RE: Great planes ultimate 160    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Great planes ultimate 160 Page: <<   < prev  267 268 269 270 271 272 273 [274] 275 276   next >   >>
Login
RE: Great planes ultimate 160 - 9/16/2012 2:32 AM
mchadwick
Score: 100
Last Login: 11/3/2012
Status: offline
This is a great plane!
< Message edited by mchadwick -- 9/22/2012 4:08 PM >
Hide Signatures
(in reply to Fl_Matt)
       Post #: 6826
RE: Great planes ultimate 160 - 9/17/2012 2:42 PM
mstcitabria73
Score: 100
Last Login: 5/24/2013
Status: offline
Building a Bud Nosen Citabria and using the spare control horns that came with my Ultimate. Neede a couple more control horns if anyone has a couple they want to sell...........Mike
Hide Signatures
(in reply to mstcitabria73)
       Post #: 6827
RE: Great planes ultimate 160 - 9/17/2012 2:47 PM
mstcitabria73
Score: 100
Status: offline
Message repeated and deleted, sorry...........Mike
Hide Signatures
       Post #: 6828
RE: Great planes ultimate 160 - 9/17/2012 4:53 PM
iflywhenican
Score: 100
Last Login: 5/15/2013
Status: offline
No, I didn't do anything different other than what the manual said. When we first started our building of these planes, we didn't know about any wing joiner failures, so I didn't do anything other than sand the joiner (it was to tight of a fit) and used the G'Glue. Believe me, it has withstood some "tasks of flight" and I have not had a single problem.....so far.
_____________________________
If you have to bend over more than once, it wasn''t a good landing....
Hide Signatures
       Post #: 6829
RE: Great planes ultimate 160 - 10/1/2012 12:01 PM
Gordon W
Score: 105
Last Login: 5/25/2013
Status: offline
Thanks for this thread guys. After reading every word and book-marking much of the great advice whilst I looked for a kit, I eventually discovered a kit on sale for half price (which over here made it about the same price as over there), so jumped at it.
Mine has a Saito FG-36 for power as I'm not a 3-D flyer and am content with performing lower-power pattern-style aerobatics. One reason for purchasing this kit was to study how a big light bipe is constructed, because my scratch-built own design 71in span Jungmeister seen in my avatar, which is to the same scale with the same wing area and powered by another FG-36, is rather overweight at over 17lb. I've learned some good ideas from this kit!
I did make a pair of replacement wing joiners for the Ultimate from beech engine bearer, and also stiffened the engine mount by adding 1/8in birch ply plates fully covering the front and rear faces of the firewall, and a square of 3/32 liteply to seal the top of the engine box. I glassed the entire engine mount box, with glass tape round all the joints, and the whole then being encased in 6oz glass/epoxy. As guys have mentioned, the u/c is softly sprung, but as the Saito only turns an 18x8 there's plenty of ground clearance for the prop.
Pics 1 and 2 show my way of securing the top wing servo connectors to the rear cabane with white heatshrink tubing.
Pics 3 and 4 show the engine and cowl cut-out. I opened out the scoop beneath the spinner to force more cooling air into the cowl.
I fitted a 16oz tank in the location suggested by Maudib. Pic 5 shows the tank wrapped in foam plastic and secured to what was the Rx mounting plate with Velcro straps. The three 2S 2200mAh lipo batteries, one for the ignition and two for the avionics, go in the next bay behind the tank on a new plate, and the Spektrum AR9000 Rx is velcro'd beneath the cockpit.
The blue finned device seen above the battery is a Powerbox Gemini dual battery regulator, and the black rectangular item above the tank is a 4.8V 5A regulator for the ignition supply.
I've used all the kit hardware except for the hinges which I replaced with Dubro heavy-duty hinges, and I employed a Dubro E/Z Mount Cowl System instead of the wooden blocks.
Being rather wary of engine vibration levels, I've fitted titanium-geared servos all round, using Savox SC1256TG for the ailerons, and Spektrum AR6030s for rudder and elevators. These are overkill for the engine power I'm using, but I wanted to minimise the risk of crumbling gears. In fact the Saito doesn't exhibit much vibration at all, which is very pleasing.
The model came out at around 15lb as have several others on this thread, but the plane is a delight to fly, with its attractive colour scheme enhancing every manoeuvre.
The CG came out in the recommended spot, and could maybe do with moving back a tad. I fitted a Spektrum telemetry module and altimeter sensor, which shows that on a good day the ship will do more than a 600ft vertical climb. Though it certainly won't prop-hang on the power it's got, it isn't short of vertical performance for such things as consecutive vertical left-then-right rolls, or vertical snaps, with enough power and speed remaining after either manoeuvre for a short vertical line before a stall turn and then repeating the rolls on the down-line.
