Ed Cregger
GA, USA Status: offline
quote:
ORIGINAL: Woody 51 Hi Guys, I'm back again. Work commitments have kept me away from my fav website, though I have also managed to destroy a ST G.51, in a 200 foot to ground level "Splot!", since I last logged on. (Crook aileron servo!) Glad to see that the thread is back on track and some great info is being exchanged. I am one of 2 who run Fox's at my club and yes, we both have had our share of frustration in the past. One thing I did learn about Fox engines was that some operating procedures that worked on other brands, didn't neccessarily work with a Fox. (Sort of like the differences found between "hotting up" a Chevy and the old Ford "Cleveland" line) I had to go back to my C/L days of many moons ago when I used to run a Fox .35, before I finally figured out my Fox .40's and .45R. I don't have a problem with either now. I can leave my Fox's "in the shed" for months and then get 'em out and fire 'em up 2nd flick and never have to touch the carby needle. I have more powerful engines in my "stable" than some of my Fox's, but I like to match the engine with the potential performance of the model that they are powering. No point installing an MVVS .49 with tuned muffler, (or silencer), into a Trainer, when a Fox.45R will be quite adequate. And I did have to turn to George over at Fliteline Solutions to sort out my Eagle IV .74 Ring. His alternate head button design for this engine does work very well. "K" (Pleased to meet you by the way,) I agree with you that MVVS is a "pearler" of an engine brand, I have several now (and Dar Zealon has helped me no end in understanding them. This website is so lucky having guys like Dar as contributors.) and will be adding more in the future. And yes, as you say, the "FX" was better "on the Barby." But mate, it didn't taste nearly as good as the Shrimp! A bit hard and metallic! Turning to OS, (I did use OS engines also in my C/L days. Didn't even have to fit a muffler back then) they have a marketing department that many other businesses around the world would kill for and their spares back up was and still is, excellent. But my humble opinion is, that OS reached the peak of their design with the FSR series. Once Ogawa San went to the Great Flying Field in the sky, those that have followed him in the design department at OS, have found it somewhat hard to walk in his footsteps. Same situation over at Fox since Duke passed away. Charles Thacker has had plenty of time to sort out the niggling problems with some of the Fox line, (caused mainly by Duke's fiddling with Higher Compression in his motors) and also come up with a decent, flexible Twin Needle carby. Incidentally, this latter project was started, but has now been abandoned. The few TN Carbys (Fox part no #2600) that they produced for "C " Frame engines, worked well, but suffered some QC problems with machining etc. Methinks Mr Thacker has seen the steady "Asianisation" of the (much flooded) model 2 stroke market, that has gobbled up Super Tigre and Irvine (maybe, - no one quite knows what the situation with Irvine is at this time.) Also the arrival of larger Brushless Electric motors and Lipo batteries and so has decided to concentrate on Glow Plugs and developing the new range of large scale Fox Gasoline Engines. He has to keep an eye on the company's future survival, so no point in spending large amounts of development $$$, when ones market is not all that big. What they make works pretty well and keeps their client base happy, most of the time! (Almost like a Cottage Industry.) In finishing, did Crazy4Flight, ever sort out his overheating .50? -------------------------------------------------------- Most Fox engines are "old paradygm" designs. This does not make them bad. Just different. I used to get a kick out of how far Duke would go to incorporate as many "features" as he could in a casting, instead of relying upon machining and additional parts. An example would be the carb fuel nipple on the seventies engines equipped with non airbleed carbs. I recently purchased a used Fox .50. I've always wanted one, but never got around to buying one before. I'm still deciding whether I am going to convert it to Diesel operation. Running Fox engines without lots of castor oil in the fuel usually leads to overheating and poor running. That is the single biggest "secret" to successfully running Fox engines. Even the ball bearing, ABC engines. All Foxes need castor oil.
_____________________________
Artisan "Flying models since the Fifties - I'll get the hang of this yet!!!"
