RE: Great planes ultimate 160
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Great planes ultimate 160
Page: <<   < prev  209 210 211 212 [213] 214 215 216 217 218   next >   >>
Login
RE: Great planes ultimate 160 - 7/21/2008 6:22:33 AM
sdstick06
Status: offline
How do the Bennet tanks work.... looks like you have to drill the cap and install the fittings?? How do you do the vent inside the tank
Found the felt clunk... it is a Zenoah part # 5500-85400
I think the felt clunk is a GREAT idea and I plan to get one
I wish I new more about the Bennet tank and how it goes together... not much info to be found
SDS
(in reply to vertical grimmace)
       Post #: 5301
RE: Great planes ultimate 160 - 7/21/2008 2:48:48 PM
69 roadrunner
Status: offline
The tank looks great but that wont stop the stuff from getting to the carb I need a good filter both on my red gas can i installed a clear v/w filter but need a filter for the plane what do you guys use the runner
(in reply to sdstick06)
       Post #: 5302
RE: Great planes ultimate 160 - 7/21/2008 2:57:25 PM
69 roadrunner
Status: offline
Is the flet clunk a filter and is that the only filter you put on the plane thanks the runner
(in reply to 69 roadrunner)
       Post #: 5303
RE: Great planes ultimate 160 - 7/21/2008 3:49:00 PM
sdstick06
Status: offline
runner.... that's correct
       Post #: 5304
RE: Great planes ultimate 160 - 7/21/2008 5:20:13 PM
iflywhenican
Status: offline
Use any of the felt clunks or any of the fine wire mesh inline type filters on your gas line. Just as long as you filter it BEFORE the gas gets to your carbs. I have an inline filter on the inlet line of my fuel can, also one on my inlet line to the carb.
_____________________________
If you have to bend over more than once, it wasn't a good landing....
       Post #: 5305
RE: Great planes ultimate 160 - 7/21/2008 5:30:12 PM
sdstick06
Status: offline
Yep... thats what I do too.... filter on the can and the plane both
(in reply to iflywhenican)
       Post #: 5306
RE: Great planes ultimate 160 - 7/22/2008 3:26:55 AM
vertical grimmace
Status: offline
You do have to make the holes in your Bennett tank exactly where you would like. This is very easy though. They come with fittings for 3 lines. A fill, a vent, and the pickup with clunk to the carb. The Fittings are already barbed so you do not have to worry about that and there is absolutely no tubing to bend. It is the simplest design and works great. The cap screws on and will never fail like a stopper. Some say it could come un-screwed but I have never seen that.
I am just about done mounting my engine now. Unless I am missing something, the standoffs that came with my DL 50 were long enough and work fine. Do I need to move my engine further out to balance? I kind of thought this engine would be heavy for this plane and moving it back would help.
The cowling fits fine in this position.
       Post #: 5307
RE: Great planes ultimate 160 - 7/22/2008 2:46:58 PM
69 roadrunner
Status: offline
I used just the stand offs that came with the dl50 and had no concerns it worked out great and did not have to add any wt. The runner
       Post #: 5308
RE: Great planes ultimate 160 - 7/22/2008 10:17:15 PM
codfish
Status: offline
quote:
ORIGINAL: a1pcfixer
aad2dd,
Test fit wings together just like instructions tell you to. Bottom wing needs assembled in advance of these steps.Get some 60 minute epoxy from the hardware store (Ace Hardware carries it).
Cover upper portion of fuselage (from epoxy dripping onto it).
Assemble as per instructions & wipe off excess epoxy (rubbing alcohol & paper towels).
Look back (here) a few pages for my list of "Links to mods" for ideas on modifying wing joiners prior to above steps.
'Glassing' of bottom wing not required, unless you forgot to modify wing joiners.
I built my wings a while ago before I read this thread. I did not modify the wing joiners so I was wondering if:
1) I really need to glass the wings?
2) Where to glass, how much, and what weight cloth should I would use?
3) Both top and bopttom wings?
thanks...
(in reply to a1pcfixer)
       Post #: 5309
RE: Great planes ultimate 160 - 7/22/2008 10:25:40 PM
sdstick06
Status: offline
I recently completed my wings. As I see it... the joiners are risky.... especially without glssing the joints.
My version of the build included building new joiners with carbon fiber plate and high grade aircraft ply... and 3" wide medium weight fiberglass tape top and bottom.
I know for a fact my wings will never fold up.
Confidence in your aircraft is essential in a high performance aerobatic airplane.
SDS
(in reply to codfish)
       Post #: 5310
RE: Great planes ultimate 160 - 7/22/2008 10:54:37 PM
speed nut
Status: offline
Hi I have been flying one with a zenoah 45 with no trouble. It will pull it straight up as for as you want it to go.
You got to land it with a little power on to keep noes up. It bleeds of speed very quick. Mike
(in reply to drumbum)
       Post #: 5311
RE: Great planes ultimate 160 - 7/23/2008 12:46:16 AM
vertical grimmace
Status: offline
aad2dd,
[/quote]
thanks...
[/quote]
I think 3" cloth on the top and bottom of both wings would be safe. I think the real problem is the wrong type of material was used for the joiner. (should be maple) If this was a kit I am sure they would have advised fiberglass but it had to be engineered as an ARF so this is what you get. Recovering the center might not be such a big deal though and if the cloth lays down well it should look fine. I always like to tack my fiberglass cloth down with spray contact cement before adding any resin.