The climb-out from take-off isn't as steep as I'd like because of the lower power and it definitely won't pull up into a prop-hang from take-off! Landing behaviour is excellent though, with a slow nose-high approach and most times I can get it to touch down tailwheel first.
The model is definitely a keeper and I'm looking forward to flying it a lot.
Gordon
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to iflywhenican)
       Post #: 6830
RE: Great planes ultimate 160 - 10/1/2012 8:23 PM
iflywhenican
Score: 100
Status: offline
Very nice job Gordon. I know that you will enjoy this plane.
Hide Signatures
(in reply to Gordon W)
       Post #: 6831
RE: Great planes ultimate 160 - 10/1/2012 8:36 PM
69 roadrunner
Score: 100
Last Login: 5/1/2013
Status: offline
I have one with a 50cc on it flys great I havent flown it in about two years been fling 100cc extra 300 but seeing your plane i think its time to break out and fly again the plane just flys so great its a shame to just let it sit Steve
Hide Signatures
       Post #: 6832
RE: Great planes ultimate 160 - 11/13/2012 12:06 AM
Fl_Matt
Score: 100
Last Login: 5/23/2013
Status: offline
I am putting a new DLE 55RA on this plane and wanting to use a Vess Prop. Question is what Size and pitch should I go with? Any input would be appreciated.
Hide Signatures
(in reply to 69 roadrunner)
       Post #: 6833
RE: Great planes ultimate 160 - 11/13/2012 12:24 AM
mstcitabria73
Score: 100
Status: offline
Break in prop Vess 22/8-10, Vess 23/10 after break in.
Hide Signatures
       Post #: 6834
RE: Great planes ultimate 160 - 11/13/2012 2:08 AM
Fl_Matt
Score: 100
Status: offline
Thank you Sir
Hide Signatures
       Post #: 6835
RE: Great planes ultimate 160 - 11/27/2012 12:28 AM
Fl_Matt
Score: 100
Status: offline
So Far I am setting up my Ultimate with
2) 3200mah life batteries
Wike R/c IBEC w/ optical kill for ignition
Spectrum 9ch Powersafe reciever and failsafe switch
Savox servos 0251 on Ailerons and Elevators, 0254 on throttle and 1256tg on rudder
DLE 55 RA engine
Vess 22A prop
Carbon Fiber Spinner
Dubro Flat pinned hinges all surfaces
Carbon fiber rod over 4-40 for all contol rods with ball links
Hangar 9 rubber tires
Hide Signatures
       Post #: 6836
RE: Great planes ultimate 160 - 11/27/2012 12:41 AM
acerc
Score: 221
Status: offline
I have the DLE 55 in mine with a 23-8 prop.  And in has unlimited vertical.
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 6837
RE: Great planes ultimate 160 - 11/27/2012 1:53 AM
tiger650
Score: 100
Status: offline
quote:
ORIGINAL: acerc
Same with me, dle55 and Xoar 23x8 prop. Awesome plane. I never tire of flying it!
Hide Signatures
(in reply to acerc)
       Post #: 6838
RE: Great planes ultimate 160 - 11/27/2012 1:56 AM
PropsnWings
Score: 110
Status: offline
I have a DA 50r for mine... But I do have a new DLE 55 sitting too.  Maybe I should make a change in my plans before I get to my project for this winter?
Hide Signatures
(in reply to tiger650)
       Post #: 6839
RE: Great planes ultimate 160 - 12/10/2012 12:33 AM
Fl_Matt
Score: 100
Status: offline
Almost ready, just need to set the throws and give it a good once over.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to PropsnWings)
       Post #: 6840
RE: Great planes ultimate 160 - 12/10/2012 12:48 AM
acerc
Score: 221
Status: offline
Ok Matt! You gotta get rid of that baby and put in a doll. LOL
You like flyin on the edge of your seat?  You will love this plane.
Click for fullsize
Robert
Hide Signatures
       Post #: 6841
RE: Great planes ultimate 160 - 12/10/2012 1:23 AM
mstcitabria73
Score: 100
Status: offline
quote:
ORIGINAL: acerc
DLE 55 is very strong, pulls mine vertical out of sight at about the same speed as flying level wide open, good combination motor/plane for sure....
Hide Signatures
(in reply to acerc)
       Post #: 6842
RE: Great planes ultimate 160 - 12/15/2012 3:05 AM
Fl_Matt
Score: 100
Status: offline
All finished. Throws set to the book, batteries charged. If all goes well I will run the engine and get her tuned tomorrow. If that goes well I may put her up in the air.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 6843
RE: Great planes ultimate 160 - 12/15/2012 10:03 PM
Fl_Matt
Score: 100
Status: offline
I must say that is the best running engine I have ever had to set up. 1/16 turn richer on low and 1/8 turn richer on high and it transitioned perfectly spun the 22A at 7550 (peak was 7650 richened it till it went down 100 RPM) no burble at all.
