2 storke pump. Which one?
Tower Hobbies
Logged in as Guest
  Printable Version
K&B .40 R/C Ball Bearing
Seller:  area51jmitch
Details:   $75.00   |  8/28/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> 2 storke pump. Which one?
Page: [1]
Login
2 storke pump. Which one? - 8/19/2005 12:24:29 AM
nimffish
Status: offline
I will be inverting a 2 stroke engine. Maybe a 1.08 or 120. Will I need to use pump? If so who sales them?
Thanks in Advance,
Pat
       Post #: 1
RE: 2 storke pump. Which one? - 8/19/2005 12:35:00 AM
w8ye
Status: online
The pump requirement is usually indicated by the tank not being mounted directly behind the engine
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to nimffish)
       Post #: 2
RE: 2 storke pump. Which one? - 8/19/2005 6:30:08 AM
Rcpilot
Status: offline
If your going to mount a 2-stroke inverted, then you need to move the tank so that it's perfectly centered up on the centerline of the carb spray bar.
You don't need a pump unless you plan on mounting the tank on the CG or significantly behind the engine. If you do run a pump--then get the Cline Regulator. It's not really a pump--but rather a fuel regulator for the carb. It works very well. You'll need a 2-needle carb for the regulator. An air-bleed carb won't work with a regulator.
What you might really need for an inverted 2-stroke is an on-board glow driver. It's an electronic device that lights your glow plug at idle or slow speeds. It has it's own 1400mah nicad battery on board. You just use a Y-harness to hook it up to your throttle servo and then dial it in. Most on-board glow drivers have a dial that you can turn with a small screwdriver. This is so that you can set when you want the glow to come on--relative to throttle position.
Somebody is for sure gonnna pipe up and tell you that using an on-board glow driver is a dummies excuse for a poor tuning job. Thats BS. Sometimes--no matter what you do, a 2-stroke glow engine just won't run inverted without a glow system. It's no different than using a volt meter, or a tuned pipe. If ya need it--then ya need it.
Airplanes have expiration dates. It''s just not printed anywhere on them.
I''m not really an airplane pilot; but I did stay at a Holiday Inn Express last night.
       Post #: 3
RE: 2 storke pump. Which one? - 8/20/2005 6:49:21 PM
captinjohn
Status: offline
A small 2 ounce head tank near carb works good too. Of course you need a main tank also. Then you may not need the regulator or pump!!!!!!
I never met a engine I did not like!
(in reply to Rcpilot)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU1
