Montague
On the JR's I have, and have used, you leave the power switch "off". They power themselves up enough to do buddy box functions when you plug in the trainer cord, but it's not transmitting even if it has the crystal or module installed. But if you flip the power swtich on, they actually try to transmit, and I thought they actually stopped working through the buddy box. Btw, for JR systems, you can get a direct servo control cable that basically adds a signal wire through the charge port. If you plug in to the trainer port, but leave the power off, it can actually drive the RX directly and allow you to set controls and such even with the TX off.
_____________________________
Kirk Montague Adams RCCA 560
