RE: Another Beginner Build - Sig Somethin' Extra
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Beginners >> RE: Another Beginner Build - Sig Somethin' Extra
Page: <<   < prev  40 41 42 43 44 [45] 46 47 48 49   next >   >>
Login
RE: Another... - 12/7/2005 5:04:00 PM
krossk
Status: offline
Another covering milestone reached...
And by popular demand - in high(er) res!)
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to kiswa)
       Post #: 1101
RE: Another... - 12/8/2005 12:06:25 AM
SLOWFLY58
Status: offline
krossk... Stay with it man !!!! Plane looks great !!!
Your getting close now !!!!
Dale
_____________________________
GETTING BORED WITH THE SAME OLD PLANE AND THE SAME OLD FLYING ROUTINE ??? TRY A FULL THROTTLE INVERTED TOUCH AND GO !!!
(in reply to krossk)
       Post #: 1102
RE: Another... - 12/8/2005 1:10:29 AM
CJ Danca
Status: offline
well i havent been at RCuniverse in a while, and this is my first post since i have been back....and i'll say that your plane looks fantastic! good luck with finishing, keep up the good work
nephew of the famous terry d'anca!
(in reply to SLOWFLY58)
       Post #: 1103
RE: Another... - 12/8/2005 4:43:32 PM
krossk
Status: offline
Getting a little further on the nose. As you can see, I decided to take a little artistic license and deviate on the transition into the front. The zig-zag was easier and (IMO) looked more consistent with the lines than my originally designed radius. But now I'm dreading the thought of covering the compound corners on the front of the cowl.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to CJ Danca)
       Post #: 1104
RE: Anothe... - 12/8/2005 7:50:31 PM
Scworth
Status: offline
Man, Krosk looks awesome i cant say it enough.
       Post #: 1105
RE: Anothe... - 12/9/2005 9:47:05 PM
iflynething
Status: offline
Amazing. I love that cowl
~Michael~
Michael Carr
Funtana, S100, Fut. 3050 / Rap 30, OS 32, JR 537, Fut. 401
(in reply to Scworth)
       Post #: 1106
RE: Anothe... - 12/9/2005 10:10:24 PM
krossk
Status: offline
quote:
ORIGINAL: iflynething
~Michael~
If you like it naked, wait until you see it covered. I've just got the pinstripe left to do on the lower half. Hopefully I can get it done and pics uploaded when I get home. The compound corners weren't as bad as I thought they'd be. Although I did end up with more seams than I had hoped for.
(in reply to iflynething)
       Post #: 1107
RE: Anothe... - 12/9/2005 11:08:44 PM
somegeek
Status: offline
Looking good, krossk! Cowl looks good.
On those close up shots, select the macro button if your camera has it (should looke like a flower above the button).
Fly safe, have fun. Measure three times, cut once. The man who makes no mistakes does not usually make anything.
       Post #: 1108
RE: Anothe... - 12/10/2005 1:38:02 PM
krossk
Status: offline
Well, I've finally got all the covering done except for the last piece on the bottom (after final balance check and control cable installation).
I'll post some better pics after I get the tail surfaces hinged, but you get the idea of the finished product from these...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Lightfoot -- 1/11/2006 12:38:59 PM >
(in reply to somegeek)
       Post #: 1109
RE: Anothe... - 12/11/2005 12:39:43 AM
yel914
Status: offline
Krossk, a really excellent covering job. I'll bet you can't wait to get this in the air. You should be very proud!
WACO Brotherhood #24
       Post #: 1110
RE: Anothe... - 12/11/2005 3:49:04 AM
somegeek
Status: offline
Damn - that cowl looks sweet!
(in reply to yel914)
       Post #: 1111
RE: Anothe... - 12/11/2005 12:05:03 PM
krossk
Status: offline
Thanks guys, I am really pleased with how it is turning out. After seeing the cowl finished, I'm really wishing I would have made the white stripe across the top at least twice as wide as I did. I kept it the same width as the side stripes, but I think it should have been at least double that to transition from the purple to that much orange. I'm alos hoping that I don't run into any cooling problems by not having any air flowing through the cowl. Oh well, if that happens, then I guess I'll have an opportunity to fix the stripe!
And I am sort of anxious to see it in the air, but I'm not too overly eager to put her there yet. I still need a lot more practice time on my T2 before I'll be brave enough to maiden this one. But I'm hoping that time will come by late spring. I was hoping to have it ready to show off at the next club meeting on 12/19, but it's looking more like the January meeting.
       Post #: 1112
RE: Anothe... - 12/12/2005 11:37:18 AM
krossk
Status: offline
I'm in the process of hooking up the tail surfaces. I've got the rudder & elevator hinged and the pull-pull connected on the elevator. It still needs the throws adjusted, but I'm really impressed with how solid the elevator is with this set-up. There's NO give whatsoever when deflection. When I get the cables finished on the rudder, then I'll post some detail pics of the controls.
Also, does anyone have any tips on cutting the canopy so it fits closely without screwing it up?
       Post #: 1113
RE: Anothe... - 12/12/2005 3:21:24 PM
tychoc
Status: offline
krossk:
The covering looks great! As for the canopy, what I did was to cut a narrow piece of masking tape and put that down along the indicated line on the canopy first. I then purchased and used a pair of canopy scissors and was able to cut precisely along the line. This made for a perfect fit.
Good luck,
tychoc
Good judgement comes from experience. Experience comes from bad judgement.