I started on low rates thank God, plane was a little tail heavy. I originally checked the balance at 1" in front of rear cabane hole (wings off) but after a real squirrly flight I did the wings on check and at 6 3/8 (book ideal point) it was extremely tail heavy. All I can think of is the servos I used on the ailerons may be heavier than normal (Savox 0251 220 oz of torque). For now I am going to add 8oz on top of the engine posts. I checked the batteries and after over an hour of on time with ignition and a 10 minute flight it only used 302mah and I have 2 X 3200 life packs. I think I will order 2 X 2500 life packs which should lower my tail weight and allow me to remove the 8 oz on top of the engine stands. The plane AUW before the 8 oz came in at 14lbs 15 oz and now weighs 15 lbs 7 oz which is still not bad I guess.
Hide Signatures
       Post #: 6844
RE: Great planes ultimate 160 - 12/15/2012 10:42 PM
PropsnWings
Score: 110
Status: offline
What engine are you using again?
Hide Signatures
       Post #: 6845
RE: Great planes ultimate 160 - 12/16/2012 12:08 AM
Fl_Matt
Score: 100
Status: offline
The new DLE 55RA .
Hide Signatures
       Post #: 6846
RE: Great planes ultimate 160 - 12/23/2012 1:56 AM
Fl_Matt
Score: 100
Status: offline
I got a new digital scale that is supposed to be very accurate and re weighed my plane. It is 16lb 3oz so I am definately going to get a couple smaller packs and then lose the 8 oz on the nose. Should come in around 15lb 8 oz after the changes.
Hide Signatures
       Post #: 6847
RE: Great planes ultimate 160 - 1/27/2013 9:55 AM
agbjarn
Score: 100
Last Login: 2/24/2013
Status: offline
My kit which I bought last September is still waiting in the box in my garage. I have to finish my H9 Ultra Stick 60 + DLE20 before I start building the Ultimate, probably with a DLE55.
Thanks for this great thread.
Agust
Agust
Hide Signatures
       Post #: 6848
RE: Great planes ultimate 160 - 1/27/2013 6:19 PM
Uncas
Score: 105
Status: offline
quote:
ORIGINAL: Fl_Matt
I started on low rates thank God, plane was a little tail heavy. I originally checked the balance at 1'' in front of rear cabane hole (wings off) but after a real squirrly flight I did the wings on check and at 6 3/8 (book ideal point) it was extremely tail heavy. All I can think of is the servos I used on the ailerons may be heavier than normal (Savox 0251 220 oz of torque). For now I am going to add 8oz on top of the engine posts. I checked the batteries and after over an hour of on time with ignition and a 10 minute flight it only used 302mah and I have 2 X 3200 life packs. I think I will order 2 X 2500 life packs which should lower my tail weight and allow me to remove the 8 oz on top of the engine stands. The plane AUW before the 8 oz came in at 14lbs 15 oz and now weighs 15 lbs 7 oz which is still not bad I guess.
That is a lot of servo torque for your ailerons! The airlerons are actually smaller than what is on a UCD 46. But your servo weight is about 2 oz so I do not think that is the problem. Mine weigh about the same.
I suspect your squirrly flight is not because it is tail heavy, especially since you have 8 oz in the nose and large batteries. I actually put my 5 cell NiMH (1700maH) pack in the fuse behind the wing to get it more tail heavy for 3D flying, plus I even added weight in the tail. I am running a DA-50r. I would check my trim, even have someone trim it up during flight. Also make sure your wings are tight and properly bolted. Double check this. I have my rates set very high - I even re-hinged my ailerons for more throw to limit the Torque roll during hover. I used all stock hardware. I presume you used the tail support wires and they are tight. Another thing, this plane can fly pretty slow without stalling, no need to race it around, though it can do that too.
This is one of the best flying planes I have ever owned.
Good Luck!
Hide Signatures
       Post #: 6849
RE: Great planes ultimate 160 - 1/30/2013 11:52 PM
Fl_Matt
Score: 100
Status: offline
The squirrly flight was before the 8 oz on the front . The next thing was it balanced perfect with the wings off method but after the touchy flight I checked it with the wings on method (per manual) and the tail would drop like a stone. I trimed it out on the touchy flight, if you trimmed it for level flight at half throttle then rolled inverted it would climb at a good clip.
quote:
ORIGINAL: Uncas
quote:
ORIGINAL: Fl_Matt
Good Luck!
Hide Signatures
(in reply to Uncas)
       Post #: 6850
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
