RAPPTOR
FL, USA Status: offline
HI GOONY IS RIGHT.. USE AS AS POLYESTER.. LOOKS THE SAME..THE STUFF IS SUPER.. I HAVE GONE TO AS LITTLE AS 1/4 PERCENT HARDENER WITH GOOD RESULTS..GIVES ME MORE WORK TIME.. 1/2 WOULD BE BEST IF YOU ARE IN A COOL AREA.. OK,,SANDS SUPER,NO TACKY SURFACE, HEAT DOES NOT EFFECT IT,, ANY GLUE STICKS TO IT CA,EPOXY,ECT..CAN BE THINNED WITH ACETONE,MEK,..CAN AD COLOR,PIGMENT,,,WORKS WITH ALL RELEASE SYSTEMS..PVA,WAX.MARBACOAT.SILICONE..HAS JUST THE RIGHT AMOUNT OF FLEX SO THE GLASS DOES NOT ,EGG-SHELL, WHEN FLEXED,, IT TOOK ME A LONG TIME TO FIND A RESIN I COULD RELY ON,,THIS IS IT,,ABOUT $32 A GALLON RD
