Turbine alignment
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> Turbine alignment
Page: [1]
Login
Turbine alignment - 8/10/2005 11:38:20 PM
Yann
Status: offline
If like me you have troubles to align your turbine / thrust pipe, here is what I just did for my Savex F16.
I used a laser pointer I placed of the turbine on the mount.
I first designed a little mount for the laser beam, to take the place of the turbine in the fuselage.
I taped a piece of paper as a target for the beam. The goal now is to get the laser beam in the center of the taget...
I did my turbine alignment in 10mn using this tool.
I thought this trick could be usefull
The end result can be seen on pics... perfect alignment of turbine and thrust pipe.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: Turbine alignment - 8/11/2005 12:00:05 AM
mr_matt
Status: online
Great trick.
I did something similar to align the external wing tanks on my BVM F-4.
For turbine duct alignment (with no mounts to use) I use thread to line it up, I will try to post some puctures myself.
Again, very good tip!
_____________________________
Matt
JetCat rep
(in reply to Yann)
       Post #: 2
RE: Turbine alignment - 8/11/2005 12:16:57 AM
Yann
Status: offline
Thanks Matt,
Just stick a piece of paper to the end of it, and you can align pretty much everything...
Once you have made it, don't loose it, you can re-use it anytime you want to check your alignment, or install your turbine in a new bird.
(in reply to mr_matt)
       Post #: 3
RE: Turbine alignment - 8/11/2005 8:14:16 AM
Lt. Dan
Status: offline
Excellent tip!
I use thread, but I may try the laser next time.
Click for fullsize
Click for fullsize
(in reply to Yann)
       Post #: 4
RE: Turbine alignment - 8/11/2005 9:01:27 AM
A343
Status: offline
And here another way of doing it. A woodblock turned in a lathe gives perfect alignment between my Merlin160 and Tam's pipe. Even the distance between the nozzle and exhaust is her adjusted to the correct value. It doesn´t matter if you are using a bifurcted- or a straight pipe, vertically and horizontal alignment is achieved.I´ve another block made for my P160.
My 2 cents.
Thomas
Click for fullsize
< Message edited by A321 -- 8/11/2005 9:08:54 AM >
(in reply to Lt. Dan)
       Post #: 5
RE: Turbine alignment - 8/11/2005 2:22:49 PM
wojtek
Status: offline
hey guys, all good stuff here .... thanks very much as i will use a bunch of these ideas in the coming weeks ..
Wojtek
Nothing can ever be fast enough !!!
(in reply to A343)
       Post #: 6
RE: Turbine alignment - 8/11/2005 4:51:22 PM
Delta Mike
Status: offline
How critical is the alignment on centering???? Dennis
       Post #: 7
RE: Turbine alignment - 8/11/2005 4:54:58 PM
erbroens
Status: offline
great idea... thx for posting! I´ll going to make a wheel alignament tool with it too...
Enrique
E pluribus unum
(in reply to Yann)
       Post #: 8
RE: Turbine alignment - 8/11/2005 5:15:48 PM
Yann
Status: offline
Thomas,
First, I thought of this solution, but without a lathe to turn the wood block, my first attempt was a disaster...
It also has to be a tight fit to be accurate. Congrats, you worked it out...
Lt. Dan,
Godd idea, but how do you keep perpendicularity with your former, as you move it around to find the perfect spot ?
Also, you can only check two dimensions at a time...
Dennis,
If your turbine is missaligned with the thrust pipe you loose power. If the pipe is missaligned, you have the wrong thrust line, and the turbine won't push strait.
You might have troubles to trim the plane. It all depends of course how bad is your missalignment.
Thanks a lot for your inputs guys,
Yann
< Message edited by Yann -- 8/11/2005 6:00:44 PM >
(in reply to A343)
       Post #: 9
RE: Turbine alignment - 8/11/2005 5:52:47 PM
Woketman
Status: offline
I have found turbine alignment, when using a thrust tube as we are discussing here, to be very non-critical. Sure, if you are a few degrees off you will be heating up one side of the thrust tube a bit more, but if your tube is plenty thick (0.008" ), no matter. If it is at least three diameters long, you won't notice any thrust misalignment. If you visually center the tail end and the angle with the tube, all will be just fine.
Team Hitec/Multiplex, Fromeco
(in reply to Yann)
       Post #: 10
RE: Turbine alignment - 8/11/2005 10:27:07 PM
Miguel Santana
Status: offline
Nice creations ....all.
In my case I made a rim with carton.... Was thinking using a GPS , but decided not giving my friend another reason to makes jokes on my perfectionist sickness....
(in reply to Woketman)
       Post #: 11
RE: Turbine alignment - 8/11/2005 10:30:35 PM
Yann
Status: offline
Miguel, if you're so blind you need a GPS, don't bother, go strait to the white cane...
(in reply to Miguel Santana)
       Post #: 12
RE: Turbine alignment - 8/12/2005 12:00:44 AM
Lt. Dan
Status: offline
quote:
ORIGINAL: Yann
Lt. Dan,
Yann, I'm not sure I understand your question fully. I have measured the centerline of the airframe and then attached a string to run along it. I then line up the engine centerline along the string, and then once the mount is bolted in, I lined up the pipe the same way.
(in reply to Yann)
       Post #: 13
RE: Turbine alignment - 8/12/2005 12:15:11 AM
grbaker
Status: offline
I think he is stating that your method only lines the turbine and pipe up laterally and not vertically.
Gary Baker
       Post #: 14
RE: Turbine alignment - 8/12/2005 12:17:34 AM
