: ncrego
I have the BME-50 in mine and had a "plop" landing that was the first and last flight for a brand new NX 22x8....
Jim
Hide Signatures
       Post #: 2764
RE: Great planes ultimate 160 - 9/16/2006 5:56 AM
mrbigg
Score: 155
Last Login: 6/19/2013
Status: offline
I got dropped off this thread a while back and I was wondering what was the heaviest weight that this plane came out at and how did it fly?
Smooth, like Keith Stone.
Hide Signatures
(in reply to fishdeth)
       Post #: 2765
RE: Great planes ultimate 160 - 9/16/2006 10:00 AM
BoneDoc
Score: 100
Status: offline
quote:
ORIGINAL: fishdeth
quote:
ORIGINAL: LuvBipes
Jim
I feel your pain Jim. When you go bigger, everything is just more expensive. That's one flight that caused you at least 25 dollars.
Josh
Hide Signatures
       Post #: 2766
RE: Great planes ultimate 160 - 9/17/2006 2:27 PM
storklappe
Score: 100
Last Login: 3/3/2013
Status: offline
Is there adequate ground clearance for a 22" prop? Also, does anyone know if a BME 50 will fit inside the cowl (without the carb sticking out)? Finally, will the plane do a decent knife-edge loop?
Hide Signatures
(in reply to skymaster68)
       Post #: 2767
RE: Great planes ultimate 160 - 9/17/2006 3:02 PM
bubbagates
Score: 121
Last Login: 6/18/2013
Status: offline
quote:
ORIGINAL: mrbigg
Mine came in at 16.5lbs then I was able to stick it on a diet. Number 2 is at 15.5 pounds
Both fly/flew very well at that weight
Bill James
Hide Signatures
(in reply to mrbigg)
       Post #: 2768
fishdeth
Score: 100
Status: offline
quote:
ORIGINAL: storklappe
The prop will clear if you have very soft landings or beef up the LG a bit.
Yes BME 50....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to storklappe)
       Post #: 2769
RE: Great planes ultimate 160 - 9/17/2006 4:11 PM
mrbigg
Score: 155
Status: offline
Thanks Bubba. Anyone know if this thing will fit assembled in a mini van?
Hide Signatures
       Post #: 2770
RE: Great planes ultimate 160 - 9/17/2006 5:27 PM
ncrego
Score: 100
Status: offline
Probably not, my DPM just barely fit assembled in a caravan, and it had a 5" shorter wing, and about a foot less on the fuse. However, that's the beauty of this Ulti, field assembly is fast and easy with the thumbscrews. I can get it together as fast as most monoplanes.
and RE: Knife Edge loop, it's an Ultimate, it has stupid powerful rudder authority. Mine will knife edge loop with no problem at all. I'm running a single Hitec 5955TG on the rudder.
< Message edited by ncrego -- 9/17/2006 5:28 PM >
Hide Signatures
       Post #: 2771
RE: Great planes ultimate 160 - 9/17/2006 5:41 PM
BoneDoc
Score: 100
Status: offline
What's the mixing you use to eliminate KE coupling?
Josh
Hide Signatures
       Post #: 2772
RE: Great planes ultimate 160 - 9/17/2006 5:43 PM
ncrego
Score: 100
Status: offline
Mine's right around 8% opposite aileron, and 8% up elevator. However, I don't have the CG where I want it yet, I'm still moving back, and those change with the CG.
Hide Signatures
       Post #: 2773
RE: Great planes ultimate 160 - 9/17/2006 5:53 PM
Bob Pastorello
Score: 126
Status: offline
Interesting.... the slight roll couple on mine is 'adverse', going opposite to rudder (it wants to roll OUT of K.E.), so for example, with LEFT rudder, my mix needed LEFT roll, and very slight, as the mix amount depends on the total aileron travels you've setup. If you like fast roll rates (I do), then the mix gets pretty small, because the faster you K.E., the less rudder travel is needed.
One thing I've found important is setting the mixes for your particular "cruise" airspeed, so that you'll be using real world deflections, and not just numbers. One of the reasons some planes need multi-point p-mixes for coupling.
Further aft your CG goes, the more negative pitch with rudder will occur, too....I flew a tail-heavy Cap for awhile that needed - TRULY - 26% mix at cruise to have no pitching on knife. Then I flew a Sukhoi and felt a LOT better about the Cap
The Ult with stock CG has VERY little pitch mix needed, mine is on the order of 3 or 4% at cruise power (about 1/2)
It really shouldn''t be this hard....
Hide Signatures
       Post #: 2774
RE: Great planes ultimate 160 - 9/17/2006 7:50 PM
fishdeth
Score: 100
Status: offline
Had a couple more GREAT flights on the Ultimate today.
Beautiful Florida weather.
A friend help me setup the "snap roll" switch on my 9C and that was AWESOME... blindingly fast snaps !
VERY nice smooth landings... even with a 6mph crosswind...
Jim
Click for fullsize
Click for fullsize
< Message edited by fishdeth -- 9/17/2006 7:54 PM >
Hide Signatures
(in reply to Bob Pastorello)
       Post #: 2775
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.938RCU1
