What would be arealistic finished weight for the 35 % Edge?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aerotech R/C Models Support >> What would be arealistic finished weight for the 35 % Edge?
Page: [1]
Login
What would be arealistic finished weight for the 35 % E... - 8/12/2005 7:45:59 AM
Albatross
Status: offline
I like to built the airplanes I fly.
I would like to built this airplane as light as possible. I selected a BME110, of course I will install CF Landing gear and CF wing tube, lightweight tires, etc.
Where are the areas where I can safely cut weight down on this kit?
Can I modify the turtle deck foam for a built up turtle deck? what about the belly foam? Any suggestions to reduce weight on the wings?
       Post #: 1
RE: What would be arealistic finished weight for the 35... - 8/12/2005 6:06:16 PM
Aerotech
Status: offline
Hello,
The only thing with using a BME is the engine weight. Its so much lighter that causes a balnce challenge. Stock weigh is 27-28lbs RTF with a DA100 or 3W106. Using a BME you have tomove alot up front and be mindful when building the stabs to keep the rear light.
John
(in reply to Albatross)
       Post #: 2
RE: What would be arealistic finished weight for the 3... - 8/13/2005 7:48:10 AM
Albatross
Status: offline
Jhon
The weight is my major concern since I am planning to fly at 6000-7000' of elevation.
I will replace the LG and wing tube by CF, lightweight tires, and all that good stuff, however I would still like to know how can I lighthen the airframe.
If you have any advices, this is the right time, let me know.
By the way has anybody reported 23 lbs ?
(in reply to Aerotech)
       Post #: 3
RE: What would be arealistic finished weight for the 3... - 8/13/2005 2:07:15 PM
Aerotech
Status: offline
Hello,
A very good customer in Vegas averages 26lbs and with a his 106's at 2500 elev. Its unlimited and one customer in Ca made 25lbs. I think for the size plane 23lbs will not be a weight it could make. I hope this helps with your decision.
John
< Message edited by Aerotech -- 8/13/2005 2:08:28 PM >
       Post #: 4
RE: What would be arealistic finished weight for the 3... - 8/30/2005 9:40:10 PM
teamsme
Status: offline
Smoke, lightened elevator and rudder, carbon gear, carbon prop, and li ions with a bme 102 evo, about 29-30 pounds. Thats dry, which is pretty good.
       Post #: 5
RE: What would be arealistic finished weight for the 3... - 10/5/2005 2:43:18 AM
Aerotech
Status: offline
Hello,
Just depends on the builder. Lots of options when you build it yourself.
John
(in reply to teamsme)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU1
