Magnum R and Jett
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> Magnum R and Jett
Page: [1]
Login
Magnum R and Jett - 8/18/2005 10:52:53 PM
MJD
Status: offline
Hi Bob,
Planning ahead for my next fast toy, I have a second Magnum and I am kind of turned on to have a go at the canopy mods to fit a rear exhaust piped motor under the canopy. #1 has the "stock" Weston .50V1/pipe combo.
So.. I think you know a bit about Magnums - what Jett motor pipe combination do you think I should look at to fit into #2? I'd like a bit of throttlability.
I would think the ideal would be the BSE FIRE .50 with riser header and full tuned pipe. Will it dust the .50V1?
Thx
Mike D
       Post #: 1
RE: Magnum R and Jett - 8/19/2005 4:01:13 PM
bob27s
Status: offline
Hi Mike....
thanks for writing.
So you are doing a rear exhaust magnum conversion huh? Fun !
All of the sport jett engines throttle great. None of that on/off sorta stuff. However, the more critical you tune the engines for speed, you sometimes end up with a very sharp pipe-step that makes the midrange a pain in the buns. Most of the time we do not recommend tuning like that.
The West .50 is a real nice engine. Lots of power. My experince on the Magnum has been that the Jett SJ-50 with the SS muffler (higher rpm tune) installed is about the same performance as the Weston .50 with its full pipe. Prop selection is different... you have to match the prop to the SS muffler. APC 9x7, 8.75x8, 8.8x8.5 or 8.5x7.25 props are ideal. On the .50V engine, you run a tiny 8" prop and cut the pipe shorter.
As for recommendations --- depends on your end goal a bit. I assume this is - fast -
Yes, a FIRE - 50 would be great. Cast case or BSE - your choice - You just have to decide if you want a quiet pipe or a nitro pipe.
Engine is well behaved, and can be tuned for what ever prop you want to run.
Id suggest setting it up like a "Whiplash/Diamond Dust" engine, tuned for 18K "plus". Prop accordingly (dub will recommend props).
Image attached here is Zach Dempsey's Shrike. FIRE-50, Riser header with nitro pipe. Turns 8.8x8.75 at 19100 RPM peak, ground.
Would it be possible for you to utilize the standard 15deg angled exhaust ? This is a straight pipe setup, pipe angles up from the engine about 15 deg.
Or do you really need a riser header ? The stock o-ring exhaust is nice because you can purchase a tuned, fully welded pipe setup - no leaks, and its more compact. The riser header requires a coupler.
The extreme option here.....
One of Dubs new FIRE-60LX engines. High timed sleeve, improved sub-port induction, typically turns a full blade APC 10x6 over 18,000 rpm. Thats monster power from a "40". Figure on turning a 8.8x9.25 about 19K peak, ground. This setup runs great, still idles and transitions. Just take the time to break it in properly, learn to set the needle in that process. Always set it 600-700 rpm off of peak at launch, and it will last a good long time.
I hope this is helpful.
Bob
Click to see fullsize image.
Click for fullsize
< Message edited by bob27s -- 8/19/2005 4:08:27 PM >
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to MJD)
       Post #: 2
RE: Magnum R and Jett - 8/19/2005 9:12:30 PM
MJD
Status: offline
Quite helpful, thank you!
Yes, speeeeed is the goal, but I figured you'd see my message here rather than the extreme speed forum. Someone has already done a rear exhaust buried pipe conversion, with an MVVS pylon engine. What I read on it ended with engine setup still in the works after a few flights.
http://www.philsrcworld.fsnet.co.uk/projectmagnum.htm
I have to do some measuring to determine what the pipe arrangement needs to be. When I get the distance from the top of the mounting beams to the bottom of the pipe compartment I'll consult with you. Then to the finance manager about the engine.. better take some flowers and a bottle of wine
Mike D.
(in reply to bob27s)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
