-Rich87T
IL, USA Status: offline
Sounds about right. I may be on the "too loose" side of things then. I think I'm starting sift through the BS I was told at the LHS and the consensus here. I was told by the LHS to wait on the carbon blades. They have a guy there that flies thier shop 'copter and he says he's cut two tail shafts, wires and all, in two with the carbon blades. He says, and i quote, "It'll fly better with the carbons, but when you crash, you'll break the expensive stuff instead of the blades." At $15.00 a pair for blades, it might be cheaper to break the head/swashplate. LOL This is also the same guy that told me to tighten the blades until they won't swing, too. Inital "cost" isn't really a huge factor to me, especially if it saves me buying 2 more sets of wood blades. If carbons are significantly better than the wood blades, I'll buy them tonight. If, however, carbons will start cutting tail tubes and breaking head/swashplate pieces like I've been told, then I'd rather stick with wood. Honestly, I think his problem is 1320 LiPo's on a 10T motor and over tightened carbon blades. But who am I to question the 'guru'? One last LHS quote, after replacing my blades for the first time... "We don't bother to track the blades. It'll fly fine". All that chatter said... and considering the above average abuse of a newer flyer, do you still recommend carbons? Or will I really drastically increase the damage to the heli? BTW, I'm not really shooting for inverted flight and stunts. I really just want to putz around competently and smoothly. I love the size of this heli and don't mind upgrading it a bit to improve fly-ability. I'm still running the 10T w/ heat sinks, flat blades and stock batteries. I bought a Nicad/Nickle/Lipo charger but didn't drop the $$$ for Lipo's yet because I wanted to research those a bit more first. I'm thinking about buying carbons and switching ot the 9T from the performance kit. I didn't bother yet because I'm running stock batteries and thought the 9T would just slow the head speed. Do you recommend 9T on stock batteries or stick w/ the 10T? I'm not ready to purchase LiPo's yet. I do have one last stupid question. I bumped the rearend on some dirt/grass while hovering backwards and snapped the CF stick that holds the tail up, flush with the plastic. The plastic is not broken. How do you get the leftover CF rod out if there's nothing to hold onto? I was thinking about getting a small drill bit and hand reaming it out. Is it held in with CA, or friction, or what?
